Aftermarket Accessories or Mods for 2008 Prius?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Natalie Chappell, May 10, 2021.
  1. Natalie Chappell
    Natalie Chappell New Member
    Tennesse
    So I’m a owner to a 2008 Toyota Prius
    EVERYTHING IS FACTORY!!
    one of the first things for me is tint
    Can y’all throw some advice on other things I can do to make it look less factory.
    Burna J likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    --Take out the center console and replace it with an upholstered cushion or pillow. Looks way nicer/cleaner and more room for your legs and arms.
    --Install a lifters on the shocks so car sits 1 1/2" higher
    --Rear wiper delete
    --Replace corroded bus bars and nuts on hybrid battery and install grid charging harness like Maxx volts or Prolong by Hybrid Automotive
    --New Stereo
    --Low rolling resistance tires up above 40PSI for best gas mileage
    --See my mods below
    Natalie Chappell likes this.
  3. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    Hey, that rear wiper is useful. If she wants massively custom, let her get a wrap. Do you think it wise to encourage a newbie to mess around with the traction battery??
  4. Samuel Williams Jr
    246
    Dayton NV
    I don't get the rear wiper myself? But folks have been doing that forever? The bus bar and having a look could not hurt but yeah not the best advise for a newbie?
    My advise would be to have all the fluids, the pcv and the spark's plug's changed if they have no records? And to find a good Hybrid Shop. None of that would change how it looks but it may help keep it running. Then work on the rest. :)
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  6. Tideland Prius
    16,683
    Altered the title to be more descriptive
  7. PriusCamper
    13,472
    5,440
    Yes, very much so... The level of fear and misinformation and genuine apprehension to work on hybrid packs by even professional auto mechanics is ridiculous. It's a bunch of 8v battery modules wired up in series to create high voltage. Once the safety plug is removed it's no longer high voltage and very easy to work on / needs to be worked on to ensure its longevity.
  8. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    maybe, but some folks should be legally prevented from so much as touching a screwdriver... anyway she wants it to look different, i think maybe some nice wheels and some window tint is the place to start.
  9. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    I think you will find that even with the safety interlock removed there is still high voltage to be found inside the battery. The danger is only removed by removing the bus bars from at least one side of the pack.
  10. PriusCamper
    13,472
    5,440
    High voltage linked with 8volt modules in series only requires a single bus bar to be removed to disarm the high voltage risk. And while it's always better to train people to be extra cautious when they're first learning, the whole reason they created the orange safety plug design is to make the pack safe to work on by disconnecting a single bus bar and yet most professional mechanics are still too scared to learn how.
  11. dolj
    dolj Senior Member
    8,652
    4,404
    That is true that the circuit is broken. However, there is still exposure of up to 120 VDC on one side of the 'break' and a bit lower on the other. So, it is still not 'safe' until after removing all the bus bars from at least one side of the battery. When this is done it is safe as each module is a unit and the exposure is to only a nominal 7.2 VDC.
  12. kenmce
    1,552
    525
    NY
    This is what Zythryn did
    Nobody mistakes him/her for factory.
