After market rotors too thick!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wrothgar, Nov 12, 2018.
  1. audiodave
    audiodave Active Member
    783
    268
    US
    Pretty standard for the inner and outer edge to be rusty.
    padroo likes this.
  2. a_gray_prius
    2,927
    782
    IL
    Pretty standard for rotors to be rusty period. That said, there's light surface rust and it's-disintegrating-in-my-hands rust. Don't know about OP, but I can say that after 258k miles, I'm in the second group and $28 for Bosch and $56 for OEM/rotor is not worth my being concerned about.
    I am very amused that there are TRD performance pads available.
    Prices are from Olathe Toyota's site. May be cheaper elsewhere (but probably not by a lot).
    Front brake pad kit:
    Regular pads: 04465-47050 ($76.88)
    TRD Performance: PTR09-52071 ($60.50)
    Front Rotors: Rotor - Toyota (43512-47030) ($56.57)
    edit: I confused the rotor manufacturers, $28 is for Bosch, not Brembo.
    #22 a_gray_prius, Nov 13, 2018
    audiodave likes this.
  3. wrothgar
    wrothgar Junior Member
    77
    16
    oakville, ontario
    Yes, maybe they could last longer...they did feel different lately though, and a mechanic I know well suggested in the summer that I change them. The rust was worse "inside" the rotors than on the edges.. if that makes sense. I find the car so cheap on brakes that I don't mind....much better than our crv, that can go through a set of rotors in 6 months if not serviced when winter tires are changed. Besides, the new ones are so pretty (not that you can see them behind the steel rims!).
  4. Al Bundy
    Al Bundy Member
    140
    69
    florida
    so my $5.99 brake pads from china with free shipping might not be the best........ now you tell me :(
