After 8 1/2 years 12v battery GUG
Discussion in 'Gen 3 Prius Main Forum' started by BZzap!, Dec 16, 2019.
  1. BZzap!
    BZzap! Senior Member
    1,607
    878
    12v battery finally gave up the ghost after 8 1/2 years. The symptoms were an extended brake module run time followed by a few days of having to jump start the car in the morning. I’d say that I got my money’s worth. Replaced it with genuine Toyota battery. A little pricey but proven to be a good investment
    52,811
    i did the same this summer at 7 1/2 years, but didn't get any warning. pretty good run, let's do it again!(y)
    Bay Stater, tonynap and dig4dirt like this.
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    My OEM lasted around 8 years too, but I was pushing it with a charger/conditioner after I bought the car in 2014. I have one of those 12V USB outlet devices plugged into the 12V aux socket under the flying bridge. It has an LED readout of voltage when nothing is plugged in and alternating display of current or voltage when something is. The refresh rate was just good enough to show me a starting voltage of 9.6V one cold February 2018 morning, so off to my favorite dealership to get a TrueStart. About $226 and 30 minutes of work later problem solved.
    BZzap! and dig4dirt like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I got almost 9 years out of our 2010’s before replacing it:).
    Didn’t push it as far as you did, but before it left me wishing I hadn’t;).
    Nice avatar pic btw(y).
    Grit likes this.
  5. burebista
    burebista Active Member
    189
    130
    Romania
    10 years and half here.
    No problems with the car but I replaced it for peace of my mind.
    Bay Stater and Raytheeagle like this.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Interesting.
    I think these experiences go against the common thinking that the Prius 12 volt has about 1/2 that lifespan.
    I think a challenging aspect of the 12 volt in a Prius is that it actually doesn't crank over a "starter". With a regular ICE vehicle, you'll get ample warning that your battery is weakening, simply by "how" it's starting your vehicle. If it starts cranking slow, you're pretty much being warned battery failure is on the immediate horizon.
    With the Prius 12 volt, it's "booting" up the system, awakening the HV battery.
    Also, the 12 volt with a Prius becomes a bit of a Gremlin Catcher, as the recommendation to replace it, becomes almost automatic if anyone starts to experience symptoms that are hard to trace to direct cause.
    But those are impressive runs for the battery.
    I don't expect to get near that lifespan out of my Honda Fit battery, which I'm already nervous about, since it is about the size of a motorcycle battery.
    Johnny Cakes likes this.
  7. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    Older cars did warn you by cranking slower, especially on a cold morning. It's been my experience the last several years that they no longer do that. I had a couple that worked one day and clicked one time the next day. Seems to be all or nothing now. I'm not referring to the Prius though, mine did actually give me a warning on the instrument panel for 2-3 days..."accessory battery is low".
  8. Mendel Leisk
    42,310
    How much (part only or installed), and location? Is it the one branded "True-Start".?
  9. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    My 2010 (purchased early Nov) has its original battery. May 2010 date code iirc. It's obviously weak, but hasn't caused a problem yet. This weekend, I put a (fused) charging pigtail on the battery and started charging at every opportunity with a (Pulsetech) desulfating charger. I have had excellent luck restoring sulfated flooded electrolyte auto batteries with this charger... it takes a while (4 - 5 weeks)... but I've brought otherwise unchargeable batteries back to test like new (by specific gravity, voltage, starting capability). Can't say what causes end of life in these AGM batteries for sure. If it's sulfation, I'll likely see improvement over next few weeks. For $200...
    My 2 minute 12V Prius battery evaluation is this: After something other than a short trip, park the car for the night. In the morning, open the driver's door, but do not turn the car on. Check voltage. The easiest way is at the charging terminal in the fusebox. I was in high 11s, pretty marginal! I'd be interested to know what you get with a fresh battery.
  10. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    One difficult thing about an apples to apples comparison of batteries.....since they are replaced many years apart, getting the same brand/model as last time doesn't mean you are getting the same battery as last time.
    ASRDogman and burebista like this.
  11. BZzap!
    1,607
    878
    Toyota of Whittier, CA...$217.97 before tax, core etc.. Round about $230 out the door. It is the Yuasa, Toyota branded, True-Start, 84 month. Self installed.
    Bay Stater and Merkey like this.
  12. The Electric Me
    9,083
    5,801
    So you're saying I'm going to have a good excuse for not going to work tomorrow?
    Bay Stater and Grit like this.
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  14. Merkey
    Merkey Active Member
    329
    302
    Birmingham, Michigan
    Maybe not tomorrow, but a week from tomorrow.
    The Electric Me likes this.
