Adding USB charging ports for rear passengers.
Discussion in 'Prime Accessories and Modifications' started by Flaming, Feb 23, 2019.
  1. Flaming
    Flaming Active Member
    138
    122
    QC , Canada
    Technology
    Since i saw the new Prius 2019 e-AWD gettting USB ports at the rear on the armrest i decided to do the same. It was easier than i thought , you just need to pull the rear panel and it come off. There is a lot of room behind the panel so you just need to make a hole to fit your USB ports and run 2 wires tap the power from the '' round'' 12V plug.
    I use the 12V to power a Dashcam but now i have 2 extra charging port for the rear passengers. I suggest to use a multi-meter to make sure that the polarity is right. in my case the green is the Positive and the white& black was the negative.
      File size:
      79.2 KB
      File size:
      96.9 KB
      File size:
      125.2 KB
      File size:
      40.2 KB
      File size:
      95.3 KB
      File size:
      118.8 KB
      File size:
      102 KB
      File size:
      127.2 KB
      File size:
      53.4 KB
      File size:
      81.5 KB
    BLee76, citiprius and yoyoman like this.
  2. ashish koirala
    ashish koirala Junior Member
    West virginia
    2018 Prius Prime
    Nice mod. Will have to try this.
