After 250,000 miles (Update: now 293,000), should I just drive it 'til it drops?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priusyipee, Nov 15, 2015.
  1. Prodigyplace
    12,699
    11,841
    Central Virginia
    Their road salt may be worse than your salt air. The car is 5 years older than yours too.
    Priusyipee and Mendel Leisk like this.
  2. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    I'm in upstate NY :eek:
    m.wynn and Mendel Leisk like this.
  3. Priusyipee
    354
    269
    Upstate New York
    Unibody. Suspension not bad.
  4. Priusyipee
    354
    269
    Upstate New York
    The road salt is awful here and the car has never been garaged. It had a good run, though. It's a shame because mechanically, it runs great! :D
  5. Shane Burns
    Shane Burns Member
    94
    126
    SoCal
    By the tone of your recent post, I imagine that you are sad to give up your old reliable girl... Have you try taking to different inspection station to get second opinion? Or retire her for good?
    Priusyipee and Prodigyplace like this.
  6. Priusyipee
    354
    269
    Upstate New York
    It was a fleeting thought to have another inspection station look at the car but there is one section of the frame that is so rusted out, I would consider it a safety risk. It will be driven locally around town until the end of the month then we will part her out. I have a 2008 Prius as well so it's not a total loss as parts are (for the most part) interchangeable.
    Shane Burns likes this.
  7. Priusyipee
    354
    269
    Upstate New York
    Genius! You nailed it right on the head with those speed sensors! Finally got the chance to get a really good look at the car now that the weather has been clear for a few days and the ice and snow that had built up on the underbody melted away. I confirmed that the left rocker panel was severely rusted out . The rust traveled up the frame and compromises the safety of the vehicle if it were involved in a crash. Front wheel bearings are shot AGAIN, and using tech stream has pointed to both front speed sensors. I will be driving the car just here and there locally until the inspection expires on February 28th. I plan to part out the car or sell it whole if anyone wants it. All harnesses, electronics, etc. are in good working order.
    tpenny67 likes this.
  8. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    Thanks! But to be fair, I did say "pressure" sensor of some sort. Speeds sensors would be part of the ABS and traction control, and when they corroded on my old Chevy the ABS would kick in on dry pavement at low speeds, like when you're trying to park or stop at a stop sign before pulling into high speed traffic.
    Keep an eye on that brake fluid while you continue to drive. The same Chevy taught me what happens when a brake line rusts out! :eek:
    Priusyipee and Raytheeagle like this.
  9. Priusyipee
    354
    269
    Upstate New York
    It ain't over 'til it's over...
    I brought the '05 Prius to another NYS inspection station after a conversation with the owner this past Saturday (who was doing some exhaust work on my '03 Highlander). He had never seen a Prius too rusted out to pass and asked that we bring it in. Good news: I just found out that it WILL pass! :ROFLMAO:
    Now on to the codes and other repairs: I was right in that there is a slight leak and loss of piston travel in the right real wheel cylinder which will need replacing. The rear brakes and shoes will need replacement (this will be the second time in 319,000+ miles). The front wheel bearings are shot (no surprise and being replaced for the 4th time) and the lower control arms and struts need replacement (first time since owning the car).
    I lucked out yesterday in that opening my email, I found out that I had won $100 off a parts order at Conicelli Toyota! Parts are ordered and I am ready to go. I will be installing aftermarket preloaded struts to make my life easier...
    Once all this is done, the car will fly through inspection! It should only need an alignment at the shop. I am thrilled that this car (and the original hybrid battery) can work its way to 400,000 miles! Only 80,000 or so to go! :D
  10. Shane Burns
    Shane Burns Member
    94
    126
    SoCal
    Ahhh! This is good news! Love the Prius! They keep going and going! :ROFLMAO:
    Priusyipee likes this.
  11. Priusyipee
    354
    269
    Upstate New York
    Seven months ago I gave everyone an update so it's time to tell you all how the car has been performing. No news is good news. We are up to over 331,000 miles and the car runs and starts as it should. No problems at all. The rocker panels are beginning to rust out on both sides now and I may buy a new set of winter tires before the snow flies. No breakdowns and no repairs since February. My A/C is not blowing cold air. Last recharge was about 4 years ago but cooler weather is on the way so this is not a priority at the moment. Geez. I was hoping that this car would make it to 2015... Still amazes me every day...
  12. Shane Burns
    Shane Burns Member
    94
    126
    SoCal
    Great car!!! :D Have you thought about swapping the combination meter to the newer version so your odometer display properly? Not sure if it is worth $150 to you?
  13. Priusyipee
    354
    269
    Upstate New York
    Right now I don't have the time to tinker. The combination meter was replaced by the dealer a few years back. I track my miles with each fill up. No time right now for any more weekend projects - I have been prepping my property for a new house addition and have been working on cleaning up about a quarter of an acre of logs - after all the trees were taken down. The chainsaw and log splitter are getting quite the workout! I wonder if the car will last the winter. I guess time will tell. It has been an incredible journey!
    Amazing that you retired a 2010 with 352K miles! That's a lot of driving! Is that car still on the road? The Prius is an amazing car!
  14. Priusyipee
    354
    269
    Upstate New York
    341,000 miles and still going! No further repairs since last year. Is it common for these vehicles to reach this age (13 yrs. 3 mos.) With the original (never been touched) hybrid battery, CVT, and engine? Only engine work was a ice water pump a few years back and spark plugs at 150,000 mi.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    That's amazing to me. But then again, according to this, one of six Prius owners keep their new Prius for at least 15 years.
    Prius is the second most likely vehicle to be kept for 15 years | PriusChat
    Whether they had more or fewer repairs than you, I don't know. I did see a thread here recently about someone "complaining" that their '08 (iirc) finally needed its first "repair." A tail light bulb burned out. :D
    Prodigyplace and Priusyipee like this.
  16. Prodigyplace
    12,699
    11,841
    Central Virginia
    Here it is
    Oh No our Prius Broke! | PriusChat
    jerrymildred likes this.
  17. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I have been following this thread off and on, just wanted to add that my 08 Prius had 306,000 miles on it I bought it used roughly 3 years ago with 189,000 miles. Since then I have replaced the 12v for preventative maintenance reasons, I replaced the muffler, because it had holes. I recently replaced the rear wheel bearing because of speed sensor issues. Did a transmission drain and fill, noticed one of the seals was leaking. So probably CVT replacement is in my future. So kudos to Priusyippe for all your good deals with your Prius. All things considered I think I am doing alright. Oh and just the other day I replaced my blower motor fan, it was very noisy :)
  18. Mendel Leisk
    42,049
    You should be able to just replace the seal. Don't leave it to long, cus it's a pain to check level without dipstick.
  19. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Thank you for the info Mendel, my mechanic friend recommended the who assembly but I will definitely discuss that option with him. At first glance at the parts web site, Rock Auto, that I like to use I did not see the seals listed
  20. dolj
    dolj Senior Member
    8,604
    4,366
    Wellington, New Zealand
    Just use OEM, this is a specialised unit and you don't want to screw it up using 3rd party knock-offs. Shop around on online Toyota dealer websites to get the best price.
