Advice on AC issue
Discussion in 'Gen 3 Prius Main Forum' started by Grifftibbs, Aug 2, 2024.
  1. Grifftibbs
    Grifftibbs New Member
    MA
    I recently got a used 2011 Prius. The AC wasn't getting cold enough, so I used a can of refrigerant to recharge the AC. The air is plenty cool now, but there is a kind of crystalized sloshing noise coming from the passenger side when I'm taking left hand turns.
    Should I ignore it? Address it myself? Bring it to a mechanic?
  2. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    EVAP box isn't draining completely need to probably clean the coil the evaporator coil and pull a small rod through the drain hose to clear any obstructions might have to do it a few times
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    Remove the cabin filter and carefully inspect for leafs or nesting materials. Toyota has a foam cleaning product that is injected at the bottom of the passenger side condensate drain hose.
