After 3+ years, got the "low key battery" warning
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Gokhan, Jan 25, 2024.
  1. Gokhan
    Gokhan Senior Member
    4,619
    1,857
    Paramount CA
    "Low key battery" warning came up on the MID when I turned off the car after 3+ years of ownership.
    I looked up the instructions, and replaced the CR2032 lithium-metal coin cell with the same Panasonic cell; so, everything in the car is still OEM. ;)
    I put transparent tape on the tips of the small screwdrivers so that they wouldn't scratch the key. I had to use a smaller one to pry the cell off than the one I used for the prying the cover off.
    Replacing the key cell would have been easy, except that the holding plastic tabs are ridiculously hard and rigid. I was worried that they would break off if I followed the instructions in the manual and pried the battery off with a screwdriver, but they didn't; so, it was all good at the end.
    #1 Gokhan, Jan 25, 2024
    49,399
    I’ve had good luck with amazon batteries, 4-5 years
  3. Mr.Vanvandenburg
    1,028
    351
    2020 Prius Prime
    I see you explain again why you don’t want a battery monitor. A third user fob would have kept the originals pristine.
  4. Gokhan
    4,619
    1,857
    Paramount CA
    Never. You can get the Japanese-made OEM Panasonic lithium-metal coin cells for cheap on eBay.
  5. Gokhan
    4,619
    1,857
    Paramount CA
    My second key with the tag is in pristine, never-used condition. These days they give you only one key.
  6. bisco
    49,399
    i think you get two, eventually
    sylvaing likes this.
  7. bisco
    49,399
    in the 11+ years i had my pip, i only replaced the fob batteries once
    Gokhan likes this.
  8. Gokhan
    4,619
    1,857
    Paramount CA
    Yes, eventually and hopefully.
  9. Mr.Vanvandenburg
    1,028
    351
    2020 Prius Prime
    Is the second fob in the original little plastic bag as it comes with from Japan? Where do they get those dirt cheap Ebay “made in Japan” Panasonic batteries? They would have to pay way less.
    Thats terrible the gen 5 only gets one key. Im sure glad I got the 4 that gets two keys. Fobs.
  10. Gokhan
    4,619
    1,857
    Paramount CA
    Yep, it is still in its OEM Japanese plastic bag with a label with a Japanese letter.
    I got the 03/2031-expiration-date Panasonic CR2032 coin cells from eBay for about 50¢ a while back, but they seem to be going for about a buck at the moment. They are needed in a variety of devices.
    You know the PHEV-battery prismatic cells are also made by Panasonic, right?
  11. Mr.Vanvandenburg
    1,028
    351
    2020 Prius Prime
    Right, but do you know the 2032 aren’t imposters for 50 cents?
  12. Gokhan
    4,619
    1,857
    Paramount CA
    Nah, they look pretty real.
  13. Mr.Vanvandenburg
    1,028
    351
    2020 Prius Prime
    I have bought the same for years. I suppose they can look real. Something is true if we believe it. The new George Castanza world we live in. Or is it if we believe it, it’s true.
    I looked at the one I have left in the package with 2030 exp date. Panasonic made in Indonesia.
    #13 Mr.Vanvandenburg, Jan 26, 2024
  14. bisco
    49,399
    get one from a dealer for $10. just to be sure
    Gokhan likes this.
  15. Mr.Vanvandenburg
    1,028
    351
    2020 Prius Prime
    Autozone has one Eveready for $8.99 or $10 with tax. My daughter went there last week to get the fob battery replaced CR1632. Not an issue every few years.
    A retailer of substance buys the batteries from the manufacturer, chain of custody. Ebay is definitely a question mark. One needs to ask how they get things so cheap.
  16. Gokhan
    4,619
    1,857
    Paramount CA
    OEM “Industrial” Panasonic CR2032 that came with the car on the left, 39.7¢ eBay retail-packaged Panasonic CR2032 on the right.
    In my experience, there is little difference between industrial and retail cells if any. In fact, retail cells are probably of slightly higher quality if at all.
    #16 Gokhan, Jan 26, 2024
  17. Mr.Vanvandenburg
    1,028
    351
    2020 Prius Prime
    The letters in Panasonic are closer together on the one on the right, and all the stamping is thicker. The figures have differences, like the head and object are not spaced the same distance away from the body. Not that it proves anything. I saw online people showing how to test them.
    You say retail package. I bought injectors that were in perfect Toyota boxes and every detail on injectors was perfect, except the holes in the injection nozzle were not as cleanly made. I tested, all were under the ohm spec. Got money back. Seller disappeared after a while. There is a reason things can be sold for a small fraction of the regular price. How are they getting them, shipping them, and making a profit? Theft from stores may be one.
    #17 Mr.Vanvandenburg, Jan 26, 2024
  18. Gokhan
    4,619
    1,857
    Paramount CA
    Yeah, that's because they are different cells—industrial vs. retail. The word "Industrial" wouldn't fit if they used identical fonts.
    #18 Gokhan, Jan 26, 2024
  19. Mr.Vanvandenburg
    1,028
    351
    2020 Prius Prime
    Actually no, they have the same room, just the 3v is up higher on the one on the right. Not related to the differences, and the people are different. The letters and lines are all just fatter but take up the same space by being closer.
  20. Gokhan
    4,619
    1,857
    Paramount CA
    Well, in that case, follow @bisco's advice above.
