Adding smartkey door handle (rear or pass side)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by tjp74, Aug 14, 2009.
  1. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    I took a look the EWD. It looks you'll be required following parts to enable the back door SKS.
    Parts:
    - Back Door Opener Switch Assembly
    - Outside Luggage Electrical Key Antenna
    Wiring:
    - from/to Certification ECU/above two parts
    Ken@Japan
    2 people like this.
  2. sciguy125
    sciguy125 Junior Member
    CA
    If someone has instructions on how to remove the panels (maybe for the installation of some accessory), I'm willing to go in and check things out. However, I don't feel like going in blind.
  3. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Ken,
    Do you have any info for the passenger side? I'm wondering if we only need the door handle with all the sks antenna/switch inside? Thanks,
    Winston.
  4. MikeDS
    MikeDS Member
    298
    Los Angeles
    Now we're getting somewhere! Thanks Ken! We still have to figure out how to get the parts, and how to install them, but at least we've got some leads!
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Ken,
    It appears from the schematics that the signal "unlock" (LSS) is already there in the wiring - this by default. Not sure about this antenna - there was a previous post stating the antennas are already there... I think there is also a programming piece to the equation...
  6. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I believe the signal "unlock" (LSS) is unlock detection for open/close motor, not for SKS signal detection.
    The signal names for the "Back Door Opener Switch Assembly" are TSW5 and TSW6, and names for "Outside Luggage Electrical Key Antenna" are CLG8 and CG8B.
    Also, all wirings are marked with (*3), which means...
    ∗ 2 : Driver' s Door Only Smart Key System
    ∗ 3 : Except ∗2
    It looks the passenger side door handle has both lock/unlock switch and antenna combined, but the wiring in not there too.
    I believe the wiring is the most critical parts for this modification.
    Ken@Japan
  7. MikeDS
    MikeDS Member
    298
    Los Angeles
    Hmm...is there a wiring harness part number or anything like that? Are these parts available anywhere?
  8. Wiserone
    Wiserone Member
    111
    B R O O K L Y N
    Just wanted to revive this thread.
    I would be really interested in a passenger and hatch SKS setup.
  9. DougD
    DougD Junior Member
    Chicago-land
    Me too. I took a bunch of heat from another post of how could I have missed this, but I'm sorry, without the trunk option, the whole SKS is really limited in value. I can't tell you the # of times in my Prius Gen II I got out and locked from the trunk or needed to place stuff in the trunk. Having to pull out my keys negates soooo much value. We really need a step by step on this one.
  10. rrolff
    1,610
    246
    So Cal
    I'd suggest someone with time on their hands go to a dealer and ask for a quote to add it.
    That will show the details involved....
  11. andino
    andino Senior Member
    746
    551
    San Jose, CA
    If I remember correctly from the other SKS thread, the wiring is already there for the passenger door and all you'll need is the door handle with the sensor to add it. Not sure about the rear of the car though. I'm willing to take apart my car when I get it but it probably won't be for at least another week.
  12. rrolff
    1,610
    246
    So Cal
    Just moved speakers around - and there is an unused molex connector in the door (I believe all 3 doors).
  13. ronlprius2
    ronlprius2 Junior Member
    56
    San Francisco
    Anyone figure this out yet? I have a 2006 and want at least the back hatch to unlock in my wife's 2010.
    Thanks!
  14. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    As we're discussing the auto-open feature, I have a question about the reverse -- locking the door using the touch-area on the door handle.
    I've had my 2010 Trim III only since April -- so not much experience with it in cold weather.
    Does the locking function work ok if you're wearing gloves? I tried it yesterday with a handkerchief in place of gloves, and it didn't open.
    What say those of you who've had the 2010's during weather which warranted wearing gloves?
  15. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Owners manual (page-51) says as follows;
    "Gripping the door handle when wearing a glove may not unlock or lock the door".
    Ken@Japan
  16. lettcco
    lettcco New Member
    newbie with a Gen III prius III...would like to bump this thread!
  17. rleepac
    rleepac New Member
    44
    Manteca, California
    I'm going to the dealer this weekend to have that annoying back-up beeping changed to 1 beep and while I'm there I'm going to get a quote for adding the SKS to the hatch and passenger door. Will update if/when I get something from them.
  18. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    Keep us updated. I will do the mod if someone verifies it works.
    I bet the dealer will tell you it is not an option. Someone needs to try it. Maybe I can get a front 2010 door handle from a junkyard to plug in and try.
  19. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Outside door handle prices are here.
    Part Detail
    If I'm reading that correctly, the dumb key handle lists for $37.75 and the smart key handle $199.17:eek:
    I predict Toyota isn't going to have run on smart key handles anytime soon.:D
    Might luck out in a wrecking yard, except those guys can be pretty sharp about the value of what they have.
  20. Judgeless
    1,821
    257
    Cleveland, OH
    Really I only need one. I always put my jacket and netbook in the back seat.
    I just wonder if it will work.
