After 6k miles on my 2011 Prius -- Observations
Discussion in 'Gen 3 Prius Main Forum' started by NewSlow, Jun 8, 2011.
  1. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Once I drove 75-90 mph in South Dakota/Montana for hundreds of miles and got around 45 MPG. Recently drove in Pennsylvania hilly highways at 70-75 mpg and got 50+ MPG. I don't hypermile. I really don't understand the 30s MPG situation you have, even at high altitudes, unless you are only driving 3 miles at a time. May be something is not right with your car.
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    OP needs to answer some questions such as the ones I posed at http://priuschat.com/forums/gen-iii...s-my-2011-prius-observations.html#post1340283.
    However, we might need most of the questions at http://priuschat.com/forums/gen-iii...-answer-these-questions-esp-if-youre-new.html answered to better understand what's going on and whether the mileage he's seeing is normal for his conditions and drives.
  3. oldasdust
    oldasdust Member
    356
    47
    illinois
    Top tier gasoline does make a difference in all the cars i have owned always better mileage. Regarding wind yes it effects mileage but not stability to an extent i feel unsafe in my prius. You should drive a box ( scion xb/ Honda element) i did and the prius is much better. The boxes were not scary but you had to pay attention to your lane position in traffic.Mileage in the boxes was terrible especially in winter and they were 4 cylinders.
  4. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    I'm consistently getting 43mpg according to the dash monitor. This is with 87 regular octane. Thus is mostly city driving with list of hills. No matter what I can't improve. Are you using 93 octane for higher mpg?
  5. walter Lee
    1,126
    376
    Maryland
    disclosure...
    First _ I'd like to say that I bought my Prius
    to experiment with hypermiling - that is to
    extract the best MPG that one can possible get
    so my expectations are different from yours.
    After 13K miles on my 2010 Prius,
    I am getting between 52mpg to 66 mpg per
    a tank with an overall 59 mpg from day one.
    A 2010 Honda Insight can be hypermiled to produce
    an overall 75 MPG but it requires more driving
    skill than a 2010 Prius (which has a top hypermiling
    overall 65 mpg). The Prius main advantage is that
    it has a larger, more active, and more helpful
    community (e.g. Priuschat.com) than the Insight
    community. The hypermiling car of choice is the
    2000 Honda Insight. The Prius easier to
    hypermile but (like a bicycle with training wheels)
    it's not likely to deliver top hypermiling performance,
    > overall 90 mpg.
    I have also observed that my 2010 Prius main fuel
    display (MFD) MPG tends to be about 4 mpg too
    high. My ScangaugeII because it can be manually
    calibrated is only about +/- 1 mpg off for the
    most part.... If only I could calibrate my Prius MFD...
    With respect to the Prius gas mileage
    I'd like to say...
    Like a high end BMW - if a Prius is not
    driven the way it was designed to be driven
    then it will return reduced performance with
    respect to its advertised rating. A Prius's fuel
    efficiency depend on a variety of factors
    that you probably didnot consider before you
    purchased it - A Prius fuel efficiency
    depends on how much long it is driven on the road,
    the outside temperature when you drive it, whether
    it is driven in hilly or flat roads, how much cargo
    is being carried, what type of gasoline you use, what
    kind of weather you drive it in, what tire pressure
    you are using/what tires you are using, you
    must avoid depending on battery (EV) power
    exclusive, and whether you drive it aggressviely.
    a more fuller explanation
    1) A FULL HYBRID GAS-ELECTRIC VEHICLE like a Prius
    does not achieve its rated fuel efficiency unless
    it is driven over 25 minutes(>55F,<40mph) to 40
    minutes(>10F,<40mph) per trip/session or over
    15 minutes (>30F, driven faster consistantly at
    mainly between 50mph to 60mph). This is because
    there is an energy cost to warming up the Prius
    catalytic converter from a "cold" start. In colder
    climates the cost of "cold" start is more severe,
    Canadian dealers often install electric engine
    block warmers onto Prius that can migitate this.
