Advice for first time Prius buyer - which Prius to look for?
Discussion in 'Gen 3 Prius Main Forum' started by KciN, Jul 20, 2019.
  1. KciN
    KciN New Member
    Omaha, NE
    Yes maybe you are correct - it depends on the math whether the prius is worth it. I had kind of assumed that whatever I get for my subaru I would use to buy the prius - up to 10k. So if it's an even trade, I would save on gas every year. But really the variable would be maintenance, like you mentioned. In that respect, keeping our subaru may be a better bet, given we have owned it since new and taken very well care of it. No, ours hasn't had a head gasket problem, or were you hypothetically talking about the possibility of that happening on a used prius if we bought one?
    What happens if the prius never gets to 190-204F? Also, later in the thread I mentioned we actually drive around 1000 miles/month. For example today, we drove around town for 25 miles running the kids to activities, then to work, parked the car there for 6 hours, then from there went to pick the kids up. Not every day is like that but it's rare for us to just drive to and from work and that's it. We are always running the kids around. I apologize that I wasn't clear about that before.
    51,950
    i had read that some suburb's had a head gasket issue around 140k, but i don't remember years and models.
    short trips won't affect the prius anymore than other cars, you just don't get 50 mpg.
  3. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Look at it this way regarding MPGs and short trips. Startup uses a lot of gas. Warm up uses more than the normal amount of gas. Once you're warmed up, you're getting great mileage. But a short trip and you turn the car off before you get the advantage of the great mileage. Then you go through the start-up/warm-up routine and get home. Bad mileage (for a Prius but still better than most cars). My commute is 50 miles one way. At 1 mile I'm at about 20 mpg, at 10 miles, I'm up to about 40-45 MPG. at 50 miles, my trip MPG might be in the range of 55-58 and it's still increasing from the startup deficit. Of course, weather, driving conditions and your driving habits make a huge difference. Short trips do no more damage to a hybrid car than a regular ICE car, probably less so because your ICE turns off for a good part of your drive.
    By the way, I just set a personal record 66.1 mpg on the 50 mile drive home today!
  4. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Nice record. Here's today's commute-
    69.7 MPG to work, 68.2 MPG back home. Last 3 tanks were avg 65 mpg, last oil change was 13,000 miles ago :eek:
  5. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    EGR gets plugged up quickly.
    We had a guy in Europe that had misfire around 40k miles. It turned out to be EGR plugging early from lots of short trips.
    Plugged EGR encourages head gasket problems due to combustion temperature and pressure increases.
    Pixel XL ?
    mikey_t and Raytheeagle like this.
  6. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Based on the information you have given us, I would recommend a used Corolla or Civc. Both will be cheaper to repair over a 5 to 7 year period than a used Prius would. If you really want to save money over the next 7 years, that would be my suggestion. If you buy a used Prius, you are buying a car that is on the latter end of its cycle when things tend to need repair and attention and these things cost a lot more than a normal vehicle. Most of us in Priuschat knew that and so we bought our cars new, with the expectation of some repairs 5 to 7 years and later. So, we have had 5 years of great mpg and have saved up some money for the costly repairs to come. Heck, even a used Yaris can be cheaper in the long run and get you 32mpg. I would just hate to have you buy a 2015 with 75k miles and within the next 2 years your main electrical battery (costing $2,000 and up) goes out. Then your 12volt battery goes out. Then you have clogging in your EGR system.........etc. Most of us here bought ours new, and have done the necessary repairs within the first 5 to 7 years to make our Prius' last even longer. The used Prius on the dealer lot most likely has not had the same maintenance done. Otherwise, it wouldn't be on the dealer lot.
    To give you an idea of repairs on a Prius vs Yaris/Corolla, you and your wife can see where the spark plugs are on the Yaris and Corollas and if you had to, you could replace them easily. On the Prius? First, try to find them, then, you find out that you have to remove the windshield wiper assembly to get to them. This will cost you more labor at the local mechanic shop or dealer. Hopefully you can see why we all are pushing for you to just get a new Prius. In the long run, its a better investment.
  7. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Listen to the advice on here
    Get a corolla or civic
    Everything costs more to fix on the Prius
    Most mechanics cannot do things like bleed the brakes... so have to go to the dealer
    Also the things that do fail on a Prius are big ticket items...
    Just one big ticket failure and all that gas savings for the last few years is wiped out anyways
    All used cars have known issues
    Subaru blew head gaskets with one of the motors they used back in the early 2000’s
    It was a known issue
    Just like known issues with 3 rd gen Prius ...
    Hybrids are expensive to repair due to the tech involved
    Montgomery and Grit like this.
  8. Lovec1990
    Lovec1990 Junior Member
    74
    Slovenia(EU)
    So your advice is do not buy Gen3 for long term car?
