After Gasket repair, got "Check Hybrid System..." error
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by adrtho4, Jun 24, 2025.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,698
    1,745
    Bay Area
    Your latch looks secured and on properly, I wonder if it’s the big plug that you removed from the inverter that isn’t plugged in properly for the engine to run. I think your 12v battery seems to be fine because it turns on and the lights doesn’t look dim. I’d recheck the orange wire side to see if things aren’t plugged in properly or the engine side where the connectors aren’t plugged in.
    adrtho4 likes this.
  2. ASRDogman
    ASRDogman Senior Member
    7,597
    3,916
    post 35 :whistle:(y)
    adrtho4 likes this.
  3. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Yeah, I've already unplugged the battery and removed the safety pin. Will wait for the capacitors to drain (they probably have already) bust out the screenshots of the manual and check the inverter. That dr. prius app shows that the hybrid batters are good, which is great. Thanks for the callout!
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,158
    6,316
    Texas Hill Country
    If that does not work disconnect the high voltage at the compressor, inspect and try with it off after a 10 second 12v disconnect. The 12v cycling can be done at the fuse box by unplugging the white cable on top. Realize a Ready usually takes a couple of attempts after cycling 12v as the networks establish.
    This video at 28:50 shows the inverter cable installation and the cover interlock connector.
    #44 rjparker, Jun 25, 2025
    adrtho4 likes this.
  5. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Good tips. Thanks.
    EDIT: Ok. I never knew about this high voltage clip. Wow. Learn something new every day! Thanks again for the tip.
  6. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Ok. Engine runs. I drove it down the street to discount tire to get some air in my tire. On the drive back, I noticed the coolant light on. It was red. Coolant was overheating. Got a P0117 error code from the scanner reader. I replaced the water pump with a TRQ Engine Water Pump. So the water pump is new. I didn't replace the thermostat though. I've just ordered a new Asin thermostat, and water pump. The thermostat arrives tomorrow, so I will replace that and hope that will solve the issue. When I replaced the coolant I did bleed the system.
    So yeah... the saga continues. Could also be a faulty ETC sensor. So will order that as well.
    Tired of working on this thing, ngl. lol
    wukong sun likes this.
  7. NutzAboutBolts
    1,698
    1,745
    Bay Area
    you’re almost there! Don’t give up! :ROFLMAO::ROFLMAO: Hopefully when I put mine back, I don’t have that code either… I’m running on oem ect sensor lol but at least my wp and thermostat was replaced ;)
  8. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Yeah. I thinking it's that water pump not working. I got that Asin water pump on the way. Hopefully that works.
    NutzAboutBolts likes this.
  9. NutzAboutBolts
    1,698
    1,745
    Bay Area
    keep us updated (y)
  10. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    I've replaced the thermostat and water pump with Asin thermostat and water pump respectively. I burped the coolant for 50 minutes, revving occasionally. Checked that there were no leaks, and then went for a small test drive. I was a bit nervous because the last test drive I had, after about 10 minutes, the warm coolant light came on as well as the check engine light. This time.... nothing.
    Smooth drive. I think I can finally close this head gasket chapter and it's on to the next thing.
    Big ups Prius chat. You all helped!
    On to the next one!!!
  11. NutzAboutBolts
    1,698
    1,745
    Bay Area
    nice! Congrats! I’m trying to finish my HG install while filming, it’s taking longer than I expected. I just want to be done with it by now :cry::cry:
  12. Mendel Leisk
    41,463
    A few more years and we’ll have A.I. drones doing the recording. :)
  13. ASRDogman
    7,597
    3,916
    Take a deep breath, and count to a thousand by sixes!
    Wanting it to be done, is when you make mistakes! (y):eek:
    Step away, take a break...... You certainly don't want to make any mistakes.
  14. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    That was literally me yesterday. And I understand. I appreciate you filming it's going to help out so many.
    This.. this is the way. haha
  15. NutzAboutBolts
    1,698
    1,745
    Bay Area
    Hoping to finish by tomorrow! (y)
    Mendel Leisk, adrtho4 and ASRDogman like this.
