Advice on Changing Brakes and Serpentine belt
Discussion in 'Gen 2 Prius Main Forum' started by Joe Wall, Jul 3, 2020.
  1. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
  2. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
  3. Mendel Leisk
    41,479
    Are you going to DIY?
  4. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    Yes with my dad who is experienced fixing cars
  5. Mendel Leisk
    41,479
    Ok. Follow the post #14 tips about disconnecting the 12 volt neg cable before commencing, and pumping brake pedal when everything's back together, before reconnecting the 12 volt. Two reasons for this:
    1. If you have the battery connected, and open the driver's door with caliper off the rotor, the system will try to pressurize (as likely as not), and this could pop the piston out.
    2. You do the pedal pushes to take up excess pedal travel. If you don't do this, at next start up the car may detect excess pedal travel, throw a code.
    Some info in the attached, torque values.
    One more thing, not sure if second gen has plastic caliper piston. Third gen does, and you want to be careful to provide even/uniform pressure to it's rim, to avoid stress fracture.
    Also, I'd be inclined to NOT open bleed bolt when pushing the piston back in. Some like to do this, but the Prius is very finicky about brake fluid bleeding. Second gen only has instruction for doing this with Techstream.
    SFO and ydpplqbd like this.
  6. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    Dealer said they replace shims too.
    #26 Joe Wall, Jul 6, 2020
  7. Mendel Leisk
    41,479
    Dealer? It's not a bad idea, if they're really old they'll be getting pretty rusty. There's also end clips, the little bendy tangs at the two ends of the pads, that push into the caliper mounting bracket. I believe all these items are shown in my previous Amayama link (post #14).
    FWIW I've never bothered to replace the latter, on any car we've had. They almost seem to be stainless steel. Pad shim sets are about $20. With previous car's I'd sometimes replace them, sometimes not. Some manufacturers include replacement shims as a matter of course, I think Honda does now. They didn't in past, which is why I wouldn't always replace them.
    If you've got a second vehicle, maybe just take everything apart and then make a decision, pick up shims if warranted, at dealership.
    My 2 cents: I always buy genuine parts, from local dealership. With something I do so infrequently, I don't want to gamble on aftermarket parts, and have to deal with return shipping if there's any problems.
    #27 Mendel Leisk, Jul 6, 2020
    ydpplqbd likes this.
