Advice Needed! P0401, P0300, P0301, P0303 Head Gasket and/or EGR?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ALTEREG0, Aug 19, 2024.
  1. Mendel Leisk
    42,053
    With the two cleanings I’ve done, I’ve used powdered Oxi-Clean (mildly caustic laundry additive). For next time, if and when, I’m likely going to this, both for expedience and to satisfy my curiosity:
    To one cup water, say in a pint canning jar, add roughly one heaping tablespoon lye crystals. Stir till largely dissolved. Pour into top opening of EGR cooler (bottom opening stoppered).
    Prop up securely, leave about an hour, pour out (down drain), flush well with more water, inspect, and repeat as needed.
    Note:
    Lye is strongly caustic. You don’t want it on your skin, and it will react with aluminum, non-stainless steel, and carbon. Read up on it; use safe practice.
    It’s also somewhat hard to come by now. Amazon.ca still has it; not sure about Amazon in the States.
    I would only use lye on the EGR cooler. It will react with the aluminum of the EGR valve, and the metal embeds in the intake manifold. The EGR tube between the EGR valve and intake manifold looks to be stainless steel, but it’s relatively trivial to clean with rags/brushes and brake cleaner.
    #41 Mendel Leisk, Aug 31, 2024
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,679
    6,707
    Texas Hill Country
    A perfect example of a completely clogged totally gummed up cooler that probably should have coded. Typically from an engine that burns oil. The wire method works but the timely repair is to have another one ready to go like you tried to do.
    People who clean coolers preemptively don’t really need to do it. But it gives them something to do.
    However I would bet my lunch money all this time and expense to date will give you false hope when installed for a maximum of three weeks. Then it’s back to the heart of the problem, oil consumption and a bad head gasket.
    #42 rjparker, Aug 31, 2024
  3. Mendel Leisk
    42,053
    Besides flow, reduced cooling ability may be detrimental.
  4. ALTEREG0
    ALTEREG0 Junior Member
    50
    Arizona
    @ASRDogman Thanks! My friend who is an old school kind of guy came to help me today. After I explained all the advice/knowledge I gained from the chat and what I had already done to the cooler, he suggested to soak the EGR cooler in gasoline overnight and then pressure wash it in the morning. We borrowed a dewalt gas pressure washer from a friend and gave both EGR coolers a go with the pressure washer. The replacement cooler which I have been cleaning for a couple days and was in worst shape (completely clogged, zero light) ended up pretty good, the original EGR cooler which we just removed today and was in better shape (about 4-6 open channels) right out of the car stayed about the same. So we are trying his method now and both EGR coolers are filled with gas and will soak overnight, I’m pretty sure the replacement part will be ready tomorrow after the gas bath, pressure washing it and letting it enjoy a few 30 minute sessions on the ultrasonic spa!
    @rjparker I’m afraid you are right. What will be a definite sign of a bad head gasket?
    I checked the spark plugs and they seem to be fine (I’ll take a picture when I work on the car again). I’m strongly leaning towards faulty (not torqued and/or not gapped correctly) spark plugs as the main cause of my car trouble.
    Oil level and coolant level has been stable before/after the incident. No shaking after replacing the bad spark plugs (none before the incident either).
    To my surprise, the intake manifold openings were not clogged at all. Quite dirty as expected but not clogged (pictures below). The EGR valve was very dirty but surprisingly easier to open than the replacement valve I bought (before cleaning it). The EGR cooler was very bad but not completely clogged (exactly how you mentioned about a completely clogged system throwing codes).
    The original PVC valve rattled about the same as the new one I installed, not sure it was bad but since I had purchased a new one…
    Throttle seemed clean, a layer of oil (not quite a puddle) under the throttle at the bottom of the intake.
    Anything else I should look at while everything is out? (My friend said we might as well had replaced the engine, we were 1/3 there! )
    The fun part is going to be putting everything back together (specially remembering which nut and bolt goes where and finding them!)
    If I only gain a couple of weeks before the head gasket gives up the ghost it will be worth it. I’m really hoping more than a few weeks but only time will tell…
    Thank you everyone again for your help and patience!
    IMG_1235.jpeg IMG_1236.jpeg IMG_1239.jpeg IMG_1240.jpeg IMG_1241.jpeg IMG_1242.jpeg IMG_1243.jpeg IMG_1244.jpeg
    #44 ALTEREG0, Aug 31, 2024
  5. ALTEREG0
    50
    Arizona
    Oh I forgot to mention! This morning after soaking the EGR cooler overnight in oven cleaner and rinsing it, I only saw one passage open so I decided to ask a radiator shop how much they will charge me to clean it. I thought they would have a bath of secret sauce (acid, actually) where they soak the radiators for a few minutes and the emerge as clean as when they were new!
