Additional inverter cooling
Discussion in 'Gen 3 Prius Accessories and Modifications' started by toyotechwv, Jun 27, 2012.
  1. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    Here's my next mod, gonna mount this under driver's side headlamp behind bumper cover. It will be plumbed in after the factory inverter radiator. Hope to find a small fan from a bike or atv to mount on it for additional cooling. May be a few days before I get it in the car, will post pics when its installed.
    PC36100 ? 2
    peterjmc likes this.
  2. peterjmc
    917
    188
    Clarksburg, MD
    How hot does the coolant get after a session?
  3. toyotechwv
    474
    251
    Princeton, WV
    I saw inverter temps at 130 after one run and 5 minutes of heat soak. If there is constant airflow it stays cool but once that stops it heats up fast.
    PC36100 ? 2
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I have to be fully blocked with OAT in the 80's to see 130's.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I do not know, that does not sound like a recipe for long life to me. It will also cause a hell of a belly ache.
    Simtronic and xs650 like this.
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Nice!
    I remember doing similar things for ratings trannies. Now here we are doing it for inverters. LOL
  7. WE0H
    WE0H Senior Member
    3,247
    527
    Do the computers roll back the electric motor torque as the inverter coolant temp rises? At what temp does it start to decrease torque if that is so?
    tnx,
    Mike
  8. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I have monitored the inverter temp while running but have not thought about checking it later after a heat soak like you say. I am seeing a similar situation with the HV battery after stopping and going back to the car 30 minutes or an hour later.
    Thanks for the info.
  9. toyotechwv
    474
    251
    Princeton, WV
    I have the xgauge installed that runs the hv fan on max, keeps the battery nice and cool.
    If I'm not mistaken 116 degrees is where amperage is reduced.
    PC36100 ? 2
  10. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I have used the XGauge to step the HV battery fan through its 6 speed modes for testing purposes but have not gone so far as to leave it on max speed. Have you seen any issues with running the fan at max speed? Hmmm ....
    If 116F is where amperage is reduced I have not noticed this reduction as I have seen it as high as 130F after sitting and heat soaking before driving again.
  11. toyotechwv
    474
    251
    Princeton, WV
    If you're not WOT you probably won't notice it.
    PC36100 ? 2
  12. jdcollins5
    5,131
    1,338
    Wilmington, NC
    OK thanks, I am never at WOT so would not notice.
    Back to my other question, have you seen any issues running the HV battery fan at max speed all of the time?
  13. toyotechwv
    474
    251
    Princeton, WV
    Nope not a bit. Keeps battery in upper 70 lower 80 range during normal driving, and upper 80's during competition.
    PC36100 ? 2
  14. toyotechwv
    474
    251
    Princeton, WV
    More to come when I finish install.
    PC36100 ? 2
    Robert Holt and Tracksyde like this.
  15. toyotechwv
    474
    251
    Princeton, WV
    Plumbed and no leaks. I drilled out the dimples in the fog light insert, the cooler sits directly behind it. Autocross this weekend, will post performance of cooler.
    PC36100 ? 2
  16. toyotechwv
    474
    251
    Princeton, WV
    Very impressed with highway perofmance. Kept inverter temps in low to mid 80's at 70mph, ambient temp around 75. During autocross I'm still battling heat soak. Going to try and mount a motorcylce fan to the cooler for continuous air flow.
    PC36100 ? 2
  17. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    I like it. How's it work now? Did you install a fan for it?
  18. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Nice job.
  19. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Any updates on this Paul?
    offib and 32kcolors like this.
  20. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