    2) The optimum outside temperature for the best
    fuel efficiency for a Prius is between
    55 Farenheit degrees to 75 Farenheit degrees.
    Grill Blocking can mitigate this loss of power
    from cold city driving. When the outside temperature
    drops below 30F, the Prius gasoline engine
    needs to be run periodically to keep the
    catalytic converter warm - it is more fuel
    efficient if the driver runs the engine periodically
    than if the Prius's main computer automatically
    turns on the car just to heat up the catalytic
    converter. One can monitoring the Prius
    engine's coolant temperature via a ScangaugeII
    Xgauge FwT or CwT to determine when the
    ICE is getting too cold ( < 120F)
    3) if a Prius is driven in a stop-and-go hilly roads
    mileage can drop significantly ( this is also
    true for conventional vehicles). Fuel efficiency drops
    when any vehicle must come to a full stop at the
    bottom of a hill and accelerate from a dead stop
    from the bottom of the hill. There are hypermiling
    techniques to mitigate this type of driving environment
    but if I've assessed your abilities this is not a
    viable option for you. It is easier to get
    better MPGs on a flat road or slightly inclined
    road than on steep hilly or mountainous roads.
    4) The 2010/2011 Prius fuel efficiency is sensitive
    to the weight in the rear of the car. For example,
    the Prius gets slightly better fuel efficiency when
    the fuel tank only 25% full than if it is 100% full.
    (this is only 65 pounds). My current hypothesis
    is that the extra weight in the rear of the car
    adds additional higher rolling resistance to the
    rear tires and that this lower the Prius fuel efficiency.
    IIRC a Prius is designed to carry a total passenger+
    cargo weight of less than 880 lbs.
    5) The Prius Fuel efficiency is better if you can use
    100% gasoline instead of E10 or E15 gasoline. Ethanol
    based fuels have less energy than regular gasoline so
    E10 and E15 tends to give lower FE performance.
    6) Every gasoline car gives worst MPGs in the winter
    than in the Spring-Summer-Fall. Bad weather - especially
    the type of weather that causes traffic jams and slow
    traffic reduces fuel efficiency in general. Grill
    Blocking can mitigate this loss of power in winter
    urban driving environments (its value is questionable in
    winter highway driving environments).
    7) High rolling resistance will reduce the fuel efficiency
    of any vehicle but the Prius fuel efficiency more sensitive
    to the tires' rolling resistance than other vehicles with
    more power (e.g. BMWs). On the flip side a Prius fuel
    efficiency benefits more from overinflating the tire pressures
    than most other vehicles because of its aerodynamic design.
    Hence, raising the tire pressure from the door specs
    (35 psi front/33 psi rear) to its max side wall psi
    (44 psi front/42 psi rear) can increase your fuel efficiency
    without any significant loss of road traction -- albeit the
    ride will be stiffer. An alterative way would be to swap your
    OEM tires for Low Rolling Resistant Eco Tires.
    8) Draining the Prius Traction battery lower than about
    42% (2 bars on the SoC HSI indicator) will cause the
    Prius computer to automatically turn on the gasoline
    engine to recharge the battery and cause the MPG to
    drop. To get the highest MPG possible, a driver must
    avoid depending on battery power ( HSI indicator should
    be pass the "ECO" middle marker to insure that the
    car is depending more on the gas engine OR the HSI
    indicator should be in the CHG mode indicating that
    the battery is being recharged via the regenerative
    brakes). On can monitor the Prius Traction battery
    state of charge with a ScangaugeII programmed
    Xgauge "SoC."