    The first shop seemed more established and nicer, the gentlemen there asked to see the part, asked what it was (didn't seem very familiar with it) and told me that I was better off buying a new part.
    I went to a nearby shop, more of low key kind of place and I caught the professionals eating lunch. The owner asked me what I needed and when I explained it to him he informed me that he need it to see the part to know exactly what he needed to do and give me a quote. I brought in the part and he pronounced a number at the same time as he was chewing/sallowing a carnita's taco so what I heard was "$10 dollars" so I repeated to him what I heard just to make sure and he promptly replied in a loud, clear voice "No, a hundred dollars!" which really surprised me and before I could plan a calm and moderate response I replied in disbelief "100 dollars?!!!" to which he quickly replied "well, I need to submerge the part in acid and clean it really good". Learning from my previous mistake I followed up his explanation in a calm, interested tone "Oh I see, yes that seems to be a complicated process. Wouldn't acid damage the part since is aluminum?". Now he seemed to be the one caught of guard and explained that the liquid was "something like acid, but not acid"
    So... I came home and poured more oven cleaner in the cooler while I removed the other parts from the car...
    #45 ALTEREG0, Aug 31, 2024
  6. ChapmanF
    18,717
    I don't think the cooler is aluminum, though the valve body is.
  7. ALTEREG0
    50
    Arizona
    @ChapmanF that makes sense! Somehow I was thinking EGR Cooler = small radiator = aluminum :/
  8. ASRDogman
    ASRDogman Senior Member
    7,899
    4,018
    Using gasoline, and that much, is extremely dangerous!
    Get some easy off SPRAY oven cleaner.... Just keep spraying it in after the foam settles.
    Yes, it will take a few times because it's clogged, layers and layers..... But it's safer.
    Just wear gloves. Even just plain soaking for months will work.
    The first time I did mine it was clogged bad. It took a few times with the oven cleaner.
    I had not thought of using the pressure washer. Someone mentioned it here. MUCH faster!
    Dawn dish washing fluid works too. It all depends on how long you want to wait and how
    work you want to do.
    Get the cleanest one cleared first so you can get the car back together. Then you have 50,000 miles
    or so to clean the other one. Gunk, the flamable one, is mostly kerocine, would be a lot safer than gas.
    And you can let it soak for several days.
    Spraying out the water passage isn't needed, but doesn't hurt. Good luck!
  9. ALTEREG0
    50
    Arizona
    @ASRDogman didn’t think about safety much, good point. The gas didn’t do much to remove the carbon build up but just the smell gave me a head ache for two days, live and learn.
    The replacement EGR Cooler is looking pretty good. Soaked it for 1 hour in oven cleaner, power washed it and I’m going to give it two 30 minute sessions on the ultrasonic cleaner, power wash it again and see if it looks good enough.
    I’m amazed how much the ultrasonic cleaner actually helps.
    Thanks for wishing me luck I desperately need all the luck I can get ☺️
    ASRDogman likes this.
  10. ALTEREG0
    50
    Arizona
    Alrighty then, clean(er) EGR System is back in the car with new intake manifold gaskets and new PVC valve. Got a good scare at start up, it sounded like the engine had gone south, got a "Check Hybrid System" error, CEL errors, it ran rough... I thought "all this work for nothing!". I guess the computer/sensors were just adjusting, not sure about the hybrid system error, maybe because the car was not started for 3 days the battery got completely discharged or something?
    Anyways, we triple checked everything and all seemed good, drove the car a little longer and it started to run better. Hybrid system error went away and my friend deleted the rest of the CEL errors and they have not come back...yet.
    The clean EGR system did not make a noticeable difference in the way the car drives, I know it was still needed so I'm glad it is done. Now I have to deal with the possible head gasket issue, it's been a little over 1 week since I replaced the spark plugs, oil and coolant level remain stable... more to come!
  11. Mendel Leisk
    42,053
    Yeah I wouldn't expect it to. It doesn't effect performance or mpg, AFAIK. You've restored a system that was intended to allow the engine to run leaner (something like that, the prof. may be along shortly to explain my errors), a system I think the engineers are relying on.
