Advice/opinions on touch up spray paint?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by mercat68, Jul 7, 2019.
  1. mercat68
    mercat68 Active Member
    311
    216
    Mount Airy, MD
    I caught a curb with the front right corner of the ground effects on my 2017 Prime (Blue Magnetism). Scuffed it up down to the bare plastic. It’s beyond fixing with the vial of touch-up paint and brush I bought from the dealer for chips. Searched online for Blue Magnetism in a spray can and came across TouchUpDirect.com, which sells a kits with a cleaner/degreaser, primer, paint, and clear coat for about $50. Anyone have experience with their products?
    Also, any guidance on process to paint a small patch would be appreciated. Assume I have to sand smooth with a progressively finer set of papers. And what about spraying? I remember reading once about spraying through a large hole cut in cardboard to feather the edges? Thanks.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Do you have a photo of the damaged area?
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I bought the 791 code paint pen and have used it once. Works well for a small area;).
    Pics of the damage:whistle:?
    Good luck and let us know how it turns out(y).
    mercat68 likes this.
  4. mercat68
    311
    216
    Mount Airy, MD
    Here you go:
    Raytheeagle and Mendel Leisk like this.
  5. Leadfoot J. McCoalroller
    8,138
    7,642
    Pennsylvania
    2018 Prius c
    mask what you can, do it indoors if at all possible- keeps bugs from landing in it. Have a means of dealing with overspray ready- that can be a rag with solvent, or yet another spray.
    Auto paint is 99% prep 1% squirt. Clean it, clean it again, degrease it, clean some more, sand it a little to promote adhesion, use primer (instead of color) to build height where it has gone down to the base. And be ready to polish it after.
    Raytheeagle, mercat68 and jb in NE like this.
  6. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Tape off the area about 1" away from the damaged area. Lots of tape and paper to protect the rest when you spray. Sand the area reasonably smooth, clean thoroughly and then spray the finish coat. It will leave a ridge at the tape line. After the paint dries, remove the tape and wet sand the ridge line. This is all plastic, so no metal prep or primer is needed.
  7. mercat68
    311
    216
    Mount Airy, MD
    Thanks - good advice.
    Thanks!
    #7 mercat68, Jul 7, 2019
  8. Leadfoot J. McCoalroller
    8,138
    7,642
    Pennsylvania
    2018 Prius c
    As far as sanding I'd probably do 800 for the initial rough up to create traction for new paint. JB is correct you don't need primer for corrosion, but you may need it to match thickness and it usually helps with adhesion for the color layer. Can also be helpful if the base color is still showing after a few coats of color.
    After the color I'd wetsand it at 2000.
    The donut-hole spray method has its advantages- in this situation I would only do that for the clearcoat, and then only on a larger aperture mask after removing the damage-area-only mask post-color.
  9. mercat68
    311
    216
    Mount Airy, MD
    You anticipated my next question: sandpaper grits. Thanks!
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    It looks like the scratched area is pretty rough. I would flatten it with 400 wet. Then smooth with the 800, etc.
  11. mercat68
    311
    216
    Mount Airy, MD
    Yeah, it’s pretty rough. Thanks.
  12. Mendel Leisk
    41,880
    I'll put on my flame suit and say body shop. If you want it to be seamless.
  13. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    It’s a lower plastic piece. Even if it’s not perfect it won’t be very visible. And if the OP decides it is not an acceptable look, then the bodyshop can always fix it.
    #13 jb in NE, Jul 7, 2019
  14. mercat68
    311
    216
    Mount Airy, MD
    Yeah, bingo. Appreciate the thought, @Mendel Leisk, but given the location, I’m not willing to spend what seamless would cost.
  15. Mendel Leisk
    41,880
    True, the lower it is, the less noticeable. And, if a body shop does it, pretty much guarantees you'll scrape it again, lol.
  16. NSXT
    NSXT Active Member
    137
    119
    Toronto, Canada
    2018 Prius Prime
    I would check with a body shop for a price to paint-brush plus UV light to blend it in.
    Many years ago, my wife backed in (back up camera didn't exist during those era), scratched the bumper color big time and created a screw pinch-in hole. Had the body shop to do a fix, I paid about $200 all inclusive. It was like brand new.
    If you can shop for DIY, check with body shop for cash deal, sometimes you get a very good decent job to a similar $$ for DIY. Make sure UV light is applied for the final touch (I think that is needed to make it shine for bumpers).
    I am no SME for car fix but what I am trying to say, if it costs so much to do DIY, I'd rather pay the same or a bit more to do it right and save my time. I can guarantee you if I DIY.. I will screw it big time and the result will not blend in.
    As Mendel said, it could happen again :rolleyes:
  17. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
  18. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    Did you actually DIY to fix that? How did it turn out?
  19. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    no, mine is still funky but the video is something I found checking for a solution to my minor injury/scratch after curbing my front shroud.
    All I did was use some touch up paint on mine.
