Advice on Full Suspension Replacement & Upgrade for 2011 Prius
Discussion in 'Gen 3 Prius Technical Discussion' started by BrianStranded, Oct 8, 2023.
  1. BrianStranded
    BrianStranded Member
    118
    84
    New Orleans, LA
    I've been experiencing a rough ride with my 2011 Prius, likely due to wear on the suspension components. I'm keen on replacing and potentially upgrading the ENTIRE suspension. From my research, the list of components I've identified for potential replacement includes:
    Front Suspension:
    • Struts (assembly)
    • Strut mounts/bearings
    • Control arms and associated bushings
    • Ball joints
    • Stabilizer bar, links, and bushings
    Rear Suspension:
    • Shock absorbers
    • Coil springs
    • Trailing arms and bushings
    • Stabilizer components
    I'm also considering upgrading with performance coilovers and adding braces like a strut tower brace and underbody sway bars for enhanced rigidity.
    Could any of you share insights or recommendations on specific brands or kits that have worked well for you? Also, am I missing any essential components in my list? Costs? Is this a DIY-able thing?
    Thank you for your time and expertise!
  2. Tombukt2
    Tombukt2 Senior Member
    13,819
    2,505
    Durham NC
    I don't know do the strut tower brace makers cover this car for some reason I'm thinking not could possibly have front and rear strut tower braces coilovers are doable they're basically the same as a Corolla with wider spacing between the ears that go on the aluminum front and well whatever hub assemblies The Corolla units won't fit on the Prius just because of that everything else is basically the same even the top plate I have a set of coilovers here for an AE 111 and they will essentially bolt up to an '08 generation 2 I just need more space between the ears to offer up the front hub. I don't think our front ends are too sloppy as it is as far as rigidity goes. I don't think Toyota built these cars for auto crossing or seriously spirited driving of course you can throw a little money at that problem.
  3. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    I replaced my shocks for the first time in 2019 with KYB shocks and struts at independent mechanics shop. They haven’t worn out yet but I did have to replace wheel bearings, front sway bars and bushings. Based on older threads here and videos, the consensus is to avoid munroe(Monroe?) shocks.
  4. BrianStranded
    118
    84
    New Orleans, LA
    Thanks, was there a noticeable difference after the change? My car squeaks and rolls right now, 196k miles on original suspension. I’d love to liven it up.
  5. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    I didn’t notice much of diff. Priuses are usually louder and rougher than other cars.
  6. Jstampfl
    Jstampfl Junior Member
    25
    Mongolia
    2018 Aqua
    I
    I installed CEIKA coilovers and new rear springs sand shocks. Lots of customization option when ordering. Shocks and struts are adjustable for height ( I orfered the lift option). Also the shocks are adjustable. I am very happy with the ride and control
    Tombukt2 likes this.
  7. Jstampfl
    25
    Mongolia
    2018 Aqua
    I
  8. Tombukt2
    13,819
    2,505
    Durham NC
    Cost? The Corolla AE11 coilovers that are all over the web for I don't know what it is $320 for a set of four they're orange they'll fit bolt up to the Prius in it right and everything looks correct The ears on the bottom for the hub to go in are made for the iron hub assembly not the thick aluminum. I'm sure they make a set that will bolt up to the later aluminum hub faces I just haven't looked I could mill my hub faces down I don't know 40,000s and they'd probably fit in the slot
  9. Tombukt2
    13,819
    2,505
    Durham NC
    Look at what the old guy like me did hear somewhere in this mess using matrix and a few other Toyota pieces in springs The vibe Pontiacs the same and he wound up with a lifted car with stiffer springs all from the Toyota parts books if you will didn't have to merge the coilovers or any of that of course I don't think he was looking for that kind of adjustability which can sometimes turn into a nightmare for some people I personally don't want to be sitting out in the driveway adjusting spring rates and shock rebound and compression rates and so on and so forth at least not anymore.
