Advent Navigation Unit
Discussion in 'Gen 3 Prius Audio and Electronics' started by eroeder, Oct 27, 2011.
  1. eroeder
    eroeder Junior Member
    72
    22
    Dallas
    2018 Prius Prime
    $1000 plus tax/shipping
  2. Jeremy Harris
    Jeremy Harris New Member
    221
    39
    Salisbury UK
    I HAVE read the posts.
    What is very, very clear is that the CANbus connections that turn the JBL amp on are present and working fine with these Chinese units. The problem seems to be with the audio level setting, which is set in software. Maybe you've not looked at how the US JBL system works. There are audio feeds from the head unit direct to some speakers (same as the European/UK version) and also audio feeds to the JBL amp that drives the front door speakers (and sub-woofer, I believe, if you have it fitted). The amp is turned on and off via a CANbus generated digital data signal on the US model, whereas the European/UK model has a simple amp-on wire. Aftermarket head units for use on US JBL equipped cars either have to have a built-in CANbus interface (as the Ottonavi and one or two other Chinese units seem to have) or they need a separate uP box to generate the digital signal the amp requires.
    The issues being reported for the Ottonavi and related units are pretty typical for Chinese units. The hardware is essentially OK, but the firmware isn't always great. It's clear that some companies are taking these Chinese units and trying to sort out the firmware bugs and market them with their own brand, providing valuable customer support in the process. I'm not knocking this at all, as it has to be better than trying to wade through a baffling Chinglish manual and trying to get help from so far away.
    Maybe I'm wrong, and this Advent unit is all-new and made in America. I'd happily bet that it isn't though, if only because the economics of developing such a specialised bit of kit for a relatively small market would be pretty tough here in the West. My money is on it being a Chinese unit with some value-added firmware, and frankly I don't think there's anything wrong with that at all.
  3. MrPete
    MrPete Active Member
    501
    190
    Colorado, USA
    Having used an older Navteq-based GPS in the past (Mio), and recognizing that Navteq supports several levels of functionality... I have a few questions for whoever actually is using this unit:
    1) Does it support traffic detection? (built in or option?)
    2) Does it support rerouting?
    3) Does it support estimated time to destination?
    I'm guessing #3 only, which is based on historical not current data. That's what my MIO had. Not bad but quite different from navigation with up to date traffic info.
    Other than that, this looks like a very interesting unit!
    (Note: I agree with others: this is most likely similar hardware to other units, but with nicely cleaned up firmware. Windows CE makes that a very doable chore. ALSO note: most of the time, Win CE units can be "jailbroken" in a sense... and other software added. I use OziExplorer which supports real Topo maps...)
  4. Jeremy Harris
    221
    39
    Salisbury UK
    Yes, the Chinese units can be adapted to run pretty much any WinCE software, up to a point. The primary difficulties to overcome are that WinCE is usually a Chinese language version and is locked into ROM, rather than EEPROM, so any changes have to run at boot. Not a major problem when it comes to running things like Oziexplorer (I had this running on one) but there are challenges in getting things like Memory Map to run, as mapping the GPS data port for that was beyond me!
    The same goes for music playing software, pretty much any MP3 type player, or video player, can be made to launch and run OK.
    What seems harder is getting at the radio driver, or the DVD/CD element. They both run on separate, dedicated, processors and it's only the video/audio stream that's switched.
  5. prius2010II
    prius2010II Member
    269
    23
    us
    Jeremy--I'm not going to edit my posts but they don't read the way I intended.
    I understand US Toyotas' require a signal on the CANBUS to "turn on" the JBL amp. The (US) JBL amp looks for a fixed signal with the amp controlling the volume. A JBL amp "turn on" feature is of little value if the unit doesn't also supply the correct signal for the amp to work.
    Any unit which is designed to look like factory navigation is going to look similar. Too many posters think a unit is the same just because it looks the same.
    I don't know if Audiovox uses US factories for the OE Navigation line. It's possible it's made in China. It's made to Audiovox standards.
    I want to apologize to Jeremy. I forget he's not from the United States. I'm not sure if he ever even heard of Audiovox before this thread.
    This line is being marketed to new car dealers. The intent is a $2000 installed price. Used when the dealer has a customer who wants nav but the cars in stock don't have it. Or for cars, not just Prius, where navigation is part of a $$$ technology package. The dealer can accommodate a customer who only wants a factory style navigation. The GM units will actually work with the factory SAT radio unit.
  6. eroeder
    72
    22
    Dallas
    2018 Prius Prime
    So far, I am really impressed with the ADVENT units look and feel. I have not had any problems with the speed of going from app to app.
    PROS:
    -Cheaper than Factory
    -Looks like Factory
    -Easily updateable
    -Lots of cool GPS options (like split screen)
    -Great picture quality
    -Integrates everything nicely
    -Every functionality I could ever imagine
    -Cool feature to MOD the started up screen to be a personal picture a stock PRIUS one ADC MOBILE created.
    -Bluetooth works great, and now I can stream audio via bluetooth if I like.
    CONS:
    -Depending on which production run you get, the harness for the radio may require the installer to drill new mounting holes or it will not mount flush. I learned this was error in early production and has since been corrected.
    -Sound quality is great, but the front/rear fade functionality is odd since the JBL sound system (if you have it) messes with it. In the full REAR setting, the rears are on, but quiter than the fronts. I leave it set full rear and like 2 click forward and it is ok for me. Only fix to that I am told is to bypass JBL amp and have only the radio head drive the speakers, or bypass and put in a separate amp. Not the fault of the radio, issue with JBL system.
