adizon's 2010 Prius V
Discussion in 'Gen 3 Prius Accessories and Modifications' started by adizon, Jan 14, 2015.
  1. adizon
    adizon Junior Member
    52
    89
    SF Bay Area
    So I finally mounted, for real (not photoshoped), the test BRZ wheels my friend let me borrow since his has tires. Ended up buying ebay hub centric 3mm spacers, McGard spline lug nuts 12x1.5 and locks, and ebay hub centering rings (56.1-54.1) to go along with this set up.
    . . . but I do have a full set of BRZ wheels, just without tires at the moment. FRS center caps are on the way.
    wanted to see how long the McGard's were compared to the OEM ones in case I end up getting longer wheel studs to add more space between the wheels and brake calipers. OEM on screen left
    You can see how little the space is going from 56.1 to 54.1 is.
    The hub rings are super tight in the wheel so after testing one and squeezing it in the wheel, I decided not to use them on my borrowed BRZ wheels since they are so thin and fragile. Didn't want to wait another 2 weeks for them to come from Lithuania. I was a little worried not having centering rings will shake at speed. To my surprise, they are smooth. I wonder if it was to do with the McGard spline lugs and the way the seating is on the lugs. Anyways I do plan on putting on the centering rings, maybe put some anti seize, so they don't get too stuck and break later on.
    Please excuse the dirty car, it's been 2 weeks or so, didn't want to wait to take photos though . . .
    #41 adizon, Feb 11, 2015
  2. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    You're getting pretty good at Photoshop!! (y)
    Nice shading and use of the 3D features to rotate the car and wheels around. Never tell it wasn't for real... :cool:
    #42 sfprankster, Feb 11, 2015
    adizon likes this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    The lug nuts you are using have the wrong kind of seating surface. The oem has a flat washer type seat. The FRS wheels are Scion/Toyota, so don't they have the same type of seat as the oem wheels?
  4. adizon
    52
    89
    SF Bay Area
    I'm using the McGard splines for the BRZ wheels. I was just showing a comparison of the oem ones to the McGards that I bought for reference.
  5. adizon
    52
    89
    SF Bay Area
    Finally got my BRZ wheels mounted the other day. Even these photos don't do it the justice of seeing this combo in person. Bought the wheels and tires from 2 different sources. Ironically both were off of 2015 BRZs with less then 100 miles on each. The Michelin Primacy HP tires have a nice noticeable grip and response difference over the Bridgestone Ecopia tires my Prius came with, and the Ecopia's still have like 90% tread still.
    Anyways some quick shots at dusk by my work. Yes, needs a mild drop. TRD springs are what I've been thinking of.
  6. BigBear2010
    BigBear2010 Member
    156
    65
    Admire your photoshop skill :D. I have frs wheel on my blue prius, I bet the car is not look beautiful in the real life :))
  7. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    lol what the...
    Johnsk93, Burna J and Xterra72 like this.
  8. adizon
    52
    89
    SF Bay Area
    No photoshop on the latest post, just good camera/lenses and lightroom!
    Xterra72 likes this.
  9. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    That's so funny! I can't believe @BigBear2010 actually thought the pictures were photoshoped. You are that good @adizon .:LOL:
    #49 Xterra72, Feb 20, 2015
  10. ECR
    ECR Member
    40
    Looks good I like it
    Whats the wheel and tire specs?
    I am looking to getting either ct200, brz, or corolla S wheels or just go with 18's
  11. Accordlayingkit
    1,618
    1,748
    377
    hmm... like a Nikon D5100??
  12. adizon
    52
    89
    SF Bay Area
    BRZ wheels 17x7 +48 56.1, tires are Michelin Primacy HP 215/45r17
    Canon 5D mkII, 24-70mm f2.8 mkII
    Accordlayingkit likes this.
  13. s2kinfinite
    s2kinfinite Junior Member
    Could you provide some info on where you got your leather wrapped shift knob for Left Hand drive? I tried to search Ebay and only found right hands from Japan.