    9) A Prius fuel efficiency depends on the driver NOT driving
    it aggressviely. Jack rabbit starts, speeding to a stop,
    weaving in an out of lanes, driving over 65 mph will reduce
    its fuel efficiency. A Prius gets its best fuel efficiency
    when driven over 30 minutes at a constant speed (with no
    stopping) somewhere between 20mph to 50 mph. Just adding
    more time to your drive/trip so you don't feel the need to
    speed can greatly improve your fuel efficiency in a Prius
    (if not any other car). Fuel efficiency tends to drop on
    a Prius when the engine is run over 1/3 its max power
    which on a ScanguageII is when the Xgauge GPH > 1.39.
    hope this helps
    Walter Lee
    2010 Toyota Prius 3, oem floormats
    Blue Ribbon/Dark Grey
    Yokohama Avid S33 ( 50 psi front/48 psi rear )
    ScangaugeII ( AVG/MPG, RPM/Fwt, SoC, GPH)
    odeometer 13100 miles/ 59 mpg
    4 people like this.
  6. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    need more info
    What are you expecting and why?
    You should really answer the above question and the questions at http://priuschat.com/forums/gen-iii...-answer-these-questions-esp-if-youre-new.html in a new thread if you want mileage help.
    43 mpg might be the about the best you can do, given your driving conditions, esp. if they are short trips.
  7. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    The main reasons I got a Prius were similar: it suits my needs, even at EPA it gets great MPG, and I was curious to see what hypermiling it would deliver in my usage.
    From hypermiling an Insight-I and a Subaru over the past 5 years, I don't find the Prius is easier or harder to hypermile: it's just different. It's harder for me to figure out what is going on (so I got a Scangauge to see if the ICE is on) and as with any CVT it's difficult to manipulate the rpm of the ICE and the load on it. My impression is that Toyota tried to make it relatively easy for people to get EPA MPG in the Prius (though some people don't!), and in doing so made it trickier to get great MPG.
    As you say, MPG depends on so many factors, but a huge one (for any car) is how the driver drives it. So I don't think the Prius has a top hypermiling limit of 65MPG. Everybody, even the most ardent hypermiler, has a limit to what they are willing to do in terms of safety and effort, and that limit determines the max MPG they can get. For example, I'm not comfortable going <50mph on a 65mph-limit interstate (unless there is no traffic behind me or I am in a climbing lane). At 40mph I'd probably get higher MPG, but that seems too scary for me. OTOH someone who insists on driving "with the flow" at PSL+10 because they think it's unsafe to go slower (or they think going slower will add too much time to their trip) will get lower MPG. As someone pointed out here, that's why laws of physics are laws, not suggestions.
    My experience confirms most of the rest of what you say, with a few comments:
    Para 1: STM the MPG "hit" of warmup lasts only until the ICE reaches operating temp (Scangauge). From there, my trip average MPG rises continuously over the next hour or more, which means that the car is already running at high MPG's and gradually "amortizing" that hit. Maybe you meant that the trip average MPG rises to your max level over that period of time.
    Para 3: To me the optimum terrain is not flat, it's gently rolling, or even better modestly steep uphills followed by long gradual downhills. You can run the ICE in an efficient range climbing and then either shut down or run at very high MPG for long periods on the downgrades.
    Para 7: The OEM tires are LRR, no??
    Para 8: So far STM it's advantageous in the Prius to run battery-only in light load conditions (flat or gradual downhill) and let it recharge the next time the ICE comes back on for a hill or an acceleration. Hopefully the recharge load adds to the propulsion load to put the ICE into an efficient fuel-burning mode, and no energy is wasted spinning the ICE under light load conditions. Any MPG "hits" during recharge seem to be outweighed by the MPG gains during battery-only (talking about speeds <45mph here).
    [In the Insight-I it seems to work best to keep the battery fully charged, so that's different.]