  9. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Yes
    Personally
    I would get a Camry / corolla / Yaris
  10. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    To be clear
    I own a 2009 and a 2011
    In October 2017 my 2009 had it’s brake accumulator go
    it failed two months before the end of the extended warranty by Toyota
    the dealer replaced it for free but if it had failed to months later I would’ve been out of pocket $4500
    because of the technology involved it is not a thing I could have replaced on my own
    Recently I bought the 2011 and now I am finding that the brake accumulator or actuator is beginning to fail on it
    If you look at the reliability of a car but only look at the number of items that can fail and not the cost of the individual items
    you do not have a clear picture of the true cost of the vehicle down the road
    The problem with the Prius is that the things that fail are very expensive
    these are not wheel bearings and CV joints
    I’m getting rid of my 2011 and I will keep my 2009
    because I have handled the brake accumulator already
    and the second GEN’s do not tend to blow head gaskets or have any other big-ticket items go on them
    To replace the 2011 I am looking at a non-hybrid and something that has no big ticket issues
    Honda’s have some air conditioning problems so I’m probably sticking with Toyota for now
    Montgomery and bisco like this.
  11. Montgomery
    2,254
    2,241
    Orange County, CA
    Couldn't say it better Mattbatson. If one is buying a used car, hybrids are a bigger risk. If one is in the market for a used car, the Yaris and Corollas are a safe bet. Even if it fails, much cheaper to repair. You can change the water pump, alternator, brakes, spark plugs............its just better. By the way, in my house, I drive the Prius (I bought it new in 2015)while the wife, my son and my daughter drive the Yaris. Daughter's Yaris has nearly 200,000 miles on it and its been all up and down California! No major repairs to the Yaris's.
  12. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    Bisco,
    I just noticed you're in Boston. I'm on the Northshore. Is there a Prius mechanic you can recommend in our area? I'm trying to prepare for the first bridge I can't cross on my own.
    Thanks
  13. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    An older Prius doesn’t come with a terrible risk, but the specific risks do come with expensive consequences.
    A same-age Corolla has none of the same specific risks- cheaper ones instead. Also a lower purchase price, easier to find independent service and they give 80% of the same fuel economy. Right now, fuel is so cheap that the Prius’ fuel savings aren’t worth the risks. And fuel would have to go up by a lot to change this.
    Nothing wrong with wanting a Prius for its other qualities, but it isn’t the most frugal car you could own until your fuel costs are high.
    Montgomery and Michael Wood like this.
  14. Lovec1990
    74
    Slovenia(EU)
    @Leadfoot J. McCoalroller i do not know but some replies on this forum are writen so that any potential buyer of Gen 3 would think that gen3 should be avoided and only look at gen2 and gen4
  15. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    Well I’m not out to scare anyone into avoiding a given car. My comments should not be taken with such a specific filter- I don’t think those are significantly better or worse than the 2s or 4s or the c or the v.
    Philosophically, I believe hybrids are best for heavy usage while new, and are not as well suited for light usage spread over many years. A simpler car would do better in that role.
    Many people have gotten the idea that any hybrid will automatically save them money vs. other cars. I believe that is false, and it helps when people understand how a hybrid can save them money and also when it won’t.
    Ed Beaty likes this.
  16. Lovec1990
    74
    Slovenia(EU)
    true, but my post was not aimed at you. Not all of us is intrested in hybrid becouse of MPGs some are intrested in owning Prius becouse of its tech.
    Here gas costs 1,3€ per liter that would mean in your units 5,49USD per gallon
  17. bisco
    51,950
    i'm not trying to scare anyone, i would buy an older prius if i were in the market, but not before doing my due diligence, having a nest egg for emergency repairs, and finding a good hybrid mechanic if i couldn't diy.
  18. bisco
    51,950
    i'm in the metro west area, and i don't recall anyone here ever posting about a good hybrid mechanic unfortunately.
    i only drive newer cars and take it to the local gas station for oil changes.
    Michael Wood likes this.
  19. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    What is different about bleeding the brakes on a Prius compared with any other car?
    The issues I see reported most frequently are with the ICE (e.g., head gasket), so no more difficult to fix than any other car.
  20. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    The computer in the Prius is allowed to actuate the brakes for lots of reasons- stability control, traction control, diagnostic purposes etc. If you’ve bled brakes on regular cars, you know there are times during the bleed procedure when you can’t allow the brakes to be operated.
    So at a bare minimum you’ve got to have a way to inform the car that you are doing brake maintenance so it doesn’t rip a gusher.
    Further, because the car has a sophisticated valve body and pressure accumulator to enable this computer-assisted braking, that device needs to be bled free of air as well. You need to be in communication with the computer to cycle the valves at the appropriate moments to get air through and out.
    Montgomery likes this.
