Advice on possible AC condenser replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by splitter, Jun 11, 2026.
  1. splitter
    splitter Junior Member
    NY
    Hi everyone! Slowly working my way through my maintenance list - now onto the AC (it's 96 F here today...).
    When I bought my 2008 a couple of years ago, the AC worked fine for the first summer, then when the next summer rolled around it blew warm. I had a mechanic recharge the system and it worked for another summer.
    Well it's summer again and the AC is blowing warm again. I figure it's time to track down the leak.
    I had a peak under the hood at the various refrigerant lines. None of them looked black / dust caked / oily / wet, just shiny silver.
    I also had a peak at the condenser. Photos attached. The bottom left side looks dark / dust caked, like there has been a leak that has captured dirt. The line running into the bottom left is similarly dust caked, like something has leaked down onto it. The rest of the condenser looks silver / relatively clean.
    Am I crazy in thinking that the condenser is likely the cause of the leak? If so, it seems it is a relatively easy replacement, followed by vacuum + recharge by a mechanic? I believe there is little to no refrigerant in the system at the moment (B1423 code).
    I guess it would be conclusive to have a mechanic put dye in the system, but I was hoping to avoid paying for two recharges...
    Any advice / suggestions?
    If replacing the condenser first is the way to go, is there a recommended alternative to ND-11 oil? I see a few "hybrid compatible" oils available online now.
    #1 splitter, Jun 11, 2026
  2. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,520
    Durham NC
    Is this where my car I can charge w dye rt here . But looking at that I probably wouldn't waste my time it's an easy swap. usualky leak is inside EVAP box in car 3K repair . Many hours . Is less headache for me to change cars . I generally have a few . But the condensers a couple hours job you buy nice ones . Then I can gas it up right here in the driveway and see what I got. Or I can pull vac and wait . Personally I would just change that out new o-rings on all the fittings.