    Para 9: I agree with everything except constant speed. Huge variations in speed are of course not advantageous. But I set a mental speed "goal": on secondary roads it's the speed limit, on highways it's usually 50mph in the right lane. Then I let that my speed fluctuate a bit around that goal as terrain and traffic dictate. Going up a hill, I might let it drop a few mph over the crest, especially if I know there's a nice downhill afterwards to regain speed. If I gain too much speed on a downhill, I add in more regen with the brakes or "B", no point in throwing away energy to aero drag. If no one is behind me, I may let the speed droop a bit if that seems advantageous; with following traffic I try to stick closer to my "goal" speed (in the right lane on multilane roads of course!). I may ease off a bit to build a "cushion" between me and traffic ahead of me so I don't have to lose too much momentum if they slow to make a turn, etc.
    [I'm aware of P&G and used it a lot in the Subaru. Haven't yet figured it out in the Prius!]
    Thanks for the writeup, it's very useful!!!
    P.S.:This is oh so true:
    People have such a hard time accepting that:
    (a) A car's MPG is not a single number, or even two: it's a range. Different Insight-I MT owners see anywhere from 40MPG to 95MPG, so they are used to this concept.
    (b) The largest single factor determining where one's MPG is in that range is how one drives. People think that changing gas, different tires, airing up the tires, using a grille block, a new air filter, adding aero mods, etc will radically change the MPG they get. These things can help, but driving the car the way it was designed to be driven will help even more (and costs nothing).
    (c) Driving this way is enjoyable and relaxing. Comments on here about "just enjoy the car": I absolutely do! People who haven't actually tried it think hypermiling must be boring or stressful. It's a lot less stressful than driving 80-85mph as I used to do!! But hey, if folks want to drive as they have always driven that's fine too - just don't complain about your MPG!!
  8. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Wow... VERY informative posts...
  9. walter Lee
    1,126
    376
    Maryland
    The Prius main computer is always trying to optimize fuel
    efficiency so to be truly effective a Prius hypermiler
    must apply only techniques that work in harmony with
    the main computer's programming. The challenge is
    that the Prius is constantly fine tuning the electric
    motors and the gas engine outputs - the HSI indicator
    only shows the driver a composite effort by three
    powerplants (ICE, MG1, MG2). It seems I'm always
    trying to play catchup...:rolleyes:
    Clarification: What I meant is that the current top
    *overall practical* hypermiling limit is about 65 mph.
    I can get +75 mpg on some route/trips but I can't
    consistantly achieve that level so my overall MPG is
    more like 59 mpg. My mpg varies too. In the winter it
    was 52mpg. In the Summer/optimum weather conditions-
    it can be as high as 66 mpg.
    Para 1: In the Summer/Spring/Fall - Yes, once the
    ScangaugeII/FwT >= 181 the ICE stays warmed up and
    the ScangaugageII/AVG is "amortizing" the MPG hit
    from the cold start cost. During the summer, If
    the Prius is turned off for less than 15 minutes
    and then turn it back on - the engine is still
    warm and the "amortizing" continues ( the cold
    start cost is mitigated). During the Winter when
    the temperatures are less than 30 Farenheit degrees,
    the engine temperature can drop because of a stop-idle
    (traffic light/jam) or because you are running
    only the electric motors (Steath highway mode,
    GPH=0.02). When the temperature drops below 130 F,
    the Prius will automatically turn the ICE on just
    to warm up the coolant temperature to keep the
    catalytic converter hot. This inturn can cause
    your fuel efficiency to drop like a rock (this
    happen to me when my Prius was stuck for one
    hour in a traffic jam caused by snowstorm - my
    Scangauge/AVG dropped from 55 mpg to 22 mpg for
    this particular trip primarily because I was
    running the window defrosters to occasionally
    lookout the window).
    Para 3:
    The best way to approach hills is to synchronize
    the Prius acceleration with the downhill grades
    using that speed/momentum from the downhill approach
    to assist the Prius's efforts going uphill.
    For short uphill section, I apply just enough
    power from the ICE to assist the uphill climb
    until the Prius is near the crest of the hill.
    For larger longer uphill sections, I gradually
    decrease the speed of the Prius from the
    middle of the uphill section to the top of
    the hill - to decrease the fuel consumption.