    -To have button lights come on when you turn on headlights, installer has to run a wire.
    -The unit provides a new USB/small input jack station which I had mounted in that "nether region hole" under the radio. I also wanted the jack that is in the arm rest to still function (normally it will be bypassed for the new input jack colocated with the US[​IMG], so the installer did a special hook up. For me now, if for some reason I have an input plugged into each small input jack, the one in the armrest will take priority. Have no plans to run that much stuff, but I wanted the jack to work "just because".
    Neutral:
    Need a $30 jLink video cable to run video off the iphone. ADC Mobile includes one free.
    -Traffic updates would be cool
    -iPod Menu only lists Music and Video. It needs to also list PODCAST, AUDIOBOOK, iTUNES UNIVERSITY, Etc.. to better subdivide files. Program mod request submitted. Updates will be a snap.
    All and all, though nothing is perfect I am very pleased with the unit.
  7. Danger
    Danger Member
    175
    22
    Frisco
    Please take pic of where the mic location is. Thanks.
  8. prius2010II
    prius2010II Member
    269
    23
    us
    Did anyone use the FCC registration number to attempt to determine if a different company manufactured the unit.
  9. RaZa
    RaZa Member
    480
    93
    removed
  10. eroeder
    72
    22
    Dallas
    2018 Prius Prime
    I got a special deal at a local install shop, but when I talked to Best Buy they were going to do it for $150 (with backup camera).
    Now that I have the correct video cable, videos play great from my iPhone too!
  11. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I got my Flyaudio unit from Canada and could't find a FCC number.
  12. eroeder
    72
    22
    Dallas
    2018 Prius Prime
    Finally back home, so here are some pics of my unit and mic location...
    2 people like this.
  13. teiresias
    teiresias Junior Member
    61
    Hampton, VA
    Have you heard anything back regarding a fix for this? I listen to a ton of podcasts while driving (probably more than I do actual music) so having access to my podcasts is very important. Are you saying the unit doesn't list podcasts at all or that they're just listed conglomerated in the "Music" section?
    I'm debating between this and Rosen, but the software on the Advent seems to be better going off forum impressions and the videos on ADCmobile's site. I wish I could find a local dealer for this though, just for some peace of mind.
    I really don't want a new head unit for the GPS at all, mainly just want to be able to add a backup camera and have a better iPod interface, since I've yet to find a good mounting solution for the ipod that puts it in easy reach when plugged into the Aux of the standard Prius II radio, and if I keep buying cables and mounts I'll spend nearly as much as a new HU. :;)
  14. eroeder
    72
    22
    Dallas
    2018 Prius Prime
    Haven't heard back yet, but not too worried since I know future updates are easy to install. Yeah the podcast get listed in the music catagory right now, but what I learned was under the PHONE selection there is this AD2P (or something like that) which when selected basically brings up a play button which will play (via bluetooth) whatever podcast I am listening to. It advances along the items in folder too.
    I have my USB/Aux plug located down in the "hole" region. When my phone is plugged into the cable, I either set in down on the lower shelf or have it laying on the passenger seat.
    I am still happy with the unit and recommend it.
  15. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
  16. eroeder
    72
    22
    Dallas
    2018 Prius Prime
    Cool, I'll pop it in today!
  17. brewcrew9
    brewcrew9 Member
    111
    Madison, WI
    2014 Prius Plug-in
    THANKS FOR ALL THE INFO on this unit to date
    I know it has been awhile now, was wondering if anything (positive or negative), has changed with this unit. I am trying to decide between this model or an Alpine double din unit. I love the "factory" look though.
    Any new info I would be truly grateful, Again thanks for the prior info and the pictures
    David
  18. eroeder
    72
    22
    Dallas
    2018 Prius Prime
    No issues here, still works great and looks factory. Other than the minor stuff mentioned, I am very happy!
  19. rod28
    rod28 Junior Member
    ny
    My name is Rod in NY. Thanks for your posts and clarification about the subject. Retrospectively , I whish I bought a Prius II. Based on your input I got an Advent OTOPRI1 for my Prius III 2011. I love the streaming feature. I have few questions if you do not mind as you seem to have a very good understanding of the system:
    1- The button on the unit are not lit even with the headlights on at night It is difficult to use them in the dark: you said you had to run a wire. Could tell me form where to where.
    2- I run into the same problem you reported as for the front doors speakers. I had to change the setting to make the rear speakers somewhat higher. The dashboard speakers were overpowering. What kind of amp did you use to bypass the JBL amp.
    3- Is it poosible to use the toyota bluetooth with the features on the wheel to speak, pick up or hang up the phone? Mine is now using the Advent touch screen to execute these functions.
    4- I feel that at time the speeakers fade out randomly for a fraction of second? Did you feel that?
    I thank you so much for your time and input.
  20. eroeder
    72
    22
    Dallas
    2018 Prius Prime
    No prob, in response to you questions:
    1. My system was installed by a Advent dealer. He was able to get the backlight to work behind the buttons, so it is not a problem. Looks nice at night.
    2/4. I did not put in an amp, though I have thought about doing it. I saw one of these message boards a diagram to cut holes for speakers in the rear side walls, and thought about doing that with an normal amp. The installer guys said a simple small compact alpine amp could be done if I didn't want to do rear speakers and bypass the JBL. For now, I just leave the sound mostly forward to avoid the spikes, though the sound fluctuation seems to occur main when listening to the radio.
    3. My steering wheel buttons work fine with the bluetooth.
    Hope that helps!
