After Replacing Head Gasket GEN 3
Discussion in 'Gen 3 Prius Technical Discussion' started by Robot Prius, Jun 20, 2023.
  1. Robot Prius
    Robot Prius New Member
    Atlanta
    Hello,
    I purchased a 2012 Prius 2 for my daughter with 180K miles on it. I knew that it had a head gasket leak as the coolant level was decreasing with white smoke out the tailpipe. My daughter needed a car and who can afford cars now a days. So, I saw there were a few YouTube videos. How hard could it be? Well, 30 hours later with a fractured bolt while putting on the timing chain cover (learned about extractors!) and also cross threading a couple of the exhaust manifold studs (learned about taps!). I was finally able to get the whole thing back together.
    However, when I first started the car up, it rattled awful and I shut it off immediately. This is when I found Prius Chat. :) I found a thread mentioning a death rattle. I'm not sure what that is. But, I'm sure that if I had let the car continue that it sure would not have survived. Also, there was a lot of white smoke coming from the exhaust manifold area. Plus, it smelled awful. I was devastated. I thought that I had majorly messed something up.
    When I did the head gasket change, I thought that I should put in a number of new items: spark plugs, ignition coil, EGR valve and cooler (I know that you can clean them but I got a new set for $120), water pump, pcv, fuel injectors, thermostat, timing chain, and timing tensioner. I thoroughly cleaned out the air manifold and the pipe from the EGR. I was also very careful about making sure the timing was set-up as well by rotating and checking the marks before putting everything back together.
    So, after crying for a few hours, I decided to seek guidance from Prius Chat. Somewhere it stated to suspect timing, plugs, ignition coil, EGR or a few other items. All of those items were new or checked. I also had purchased a FelPro gasket. Upon receiving, it wasn't blue like the ones that I had seen on YouTube. It was grey. In the box, it stated that they needed to find other suppliers for the gasket material and not to worry if it was not their traditional blue. However, I was thinking that I had a poor gasket from who knows where. After reading Prius Chat for a while, one thread stated that unplugging the EGR stopped the condition. So, I tried that. And, it worked! The car purred nicely. But, I had a brand spanking new EGR. It couldn't be clogged. So, I plugged the EGR back and the car continued to run just nicely. Is there something the ECU needs to do in order to recognize a new EGR? I'm asking in case someone else were to do the same as I did and put in a new EGR only for it to rattle severely. I'm also just really interested in why it would rattle so severely with a new EGR. So, now that it seems to be running OK. I let it warm up a while. The white smoke seems to have disappeared. I assume that could be from getting oil or something on it and burning off. Also, the smell has gotten better. Somewhere I read that the new RTV gaskets off gasses when it heats up the first few times. I also did the combustion leak liquid test. The fluid stayed blue!
    I guess that I am writing this to let people know my experience after replacing the head gasket: new EGR (let the car run for a while with it unplugged turn the car off then plug-in), smoke (will burn off) and smell (will go away).
    I'm also writing as I purchased an OBD interface with Techstream. I read somewhere it would be useful in diagnosing the rattle. However, with the rattle now gone, how else might I use Techstream to monitor the new head gasket? Also, is there anything that I should be watching for with the new "grey" Felpro gasket? Thanks for any guidance for the newbie! Or, am I a newbie anymore after a head gasket replacement?
    mjoo likes this.
  2. SSAutomotive
    SSAutomotive Junior Member
    Stewartstown, PA
    Best thing to look at to monitor HG would be fuel trims. If fuel trims are negative and car fuel pump and all other fuel components are within spec, a bad headgasket dumping water into a cylinder will cause negative fuel trims often times. It sounds like you're good to go though. In terms of the rattle it could have simply been a temporary misfire for a number of reasons. Just keep an eye on coolant level for a week, then a month, and check fuel trims as well. After that I'd say let her fly!
    Oh and my fel pro gasket was grey as well, worked fine apart from the cracked head... Lol. Good luck man.
  3. JC91006
    16,933
    8,643
    Well the head gasket is not an item you monitor with techstream, it's just a gasket. Since you seem to want to get this as reliable as possible for your daughter, you should just go ahead and replace the HV battery with a new one.
    mjoo likes this.
  4. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    It's probably some combination of the ECU relearning the EGR, solvents used during the headgasket procedure boiling off, old engine coolant boiling off and going through the EGR, the hydraulic lifters readjusting, and pumps re-priming themselves.
  5. ASRDogman
    ASRDogman Senior Member
    8,042
    4,075
    From reading on here, felpro is a 50/50 guess.
    You didn't "need" these items: fuel injectors, timing chain, or timing tensioner.
    It didn't hurt to replace them, but not needed, unless there was a problem with them.
    But it didn't hurt to replace them.
    Did you spray wd-40 or other light oil into the intake/exhaust to check if any of the valves
    were leaking? Did you replace the valve stem seals?
    Did you clean the 4 small holes on the intake where the exhaust gases go through?
    Lot's of little things! :whistle:
    It's normal to run rough and noisey first time after replacing the head gasket. It should clear
    up in 2 or 3 seconds.
    There is no "need" to replace the hybrid battery. You could get the Prolong system and run
    it through the cycles which will give the battery a new lease on life. It worked on mine.
    I hope she gets a few hundred thousand miles out of her Prius!
    CR94 likes this.
  6. Mendel Leisk
    42,264
    Both the valve and cooler retail for over $200 USD (IIRC); any more detail on that bargain?
  7. ASRDogman
    8,042
    4,075
    Also, did you check to see if you had a bent rod? Did the pistons all go to the same
    position at TDC?
