after 4 new plugs and an injector . . . .
Discussion in 'Gen 2 Prius Main Forum' started by lexidium, Oct 10, 2025 at 2:05 PM.
  1. lexidium
    lexidium Active Member
    294
    137
    manchester
    Had a slight misfire on cylinder one so fitted a new injector and changed the four plugs at the same time.
    Now it runs ok for a while and then rattles and wobbles when coming to a stop. It showed obd code P0420.
    If I switch it off and on again, it then runs fine for a while but then happens again.
    Any suggestions?
    Thanks guys
    51,597
    what does that code stand for?
    51,597
  4. BiomedO1
    BiomedO1 Senior Member
    3,204
    1,699
    SacTown, Ca
    what was the reasoning behind changing the injector? How did you determine it was an injector fault?
    did you troubleshoot the misfire and/or did you get a P0301?
    how did the plugs look when you pulled them out?
    how many miles/km on the clock?
    how much oil burn between oil changes and at what interval?
  5. lexidium
    294
    137
    manchester
    Yes. Had p301 so I changed the coils over and spark plug looked ok but fitted a new one anyway and misfire was still there.
    175,000 on the clock.
    oil is fine
  6. BiomedO1
    3,204
    1,699
    SacTown, Ca
    did you do a compression test or look at fuel trims before replacing the injector? Did you do all 4 or just one injector?
  7. Aegean
    Aegean Active Member
    456
    203
    Alexandria VA
    Do you think engine temperature, when car is warm or cold changes anything? Or when idles you have the issue and when driving with higher rpm is working fine?
