Advice for a beginner thinking about buying a Prius 3 gen
Discussion in 'Gen 3 Prius Main Forum' started by P-etr, Jun 24, 2023.
  1. P-etr
    P-etr New Member
    EU
    Hello,
    I am new here and have been reading the forum here as I am thinking of buying a Prius 3gen after the facelift.
    I understood that this car has a frequent problem with the head gasket, a problem with the EGR system, the battery may need to be replaced after 10 years and it is advisable to check the battery with Dr.Prius.
    I would like to ask if there is anything else important that I should know about this car?
    Are the problems fixed from a certain year of manufacture?
    Does it even make sense to buy this car? Isn't it better to buy an Auris hybrid, for example?
    52,804
    welcome!
    sometime in 2014 production, toyota upgraded the pistons and rings.
    the brake actuator is another expensive system.
    auris might be a better choice, but idk anything about them.
    all the best!
  3. JC91006
    16,936
    8,646
    If you buy this car, make sure it’s from an owner that’s had it for a while. Many people flipping this car after it’s been repaired (sometimes properly, sometimes not)
  4. Mendel Leisk
    42,298
    Just to clarify, "EU" is "European Union", you're somewhere in Europe?
    Only the piston rings, somewhere through model year 2014; the VIN number at which the change occurred in the attached. The older piston rings were "low tension", more prone to clog and/or let oil into combustion chamber.
    Your best bet would be to buy one with under 100K miles (hopefully not rolled back). Anything more and you're getting into the zone where EGR clogs and head gasket fails.
    #4 Mendel Leisk, Jun 24, 2023
  5. Tombukt2
    Tombukt2 Senior Member
    13,830
    2,510
    Durham NC
    Yeah that would be better do you know how to buy one?
  6. Tombukt2
    13,830
    2,510
    Durham NC
    IF you've access to JDM vehicles be looking at those. You're obviously looking at hybrids or IQ type vehicles...they're some deals out they're in the market. The flood gates have opened up . Easy to get them in now . Just beware of State issues.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I would just buy another car that won’t need a lot of repairs from the get go. Some feller bought and drove his for 80,000 miles and head gasket and hv battery both went after recently. If money and time is no object, the Prius turd gen is perfect t for you.
    JohnPrius3005 likes this.
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,040
    6,920
    Texas Hill Country
    Inverter fails and excessive oil consumption are additional concerns.
    If you insist, I would buy the 2018 EU Prius + (v/Alpha) with a lithium battery. The Prius + wagon has a 50% increase in space and improved ride. Plus beefed up suspension, brakes and ac system. By then the low tension rings, inverter and brake booster issues are sorted out. Plus a lithium battery from 2018 would easily last five or more years.
    They were also sold in Australia until 2021 with the same gen3 engine.
  9. Tombukt2
    13,830
    2,510
    Durham NC
    Buy a gen2 . For kids and first timers . It's almost painless . Many of those by the time you get to them will be pre-sorted and some won't but a lot will batteries already been replaced etc etc HIDs have been removed and LEDs or halogenes have been put in inverter pumps have been dealt with all of those sort of things no problem where else you get them done as needed they're not huge You only get taken real bad on these things when you make it an emergency I have extra vehicles on premises I have a motorcycle a big bore scooter etc My car breaking down is never a problem nothing to get excited about at all We are not stranded or anything close to that. That is a big part of mechanical things when something breaks if it is an emergency in your eyes then money gets spent without good thought processes when things aren't an emergency things can be dealt with a lot easier if that makes sense. That's why you pave the mold remediation people $400 an hour from Friday night until early Monday morning because it's what an emergency can't wait top Dollar and so on and so forth.
  10. P-etr
    P-etr New Member
    EU
    Thank you all for your replies. I thought it would be a reliable car. Many taxi drivers here have hybrid Toyotas.
    Yes.
    Do you mean Auris? Yes, I can buy these cars here in the EU.
    But isn't it identical technology to the Prius, just with a different body?
    So maybe I'll be looking more for a Honda with a regular gasoline engine.
  11. Tombukt2
    13,830
    2,510
    Durham NC
    In the EU I would think you'd be looking for one of the small diesels that goes in the Corollas and other little cars they might even be a three cylinder version I know some of these engine numbers I just have to look at the paper to tell you what they are but the caldina and a bunch of other cars have these very small diesels that I would imagine getting near 50 mi to the gallon I don't know I saw a '93 Corolla in Greece just like my LE in the States with a beautiful little diesel engine in it
