adding subs but...
Discussion in 'Prius c Audio and Electronics' started by Priusxrs, Oct 15, 2012.
  1. Priusxrs
    Priusxrs Junior Member
    61
    Pa
    Started to make my own custom box to fit in the trunk under the mat. Its big enough for a 12" sub but small enough to keep the spare. The main probem im having is wire the amp up. My amp only uses Rca's to connect to the head unit. I ended up buying something to convert the speaker wire to rca but cant seem to find a diagram of the radio. Anyone know where I can find what color does what to hook this thing up? The unit I got is an AudioControl LC2i if anyone has any imput on how or where to install this im open to suggestions too : ) Preview of the box is below also
  2. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    This PDF has been a major time saver. The wire colors are the stripes, not the main jacket color, FYI. Yes, you'll need to use that speaker-level to pre-amp level converter to get rational signal level to your amp's RCA inputs.
  3. taco4267
    taco4267 Junior Member
    North Carolina, USA
    How did this turn out? I would to see some pictures and hear how you did it all.
    Justin Park likes this.
