Affect of 12v battery on SKS function
Discussion in 'Gen 2 Prius Technical Discussion' started by f18cmech, Aug 20, 2019.
  1. f18cmech
    f18cmech Junior Member
    52
    San Diego
    Ok, so my key fob unlocks the doors of the car like once a month if I’m lucky. Also, I changed the failing battery with a used one which probably isn’t that healthy either. So, will installing a fresh new 12 v bring my keyless entry back to life, I’m sure it is that because after charging the battery overnight the keyless lock unlock and Keyless starting was working as well. Thanks
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Only if the old one is weak or has bad connections.
    You have almost proved that......so I think it is worth the gamble, especially if it is over 4 years old (the battery that is).
    52,849
