After 3 Prii, I finally said good bye. (Not to PC though!)
Discussion in 'Gen 3 Prius Main Forum' started by Aaron Vitolins, Nov 13, 2017.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I agree that it still can depends on how the car was driven and cared for to a certain extent. I had a Prius V that didn't use any oil when I bought it, and I maintained it better than the manual ever even called for, using the highest quality synthetic motor oil I could buy, and also using a thicker weight. But eventually that car started burning oil. At 100,000 miles.
    And I believe the American roads with high-speed, heavy loads, a great variety as temperatures and terrain are also very hard on gasoline engines. Apparently the Prius is made to be babied and treated lightly if you don't want it to start burning oil and eventually have a head gasket failure down the road.
  2. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    My brother and his wife have a 2007 ford escape Hybrid, its way under maintained neither one of them knows anything about cars, and that car is subjected to steep curvy Mountain Road driving and long high-speed highway driving and has over 200000 miles and never uses a drop of oil.
    All the 4 second gen Prii in the family (now only two 2nd gens) all drink a fair amount of oil at 200,000 miles. Funny thing is..... The escape and 2nd gen Prius use the SAME oil weight...
  3. orenji
    orenji Senior Member
    5,887
    3,488
    Escape and Gen 2 Prius don't use 0W-20 weight oil. 200k miles is an old motor, it has served your family well. Also isn't the hybrid Escape a bigger motor? Like 2.5 liters. It does not have too work as hard as a 1.8 liter motor.
  4. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Exactly, it doesn't use 0w20 but Prii still use oil. Btw a 2nd insight usues a tiny 1.3 liter engine
  5. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    This is ridiculous. I dont want to make this thread 10 miles long, and you're not going to admit to anything other than too thin of oil.
    Have a nice day
  6. frodoz737
    frodoz737 Top Wrench
    4,699
    2,497
    33
    As a Mechanic...here's my "opinion" on the Toyota 1.8L in question...having 2 Gen III Pri and had a 2014 Corolla. Your opinions may vary.
    They are efficient engines. They both use 0W-20 oil "only" to maximize MPG. They are aluminum engines and have zero tolerance for low oil and overheat events. Most Prius owners think the these cars are bullet proof and do not require "normal" preventative maintenance. Most Prius owners don't check their oil level, tire pressure or anything for that matter.
    pilotgrrl, kc410, Tbkilb01 and 3 others like this.
  7. Bill32803
    Bill32803 Junior Member
    27
    Orlando Florida
    I think I read on Autoblog/Green that 2018 is last year for CMax. Being dropped for a more CUV look coming from Europe. Or did I have an LSD flashback from the 60's?
    Merkey and bisco like this.
  8. NotFromHere
    NotFromHere New Member
    Thank you for writing so throughly about the differences between the Prius and the C-Max. I’m on the verge of buying my first Prius (a 2014), but am coming from a 13 year relationship with a 2004 Ford Focus. When test driving the Prius, I had to adjust my seat way down to get the view “right” and still felt the visibility was .... cramped?
    The salesman asked me if I even considered a Ford hybrid, and the answer was “no, because gas mileage. And trunk space!” But now I’m reconsidering. Off to find a C-Max to test drive!
    Cheers!
    Merkey and Aaron Vitolins like this.
  9. bisco
    51,933
    the toyota salesman?
  10. bisco
    51,933
    i believe you are correct.
  11. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    They are already using an 0w-16 spec. in Japan and the new camry hybrid will too.
  12. NotFromHere
    No, a third-party seller.
  13. bisco
    51,933
    ah, that makes sense. all the best!(y)
  14. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Glad I could help! Yes test drive everything you can! The more the marrier I always say.
    If you don't drive a ton the gas savings Prius vs cmax aren't going to be huge, but the cmax will have more power and more features.
    Love Prii too, not trying to knock em, even though it may seem that way. Feel free to ask me anything about a Prius or a c-max! Best of luck to you
    Raytheeagle and NotFromHere like this.
  15. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    If the Cmax is the real deal, then my hats off to Ford. My problem is, I have had the worst luck with Ford cars. And I mean the worst! The worst dealerships, worst repairs (no matter where I took them), repeat issues after repairs that were to supposed to fix the original issue and the most expensive when it came to maintaining. It was always the "bells and whistles" that drew me back to buying their cars. So, because of that history, I cannot risk another Ford car. I know, I may need to "get over it", but I will let others enjoy the new fine Ford products, and I am glad Ford is producing such a wonderful car. But I have to ask myself this, why are they discontinuing such a great car? (Is it because they can't get you back in the show room within 3 years?
    Jnaom and Tande like this.
  16. orenji
    5,887
    3,488
    Yes, 0w-16 has been used for the past several years in Japan. This will be the weight to achieve even better MPG. But at what cost will it be to our ICE.
  17. fotomoto
    5,638
    3,813
    So. Texas
    Yup, lots of challenges to keeping ICE drivetrains viable in the future; no surprise manufactures are working hard on other systems.
  18. AMCJeepMJ
    AMCJeepMJ Member
    33
    29
    Central Oregon
    We nearly pulled the trigger on a '16 C-Max with 26k for$13k from a Hertz pre-owned lot before picking up the '15 CPO Prius Three from a Toyota lot. With that said, CPO '17 C-Maxes being pulled from Ford dealer loaner car fleets with only 4k-8k miles are in the $18k-$20k range.
    We found the Sync 3 to be unnecessarily complex and the trunk space affected due to the oddball battery placement. Otherwise the C-Max was a rock star and we really liked it.
  19. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    They drive fantastic, they have endless touque and very comfortable. More people would buy them if the general public knew they existed!
    m.wynn likes this.
  20. mrwhsprs
    mrwhsprs Junior Member
    17
    Pacific Northwest
    FYI: My wife and I own a 2006 Ford Escape Hybrid (the 2007 model year had the same drivetrain); it has a 2.3L I4 engine. The Owner's Guide recommends "Motorcraft SAE 5W-20 Premium Synthetic Blend Motor Oil". A 0W-20 should be fine in any situation where 5W-20 is appropriate, as at full operating temperature they would both both 20-weight oils.
    Aaron Vitolins likes this.