  12. ChapmanF
    18,717
    It reduces the amount of oxides of nitrogen in the exhaust, and also improves MPG. At least, those are the reasons they use it. That isn't a guarantee that, in your particular driving, you're going to notice an MPG difference after changing the system from less clean to more clean.
    Re: lean/rich, a stoichiometric mixture is 14.7:1 air:gasoline, lean is more than 14.7 g air per g gasoline, rich is less than 14.7 g air per g gasoline.
    EGR lets you keep a stoichiometric, neither lean nor rich, mixture, and just have less of it in the cylinder, filling the rest of the space with exhaust, which is neither gasoline nor air.
    #52 ChapmanF, Sep 2, 2024
  13. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Injecting warm air into the engine during the cold season will reduce fuel consumption.
    Of course, the car's power will also decrease slightly, so don't be fooled, miracles do not happen often.
  14. ChapmanF
    18,717
    The majority of your driving time is spent not needing maximum power from the engine, so some way to make the power decrease is needed.
    Without EGR, most of the power reduction is done by closing the throttle valve, but that turns the engine partly into a vacuum pump, doing work to pump air across the throttle. Allowing some EGR into the intake achieves the same decrease in engine power with not so much pumping loss. No miracle, just engineering.
  15. ALTEREG0
    50
    Arizona
    Thanks for the explanations!
    How long should I give the car to show conclusive symptoms of a bad head gasket?
    I ask because there are two more concerns with the car I would like to address if the head gasket is ok (if not, I might just cut my losses).
    * Aging traction battery
    * Noise at start up when pressing the break pedal (ABS or brake booster issues?)
    Should I start a different thread for those issues, should I comment on an existing thread or should I keep going here on this thread?
  16. Mendel Leisk
    42,053
    Same thread probably best.
    ALTEREG0 likes this.
  17. ALTEREG0
    50
    Arizona
    IMG_1274.png IMG_1275.png IMG_1276.png IMG_1277.png Here we go… again!
    Traction battery:
    The tricky part is that I still don’t know if the head gasket needs replacing but I guess I better research the options now in the unlikely scenario that the head gasket is still fine.
    180K miles, no issues until the trip (beginning of the post).
    The only sign I can attribute to a degrading battery is the poor mileage I’m getting.
    * Should I pay $400-500 (plus $50? each bad cell they need to replace) to have a local shop “recondition” the battery?
    * Should I pay for a “refurbished” battery with all good battery packs? $800-$950 3 month warranty
    * Should I buy a new battery (LiFePo4 $1,300, OEM $1,500-$1,800?, sodium-ion battery $1,800-$2,000 if available)?
    Here are the levels I’m seeing (not that I know what they mean )
  18. ALTEREG0
    50
    Arizona
    Brakes issue(s):
    I have recently replaced the break pads and replaced the front shocks (not sure if that has anything to do with the issue but… just in case)
    Notice a noise when pressing the break to start the car. Not sure if is the ABS module, the master cylinder or both.
    If I have to replace the head gasket (will replace the engine instead), replace the traction battery and replace both the ABS and Break master cylinder it just won’t make sense financially.
    * Will bleeding the break system help)
    (I bought an Autel AP2500 scanner because I thought it would let me 1.- program a new key fob, 2.- bleed the breaks and 3.- program new TPMS sensors but it only has access to TPMS and even then it wouldn’t connect, I’m returning it and exchanging it for something else).
    This is my wife’s (kids) daily driver, other than the noise at start up the breaks work fine but it makes me nervous.
  19. ALTEREG0
    50
    Arizona
  20. rjparker
    10,679
    6,707
    Texas Hill Country
    The brake booster almost always runs as you get in the car for the first time each day. That is normal. Problems start when it runs every 15-30 seconds regardless if you are just sitting there or driving. Usually it’s hard to hear it when driving. However the brake booster will code and produce several warning lights when it has had enough. Some get a year or more after hearing frequent brake booster running noises (other than the normal startup pressure build).
    Hv battery codes? Did not see them from your app screenshots. If it is coding it would be best to do something but people rarely get stranded suddenly due to a weak hv battery. Symptoms like quick loss of charge at a stoplight and bad mpg are typical.
    If it is bad I recommend new OEM cells which will last another fourteen years and will restore mpg and pep. The aftermarket new cells are really a risk from a lifespan view and even a short term reliability standpoint. A budget option is a rebuilt mic and match used battery with a very good warranty. With this option you are likely to need warranty often and some sellers have been known to ghost customers.
