Aftermarket 12v battery $89
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pmconely, Jan 6, 2013.
  1. pmconely
    pmconely Junior Member
    Orange County
    This battery is available for $89. It is distributed by Battery Power out of San Fernando,CA. I bought mine from Battery Mart located in Costa Mesa,CA 949-646-1696. It was no problem to install, it is vented and fits perfectly. It is available at some local auto part stores with branding from Battery Power. The vent holes are on both sides. One has to be plugged and the other is used. The stock vent tube is replaced by one that was provided by Battery Mart. The Toyota vent tube was too short and the hole on the new battery is smaller. The Toyota tube is easily pulled out and replaced by the new provided tube. It can be saved if you ever want to install a factory battery.
    The install took about 20 min and the new battery works perfectly. Much cheaper than a $200++ Toyota battery or an $180 Exide battery( which also has to use a new vent tube).
    Just my 2 cents. I know some might only use factory Toyota, but this battery worked perfectly for me.
    Battery Mart includes a 60 month pro-rated warranty.
    [email protected] likes this.
  2. Patrick Wong
    18,210
    6,517
    Good to know there are alternatives. However, pls note this battery is a conventional design with flooded plates, vs. the Toyota original equipment battery or the Optima, which are both AGM.
    That is why the battery only cost $89.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    It's a pity they do not put the capacity of this battery on the label, but apart from that it will hopefully give you good service.
    Some worry about having a flooded battery inside the car, but my OEM battery had plenty of liquid above the plates when I replaced it and many other vehicles have flooded batteries inside the car including the Mercedes A class.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    An AGM battery has no/little free sulfuric acid in case there is an accident and the case breaks. The battery you have found is 'flooded' with sulfuric acid which can cover the passengers in an accident. I urge you to use an AGM battery. (or not carry passengers)
  5. pmconely
    Orange County
    I grew up driving Volkswagens which has a flooded battery under the back seat which NOT vented. Like I said some people only feel safe using Toyota factory parts. Use what you feel comfortable with. I think not carrying passengers is a bit extreme, but you can do whatever you choose.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In that same era, Volkswagen vans were designed so the driver's knees were the 'crumple zone'. That did not make them safe then, nor does it mean we should go back to being that unsafe now.
    I realize I am advocating you spend approximately $100 on the safety of the people in your Prius, I do not feel very guilty about it. A vast number of 12 volt deep cycle batteries can physically fit in the space, and electrically do the job. To be safe while doing so may limit you to 3 models:
    1) The OEM battery at the dealership
    2) The Optima Yellowtop Optima DS46B24R Optima battery direct fit replacement for Prius 2004 + with Instructions
    3) The Exide Edge Toyota Prius Starting Battery - Exide Edge 51JIS Flat Plate AGM
  7. pmconely
    Orange County
    If this battery wasn't vented, I wouldn't have used it. I'm sure it will be fine. You should definitely use what your comfortable with.
  8. pmconely
    Orange County
    My 2004 Saturn ion has a vented conventional designed (flooded cell) inside the trunk similar to the Prius. I have 180k on it with no issues. GM does not install AGM' in the Saturn.
  9. John H
    John H Senior Member
    2,208
    558
    outside of the sulfuric acid and venting, I would not expect this battery to provide the same performance characteristics as the AGM batteries. I believe the depth of discharge the Prius 12V is exposed to will be problematic for a conventional flooded lead acid battery.
    If you install a non-AGM battery, you should probably consider replacing it with an AGM before selling or loaning it to someone else for liability reasons.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Is it in the passenger compartment like the Prius or in the trunk? (separate compartment)
  11. pmconely
    Orange County
    In the trunk which becomes the passenger compartment when the back seats are folded down. I will repost in a year with a performance update..Thanks for your opinion.
  12. bisco
    52,857
    this thread sounds vaguely familiar, especially the 'battery under the seat in the old volkswagon' part.
  13. John H
    2,208
    558
    Is Battery Power, or Battery Mart, recommending the battery for use in a Prius or is this your personal recommendation?
  14. PriusCamper
    PriusCamper Senior Member
    13,465
    5,432
    Pacific Northwest, USA
    There was a good thread on here about 6 months ago that looked into batteries for electric wheelchairs and how it'd be easy to match up a nice size battery that'd serve the needs of a Prius that way. Of course it's hard to find stats on wheelchair batteries thus far. But there's gotta be geeks out their that make high-performance electric wheel chair mods that know what battery is best? Still searching...
    I'm still on the fence with my 07 replacement battery. The YellowTop is popular because in the 90's they were the best even though in the past dozen years their product quality has been in significant decline. Also I think it sells well because of the psychological effects of the color yellow.
    But if I can find an Exide or a Wheelchair battery for half the price of a yellowtop that's what I'm going to do.
  15. pmconely
    Orange County
    The distributor Battery Power, and Battery Mart, the store are both recommending this battery for the Prius. Im not just "making it work". Also there are many auto part shops that stock Battery Power batteries and they also can sell you a battery (Battery Power) for the Prius.
    There are still thousands of Saturn Ions on the road with "wet" vented batteries in the trunk. The trunk area is not sealed and becomes the passenger area with the seats folded down. Like I said before my Saturn has 180k with no problems created by the battery.
    If you don't feel comfortable, then don't use it.
  16. pmconely
    Orange County
    For anybody lives in Orange County, CA. Hub Auto Supply 949-646-2464 stocks the Exide AGM for $179. Battery Mart and Hub Auto Supply are about a mile apart. You can compare the two.
  17. Britprius
    5,194
    1,922
    I am the one that uses the "wheel chair battery" and very well it works to. The version I am using is 60amp/hr and is ultra deep cycle agm and same physical dimensions as the OEM battery.
    As you probably realize with an application like a wheel chair the battery is deeply discharged on a day by day basis and has to be able to recover from this without damage.
    The extra capacity for periods when the car is not used also makes them eminently suitable for use in the Prius.
    John (Britprius)
    PriusCamper and ursle like this.
  18. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It only takes 1 hard rear ending of your vehicle to spray the entire cabin with sulfuric acid. And I don't think anybody in the entire history of the Saturn brand ever turned to it as a leader in safety...
    Do what you please to you, but you should never recommend this battery or any flooded battery in the passenger compartment to people other than yourself. Likewise as already mentioned, it is a severe neglect of safety that should condemn the vehicle to not be allowed to carry any occupants other than yourself you put yourself in the risk.
  19. John H
    2,208
    558
    That should work. It might be better to have the manufacturer onboard recommending it but the store and the distributor might have enough liability insurance if there happens to be a problem. I have had Interstate Battery deny a replacement warranty because "the shop" put the wrong battery in the vehicle (not a Prius).
  20. pmconely
    Orange County
    Spray the entire passenger compartment with acid? Seriously??? Severe neglect??? I don't think so. I didn't recommend this battery to anyone. You are being extremely dramatic..... So is every Saturn Ion owner putting themselves and their passengers at risk?? It's a vented battery.....VENting is what is required for inside applications, not AGM.
