Advice on getting hybrid battery life checked out
Discussion in 'Gen 3 Prius Main Forum' started by HavingRegrets24, Jan 5, 2022.
  1. HavingRegrets24
    HavingRegrets24 New Member
    Southern California Inland Empire
    Purchased a 2014 Prius last year and it currently has 80k miles. Car was owned my parents previously who took excellent care of it. Since I've had it I've had to try get to get 40 MPG in it. I used to have a 2010 that I could get in the 42 to 44 range without trying. Starting to think that maybe the hybrid battery is on its way out. I downloaded the Dr Prius App bought the battery test. It failed the first time Load Testing bottom voltage: warning! Suspected problem block 3, 4. Did the life expectancy test did not finish however. Did the battery test two more times and each time no issues. Wondering if I should take to a dealer to get it tested to know for sure or is the Dr Prius app trust worthy?
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    When our 2011 Gen-3 first reached 100K miles, I was very worried about how long to hold onto these Prii.
    I spoke with our nearest Toyota Service Manager. He insisted that when the vehicle sets a diagnostic code that is the first indication that there is an issue. Until it sets a diagnostic code there is no way to guess at the health of the battery.
    Even as it is failing, unless it sets a diagnostic code there is nothing the dealership can do.
    52,805
    that was just a glitch, the battery is fine. no computer is perfect. i would go about my business and sleep well.
    now, if you want to talk about the egr circuit, i'm all ears...
