Advice on new tires
Discussion in 'Gen 3 Prius Main Forum' started by Texida, Sep 10, 2015.
Tags:
  1. Texida
    Texida Junior Member
    I'm approaching 40,000 miles on my 2013 Prius and my husband tells me I am going to need new tires soon (I still have my factory tires.) I live in Texas, where it doesn't snow and only rarely would I drive on ice. I have checked out Consumer Reports but am also looking for recommendations from my fellow Prius owners.
    Daddyjeph likes this.
  2. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    In my opinion, you can't go wrong with a Michelin energy savers all season. That's one of the first things I did with my 2013 when I got it about 3 months ago. Great tire, & I do consistently get my 50 plus miles per gallon. And yes, you can still get them. I've noticed a lot of tire shops won't actually have them in stock, but it's just a matter of getting them ordered from the warehouse , usually just takes a few days. I got a set of 4 installed balance with lifetime balance and rotation for around $530 if I remember. You can go cheaper, but at least in my case I plan to keep the car a long time so I figured I'd get the best tires.
    Texida likes this.
  3. Mendel Leisk
    42,306
    As an alternative: Bridgestone EP20. Cheapish, LRR, readily available. They get a little noisy as the tread gets low, but otherwise a decent tire. They ONLY come in 195/65R15, are used as OEM tire by Toyota. You might actually have them now, lol.
    Texida likes this.
  4. Texida
    Thanks so much for the advice! Both sound like good options.
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    I am hesitant to say much about tires. Tire experience is a very individual thing. Tire performance varies with driving style, roadway, weather, maintenance ... so many things. You also might want to check out another source for tire opinions that I found useful. Look up all the various brands for your Prius on Tire Rack and other sites, and read the reviews. I have posted before about the tires I use. Goodyear Assurance ComforTred Touring filled 42 front 40 rear and rotated every 6K. Good warranty to 80K. I drove a set down to 4/32" on my Gen II at 80,002 miles. Working on another set on my Gen III now that are probably close to 30K. Others report mid-life road noise, and this probably is characteristic of most tires. These tires have a shock absorbing layer in the belts and start out very quiet. If there is an increase in noise over time it is gradual. As always, YMMV.
    Texida likes this.
  6. Patrick Wong
    18,210
    6,517
    One possibility would be for you to buy the tires that this guy wants to sell:
    Replace tires on brand new Prius? | PriusChat
    AzWxGuy likes this.
  7. solrunner
    solrunner Member
    114
    37
    Reston, VA
    I have read the ComforTred have high rolling resistance. What king of MPG are you getting on them? Do they ride nice and comfortable?
  8. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    Unless something unknown and amazing comes to market before I buy tires I'll go with the Continental TrueContact. I've got the OE Bridgestone EP20's now and they are an ok tire but I want to go with the Continentals. I'm the guy in the thread mentioned above. I might be selling a set that has only a couple hundred miles on them.
  9. Mendel Leisk
    42,306
    Geesh I just don't get this aversion to EP20, lol. TireRack opinion has a herd mentality, I'll just keep buying them EP20's, slapping them on our ex-Civic. :whistle:
  10. LDB
    LDB Member
    279
    71
    I'm not against them. I'm just not for them, especially if I was buying them as replacements. I'd rather have the Continentals for $80 than the Bridgestones for $90.
  11. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    In the 15" wheel size, it would be hard to go wrong with the Continental TrueContact. Continental builds a very good quality tire. Initially you'll probably see a drop in MPG, but as the tire breaks in, the MPGs should head back up. Takes a tire a few miles to "break in"... anywhere from 500 to 1000 miles. All tires tend to get a little noisier as they wear down. Some are noisier than others during the process of wearing.
    I've driven friend's Prius with Continental ProContacts and Continental PureContacts. The ProContact was a quieter tire than the Pure, but the Pure was rated better overall. I would rate the PureContact a noisy tire on a Prius. The TrueContact is rated better than both of those tires in all areas.
    Texida and Daddyjeph like this.
  12. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    Nice and quiet. Or as quiet as you can get in a Prius at 78 mph. I have a 140 mile commute every day, and I get about 49 on the way down and 53 on the way back. Eyeball averages. There is a 2200 foot elevation gain.
  13. LDB
    LDB Member
    279
    71
    Uphill both ways. In the snow. Oh, sorry, channeling my grandfather for a moment. :)
    AzWxGuy likes this.
  14. DukeDynasty
    DukeDynasty Junior Member
    Atlanta, GA
    I would suggest getting the Michelin Premier A/S they are an excellent rated tire and keep high wet traction even when the tire wears.
    Xterra72, Daddyjeph and djasonw like this.
  15. graham hendren
    graham hendren Geeman .. taximan
    82
    NOTTINGHAM ENGLAND. UNITED KINGDOM
    the best tyres I have found is hankook k115. B rated fuel B rated wet and they are very good in the snow. Im a taxi driver doing a lot of miles and they are giving very good mpg . £80 a tyre fitted
  16. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    I agree with Duke. I bought the Michelin Premier tires and their grip is incredible. It's a very quiet riding tire and the wet traction is fantastic. I bought these for my 2004 Prius. When my 2013 needs tires I'm going to get the same tire. A little expensive but worth it.
    Xterra72 and DukeDynasty like this.
  17. Roger T
    Roger T Member
    198
    48
    MA
    EP20 are kinda noisy compared to OEM Yokohama Avid S33 in my cousin's Prius.
    Do you know what tires are the quietest?
  18. Mendel Leisk
    42,306
    Sorry no. One thing, it's hard to get good opinion, because pretty much every new tire is quieter, so you'll get really scattered opinion. Check on TireRack, don't they have a category for quiet ride?
  19. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    My opinion is to get whatever Costco is selling, except, don't get the real expensive stuff. Middle of the road, etc.
    Mike
  20. djasonw
    962
    123
    Coconut Creek, FL
    Don't ever cheap out on tires. There are some tires out there that have poor performance in wet conditions. That's why it's very important to get a tire with excellent adhesion in wet weather. You'll also want to make sure it has ability to resist hydroplane. There are many tires out there to choose from. Refer to Tire Rack for customer ratings. I find those to be very accurate. Two highly rated tires are Michelin and Continental.
    Xterra72 likes this.
