After 6 mos - Love 2012 Camry Hybrid - but HATE the tires
Discussion in 'Toyota Hybrids and EVs' started by sambb, Sep 1, 2012.
  1. sambb
    sambb New Member
    17
    I have >6000 miles, and love the camry hybrid. Coming from a BMW, I couldn't do the prius because it was so sloooow, but the camry has very good acceleration.
    The problem is the tires are terrible in the rain. It has bridgestone turanzas on it. Any suggestion fo a switch to something with more traction?
  2. alekska
    alekska Active Member
    435
    138
    Atl
    Falken Ziex 912 have been very reliable and had excellent traction for me (no winter in my state :)). Price is low from online sources, about 1/2 or less of similar size Micheline , but do not expect more than 30k miles out of them.
    - Alex
  3. Tideland Prius
    16,206
    For rain? Michelin HydroEdge.
  4. ukrbyk
    ukrbyk New Member
    well, for starters, it's not question of traction. It's question of having water film between tire and road removed for contact and, having tire properly inflated. If it's over inflated, it'll skid.
    From that on, you really have to make decision - what do you want? Sticky, good in rain( and I am not sure why you concern yourself with rain so much, as it rains for months here, and I do fine on regular tires), but high friction and low mpg tires? Or less rolling resistance, maybe less stable in rain, but better mpg ones? It's your call.
    And what exactly is the issue? It takes quite high speeds to skid or hydroplane modern tires? Maybe it's operator fault, esp for someone coming from BMW driving style? As it'll cost you lotsa mullah to do tires switcharoo.
  5. sambb
    sambb New Member
    17
    I want traction. COuld care less about MPG, MPG is of no use if I get into an accident! I want safety first - better wet and ice traction. These turanzas are terrible. Worse than my minivan as well!
    xpcman likes this.
  6. habu968
    habu968 Junior Member
    Agreed. The stock Bridgestones are junk! 18k on mine. Can't wait for them to wear out!
  7. bisco
    49,796
    ours went wobbly and had to be replaced at 20,000.
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The new top wet traction LRR tires are:
    Continental ProContact with EcoPlus
    Continental PureContact with EcoPlus
    Michelin Primacy MXM4
  9. CPSDarren
    CPSDarren CPS Technician
    533
    112
    Chicago
    Toyota uses some of the crappiest OEM tires on its hybrids. We went with the Continental ProContact Ecoplus on the Prius and the Michelin Latitude Tour on the Highlander Hybrid. I have the perception that wet and dry traction and handling is improved for both, but not much difference in noise, ride quality or fuel economy. Not enough experience with snow/ice yet to judge.
  10. acdii
    acdii Active Member
    1,124
    131
    My biggest beef with the Prius when we had it was the lousy traction with the OEM tires. But back then in 2007, there weren't many choices on LRR tires or in the size that was on the car, and when you consider having to replace tires on a new car, well, just didn't make fiscal sense.
    Actually going through that right now on my current ride, debating on getting another set in smaller size to see if it improves the MPG, but will any improvement offset the cost at any point? At one point I thought, well if they dont work out, I can put them on my other car, which is about due for tires, but they are not the same size, 235 vs 225 on the old car, so.......
  11. bisco
    49,796
    we just drove 500 miles in the rain, pouring in some places, mostly 65 mph, no problems with the turanza's.