    When the Prius gets to the top of the hill
    the ICE should be be about 10mph less than
    when it was at the bottom of the hill
    However, it seems to me that the original poster
    wasn't a hypermiler candidate so I was thinking
    that the above technique wasn't going
    to be something he'd agree to.
    Para 7:
    Unfortunately no. :-(
    My OEM tires, Yokohama Avid S33, are not considered LRR atleast
    by the tire industry. Yokohama (as to other Tire Manufacturers)
    do make LRR tires but they are more expensive ($_$).
    However, if I overinflate the Yokohama Avid S33 to 44psi or 50psi
    their rolliing resistane decreases to a level similar to that
    of the more expensive LLR tires. Increasing the tire pressure
    from 35/33psi to 44/42 psi increases the Prius's potential
    coasting ability and thus contributed to an overall summer
    fuel efficiency increase from 55 mpg to 65mpg. However,
    Overinflating regular tires at 44 psi and above will result
    in more road vibration/shock being transmitted from
    the tire into the cabin so the Prius ride becomes harsher.
    When the tire pressure is increased above 50 psi
    the rolling resistance is less than if 44 psi but there can
    be a small loss in road traction/grip at higher
    speeds and when the road surfaces are wet/slippery (which
    a driver must anticipate and compensate for).
    Hypermiling expert Wayne Gerdes has overinflated tires
    up to 80 psi in a recent hypermiling contest - however,
    I am not sure how significant the MPG benefits are
    for going that high and what handling/performancee/safety
    driving limits/precautions should be observed at that
    tire pressure setting.
    Para 9: I chose constant speed because I didn't think
    the original poster would be more amiable CC than to P&G.
    I concede that P&G is better at optimizing a
    vehicle's kinetic energy than a constant speed.
    It also take less power to accelerate a Prius
    as it moves downhill than when it is moving
    on a flat road or while driving uphill (because it
    requires less power/torque to push the car downhill
    than uphill/flat straightway). The most fuel
    efficient way to handle hilly terrain is to
    uses the increase motor efficiency going downhill
    to negate the increase motor load going uphill.
    (b) The Prius is already very aerodynamic so
    aero mods like changing the roof antenna don't
    increase its MPG significantly. However, for
    non-aerodynamic vehicles, aero mods can improve
    vehichle's highway fuel efficienct significantly.
    For example, adding aero mods to a pickup truck
    (which normally have terrible aerodynamic characteristics)
    can increase its highway fuel efficiency significantly.
    (c) I liken hypermiling as more akin to sailing a boat
    - there's a kind of attitude where the driver
    is working with his environment to move forward.
    The original poster appears to be more of the
    motor/speedboat pilot variety where the driver
    is limited to manipulating the vehicle's power
    source to move forward.
  10. Jeremiahjj
    Jeremiahjj New Member
    Divide, Colo.
    I rented a Prius in Jacksonville, Fla. (cost me $540 for a week!) just to see what kind of experience/gas mileage I'd get. I drove it about 800 miles and the first tankful gave me 48 mpg calculated. The second tankful gave 43 mpg calculated. The car was kinda fun and I enjoyed the experience, although I thought it was slow off the line unless I stomped it. But nobody ever said the Prius was a hot rod. I didn't think it was worth $26,000, but beauty is in the eye of the beholder, I guess, and dealers charge what the customer is willing to pay. I'd have to think twice before I'd spend that kind of money, especially when the VW tdi and Mini are right up there too, mileage-wise.
  11. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Prius doesn't start at $26K. It starts at an MSRP of $23,520 before dest charge.
    If you go w/a VW, you'll have the "fun" of the lack of reliability of them. Diesel is more expensive than regular gas most of the year (see www.fuelgaugereport.com and http://www.eia.gov/tools/faqs/faq.cfm?id=9&t=5). The '11 Mini Cooper in the comparo and per Side-by-Side Comparison requires premium gas.
