Adjusting bluetooth voice guidance?
Discussion in 'Gen 3 Prius Audio and Electronics' started by L8rnr, Jul 31, 2009.
  1. L8rnr
    L8rnr New Member
    38
    Long Island, New York
    Does anyone know of a way to adjust the voice guidance prompts and or incoming ring volume on gen 3 without Nav?
  2. jestoy7
    jestoy7 New Member
    238
    25
    Jacksonville, FL
    Good question.
    A question I have: Can stream audio via BT (say and ipod) and have your phone paired at the same time?
  3. L8rnr
    L8rnr New Member
    38
    I have last years Iphone 3G and although it synchs up perfectly with the car to make calls I do not believe it has the capability to stream music. Maybe the new Iphone does? In any case , incoming ring volume ( car, not phone ) is quite high and I'm curious if there is an adjustment for this? Also, the female guidance voice volume should be adjustable..
  4. jim256
    jim256 Member
    317
    69
    Eastern NC
    The voice guidance has a setting in Setup on the radio dial. To control ring and speaker volume, adjust it with the steering wheel radio volume button while it is ringing and/or when the party at the other end is speaking. Works on mine.
    2 people like this.
  5. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Both iphone 3g and iphone 3gs can do bluetooth audio streaming to a nav system.
  6. L8rnr
    L8rnr New Member
    38
    How about streaming music to a non Nav system? I don't think I can with the older 3G phone. If I can, kindly explain how...
  7. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
  8. L8rnr
    L8rnr New Member
    38
    I don't think the incoming ringing volume is controlable.
    Also read the manual which was no help here. Any help appreciated.
    Thanks.
  9. jim256
    jim256 Member
    317
    69
    Eastern NC
    I posted this reply to you earlier in this same thread::confused:
  10. L8rnr
    L8rnr New Member
    38
    Yes it does work thanks. Does the ring volume stay at that level for all incoming calls or do you have to adjust it all the time? Only tried it on one call.
  11. jim256
    jim256 Member
    317
    69
    Eastern NC
    Interesting you should ask that, since I had only had one incoming when I set it, as well. I was just out, had my wife call me, and yes, the setting persists on new calls and rings.
  12. L8rnr
    L8rnr New Member
    38
    Confirmed This also. There should have been a notation in the manual.
  13. jim256
    jim256 Member
    317
    69
    Eastern NC
    I believe I found it in a video on the Toyota site for Camry with Bluetooth and non-NAV, or perhaps a FAQ on the Toyota Bluetooth pages. It should be in the manual, I agree.
Loading...
