Advice Please: Buy JBL or save money for aftermarket audio?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Chris Lawes, Dec 28, 2013.
  1. Chris Lawes
    Chris Lawes New Member
    Atlanta, Georgia
    Hey folks,
    Would love some input from those of you in the know about the JBL audio on the Gen II's.
    First of all, how do you identify the JBL premium system? If it has the "JBL" letters on the front dash speakers does that definitely mean that it's the JBL upgraded sound?
    I'm in the market for a Gen II, spending about $10k, and a few cars have JBL premium audio and a few don't but are a bit less expensive. Question is, would you make it a point to buy a used one with JBL or would you just plan on doing a custom install of some aftermarket audio gear? Audio is important to me but not hugely important, I don't think I need anything beyond what a normal JBL system offers. I do get a discount at BestBuy GeekSquad installs though as I'm an employee.
    Thanks for your input!
    -Chris
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Yes the JBL logo would indicate it has the JBL system. But, the JBL option is not very good. I suggest you listen to a JBL system before you pay extra for it. If it's not important to you then I suggest you get a base Prius and save the money.
  3. vskid3
    vskid3 Active Member
    773
    228
    Yep, I've never heard anyone say JBL was worth it. A cheap headunit should make the base system sound at least as good JBL. Add a small sub and you'll blow it away.
  4. Chris Lawes
    Atlanta, Georgia
    Okay thanks that's the kinda feedback I was looking for. Are the JBL and standard systems equally easy to install a 3rd party sound system into?
    Also, is the Prius harder to add a new system to than a normal car because of the steering wheel audio stuff or something ?
    Turn off signatures in Tapatalk Tapatalk
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I have the JBL system and find it fine. It's not bad for a stock stereo.
    Agree.
    I'm personally against installing aftermarket stereos due to the increased risk of theft. I've personally had my former 91 Camry broken into for its aftermarket head unit. :( Lost a $300+ head unit + a CD wallet full of retail CDs (this is many years ago). I only got it because the stock stereo died. And, my insurance didn't cover a cent since I didn't have comprehensive.
    I ended up replacing the stereo and having to spend yet more $ on a car alarm.
    If there were no such thing as car stereo theft, sure, I'd splurge.
    As for harder? I do not know, but the stock stereo and JBL stereo have their controls split between physical controls and the touchscreen. And, some of them are duplicated on the steering wheel.
  6. vskid3
    773
    228
    The JBL has a separate amp, where the base powers the speakers directly from the headunit. So if you were planning on adding an amp anyway, the JBL might make it a bit easier. For me, the headunit alone is good enough, so base makes it an easier install.
    There is a harness required to keep the climate controls on the wheel working, you'll need a separate device to get the radio controls to work (varies depending on the brand of headunit you use). Here is a writeup of what I did to my car. Installed Pioneer AVH-P1400 and Bazooka Tube | PriusChat
    cwerdna likes this.
  7. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    very easy to install a better system in a base model if you are the least bit handy. oe speakers bite the bag, so you need to ditch those too. there are several good write ups on how to that you can find in this forum. also, if you don't want a sub box in the rear, you can get a 7" or 8" woofer in the rear doors with out too much hassle. i've installed a kenwood touch screen with the metra axxess and scosche harness and trim panel kit (all from ebay). with some decent 4 ohm speakers you can get a good sounding system going.
  8. Chris Lawes
    Atlanta, Georgia
    OK so just to confirm, I can buy a Gen II Prius without JBL and then spend $100-400 upgrading the audio system without losing the audio control on the steering wheel or screen and without making cosmetic changes like taping a subwoofer to my back luggage area? I don't necessarily care about the greatest sound but I would rather not put a whole new screen/radio in and change appearance / lose wheel function etc.
  9. vskid3
    773
    228
    You will lose the radio control on the MFD (stock touchscreen), but all other functions of the MFD will remain intact. I only used the radio controls on the MFD because there weren't really any on the radio, I greatly prefer the controls on the radio, especially with it already taking up that space.
    For me, swapping out the headunit would have been good enough. I installed the subwoofer because I already had it sitting around. I haven't replaced the speakers, but I'm sure they would make a big difference without changing the appearance. It you really want to maintain a stock appearance, you could do a stealth install of a single DIN radio in the cubby beneath the stock radio.
    The sky is really the limit. You can do just about anything and have it visible or not like an underseat sub vs sub in trunk. Pretty much the only thing you can't do is use the MFD to control an aftermarket radio (that I know of).
  10. Dino3721
    Dino3721 Junior Member
    16
    Omaha NE
    I agree- the JBL is ok but not impressive. I like all the features of the package 6- but the JBL system does not have much bass at lower volume. It has very clear high range. I am going to add a sub to make up for the JBL lack of bass. JBL is ok- just not great. The plain stereo would be so much easier to upgrade. My Prius had it installed but would love to just have a decent aftermarket install instead.