    Those vehicles are also quite a ways from the Prius in combined mileage. Per Side-by-Side Comparison, '11 Jetta TDI auto is EPA rated 34 mpg combined and Mini Cooper 31 mpg combined vs. 50 for the Prius. That makes the Prius 47% and 61% more efficient, respectively.
  12. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Cwerdna is right about all. The Prius is the highest rank and the MINI is the lowest raking vehicle.
    VW is a bit better, but still below average.
    Videos - Free video downloads and streaming video - CNET TV
  13. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    I will vouch for the crappy reliability of VWs.. I had a VW Golf and an Audi TT.. I have NEVER spent soo much in maintenance my entire life.. EVER.. I will never go back to a european car again..
  14. priushippie
    priushippie New Member
    330
    Pennsyltucky
    Would I buy again? YES! As soon as the plug-in comes out in my region! Maybe the Prius C as soon as it comes out. I have always gotten over 50 mpg. Presently at 54 mpg. I don't drive like a grandma and have gone over 100 mph! I don't like the dealerships around my redneck area but then again they are rednecks! Just logged 15,000 miles.
  15. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    From Walter Lee.
    I insist on going the flow of traffic because if I am dawdling along trying to save a few tenths of a gallon here and there, I am causing density waves in traffic, which causes other drivers to slow down and speed up as they have to change lanes to get around me, and I thereby cause other drivers to use many more gallons of gas doing this than I would save if I stayed in my own world. Most car accidents on the highway happen in these density waves, so there is also a potential for that as well.
  16. mmcdonal
    666
    98
    16
    Columbia MD
    Ewww, I had a new beetle years ago, and I never had so many problems with a car. I spent months waiting for a door lock mechanism to come in from Mexico. The Parts Manager got tired of hearing from me, and he said he would never own a modern VW because of reliability and parts issues.
  17. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Driving in our Prius in outskirts-of-city type speeds (i.e. traffic lights but no gridlock and no highway speeds) with the AC on this past week I'm having to consciously try and maintain even 47 on the computer--that's about 45 mpg real world. This does include the occasional hearty acceleration (as should be expected), but lots of early braking to maximize regen. I really can conclude that the EPA 51 is not realistic for this car. I am all but positive that the _average_ driver of a 3rd gen prius is not consistently seeing 50-53 on their computer per trip as they would need to be equivalent to EPA.
    Yeah, I know some of you claim 70 mpg is easy or whatever but I'm talking about the rest of us.
  18. Insight-I Owner
    505
    100
    Essex, CT
    TRAFFIC WAVE EXPERIMENTS
    Oh, and it's a LOT more than a few tenths, more like 10-20mpg on the highway, perhaps 10mpg in town. Without AC. The one time I used AC I set it at 75 degrees, the dehumidification helped a lot, and I didn't see a big effect on mpg.
  19. prius21
    prius21 New Member
    Oh
    2001 Prius
    vw car is absolutely trach and it won't ever stay with you more than 3 years then you'll spend a lot of money in it
    i would buy the worst totoya car ever than buying any germany car :d
  20. fuzzy1
    10,722
    Maybe I'm fortunate to live in a region where PSL, while slower than the mean, is still within the normal speed spread. And it helps that a portion of the CDLs are obeying PSL as a condition of employment.
    Bob Wilson's MPG vs. MPH graphs show far more 'a few tenths of a gallon' to be saved by not speeding.
    It is no surprise that most crashes -- the 'accidents' euphemism just obscures the causes -- occur where most of the car are. But the local reports often list specific driver misconduct, and I'm not detecting any pattern of what you claim. Nearly all the local crashes related to someone not moving 'with the flow' involve a victim not moving at all, e.g. disabled vehicles along the road, or the trooper and the suspected DUI he was arresting last weekend, hit when yet another DUI slammed into both their cars.
