After-Market Fog Lights
Discussion in 'Gen 2 Prius Accessories & Modifications' started by wmhunter, Sep 15, 2006.
  1. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 21 2006, 11:56 PM) [snapback]323234[/snapback]</div>
    I used Silverstars in both of our previous vehicles, and I had two burn out earl also. The others lasted over three years though. Now all our cars have HID's (go on, I know you're all jealous :p ), so no more bulbs!
  2. Tideland Prius
    16,683
    Damn right I'm jealous lol. The only thing is that if I were to change, I don't really want to take the "easy" route and get a kit cause I know there will be glare. I've already seen those RSXs and Echo Hatchbacks with HID kits and rather than a nice cut off, they have just purplish white ovals. It'll be worse with the Prius since our headlight housing is larger than the RSX and Echo Hatchback. The only thing I can think of is to order a US Prius housing + ballast. Granted, I won't have auto-levelling... argh.
  3. BobZ
    BobZ New Member
    323
    Long Island, NY
    <div class='quotetop'>QUOTE(wmhunter @ Sep 15 2006, 05:12 PM) [snapback]320252[/snapback]</div>
    I added the OEM Toyota fog lights. The look and fit is good. No drilling or cutting the car up
  4. prius2go
    prius2go Member
    312
    <div class='quotetop'>QUOTE(DocVijay @ Sep 16 2006, 07:17 PM) [snapback]320552[/snapback]</div>
    which kit did you use? Did it involve cutting your :blink: ah just checked out your links
  5. DocVijay
    1,455
    Tampa, FL
    I just saw some OEM Prius fogs on eBay. Just search for "Toyota Prius" and scroll down a page or two.
  6. vuapplepudding
    vuapplepudding New Member
    75
    Nebraska
    <div class='quotetop'>QUOTE(jjf @ Sep 19 2006, 12:44 PM) [snapback]321714[/snapback]</div>
    JJF,
    I am considering the PIAA 2100XT "driving lights" for extended highway night driving. I really want to avoid retread tires and animals.
    JJF, now that you have had your fog lights for a while, do you still like it? Would you suggest PIAA? Does it really have the horizontal cut off to prevent blinding other drivers?
    As for the electrical connection, does connecting to the jumper bar cause the seal lead acid battery to run down or will all the 12 volt devices get power from the NiMH battery once the Prius is started?
    Anyone else out there with better advice and or products that you suggest.
    Thanks everyone PRIUSCHAT and the member rocks!!
  7. mee081224
    mee081224 New Member
    193
    Tampa, Florida
    <div class='quotetop'>QUOTE(DocVijay @ Sep 25 2006, 08:09 AM) [snapback]324588[/snapback]</div>
    are those these ones
    http://cgi.ebay.ca/04-07-TOYOTA-PRIUS-XENO...1QQcmdZViewItem
    and if so can they be upgraded to HID ?
  8. jjf
    jjf New Member
    Madison, WI
    <div class='quotetop'>QUOTE(Hard_working_student @ Oct 23 2006, 09:43 PM) [snapback]337179[/snapback]</div>
    I tried the fog lights on a dark, rainy night and they work really well. I've had other PIAA lights before and they really help in night-time whiteout conditions. I definitely recommend PIAA lights.
    I wouldn't call the horizontal cut-off razor sharp but the beam pattern is well-contained within the horizontal shape. I don't think it would bother oncoming traffic.
    I tested the fuse box power with the car turned off and it still has power from the small battery, but as soon as you start the hybrid system the power source will switch to the hybrid system. If you follow PIAA's directions the fog lights will come on only when the parking lights are also on. And since the car automatically turns off the lights when you leave it, it will turn off the fog lights too if you forget to turn them off.
    -JJF
  9. DocVijay
    1,455
    Tampa, FL
    I love PIAA lamps. I had 10 of them on my Explorer. They are very high quality lamps, but you also pay for that quality.
  10. emery
    emery New Member
    does adding driving lights or fog lights effect the factory warranty?
  11. jjf
    jjf New Member
    Madison, WI
    Any damage caused by the installation of fog lights won't be covered under the warranty. Other than that, the warranty will still be in place.
  12. h2photo
    h2photo Member
    432
    Chandler, AZ
    <div class='quotetop'>QUOTE(DocVijay @ Sep 16 2006, 11:17 AM) [snapback]320552[/snapback]</div>
    Wow, your fogs look great! The factory ones do diddly!! Ive been trying to figure out if I could replace them, I'm really liking your look!
  13. peternlori
    peternlori New Member
    <div class='quotetop'>QUOTE(wmhunter @ Sep 15 2006, 04:12 PM) [snapback]320252[/snapback]</div>
    We found these on e-bay. Check it out. Anyone know about these?http://cgi.ebay.com/ebaymotors/2004-2005-2006-2007-TOYOTA-PRIUS-4300K-LED-FOG-LIGHTS_W0QQitemZ170116977304QQcmdZViewItem :unsure:
  14. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(peternlori @ Aug 26 2007, 02:19 PM) [snapback]502464[/snapback]</div>
    If you are interested in "accent" lights for the fogs, then the LEDs are a good way to go, IMO. My semi-educated guess is that they will not help with actual illumination of the road - and depending on beam pattern, may make foul-weather driving more dangerous.
  15. jeff1802
    jeff1802 New Member
    Hunter;
    can you tell me how to get to the factory fog lights? Owners manual says to contact dealership, not this guy. I bought a new fog light lens unit and need to replace the old one because of a cracked lens. The car failed state inspection. Oh yeah, I have a 2004 Prius....
    jeff
