aftermarket Air Shocks, anyone try it?
Discussion in 'Gen 2 Prius Main Forum' started by Meter guy, Sep 30, 2023.
Tags:
  1. Meter guy
    Meter guy Junior Member
    53
    I've searched Priuschat before posting and didn't find anything that helps me.
    I travel sometimes and my 09 Prius gets loaded down with stuff. the rear sags and at times bottom out on bumps. I've also noticed that the right shock is leaking oil. I've installed air shocks on a few other vehicles over the years so I'm familiar with that in general, just.
    ive searched the internet for gen 2 air shocks, some come up but I can't really tell if they are just ones that "might" fit of if they actually will. I'm questioning this because some show bottom and top attachments that are not compatible with a gen 2 Prius. so with the ones that look like they would work, i also see those part numbers associated with completely different cars.
    are there any of you that have actually installed air shocks in a gen 2 and if so what brand and part number did you use and was there any modifications to do aside from running the air hose...?
  2. Tombukt2
    Tombukt2 Senior Member
    13,857
    2,516
    Durham NC
    You need to be looking at site like airbag.com as in shock absorber airbags not steering wheel SRS airbags they're a bunch of companies that make all kinds of air suspension add-ons for all kinds of vehicles not previous specific per se but I'm sure there is a way to skin that cat if anybody's done it to any other smaller car it would be very similar there's nothing special about the Prius now finding air shocks with the proper coils around them and the upper and lower mounts may be a stretch but can probably be fabbed up relatively easy from a base model air shock that meets the height and stroke requirements which shouldn't be too hard to source out then putting spring perches on said tubes is not an expensive proposition.
  3. Meter guy
    53
    your link to airbag.com is for sale it appears. i searched for helper airbags on google and got products for 2k-5k way out of my range
  4. Tombukt2
    13,857
    2,516
    Durham NC
    Arnot and KYB make things that look like they could be added to to make up such an assembly You're looking at like 12.6 to 16.8 extended eye to eye or mount to mount or however you want to look at it have approximately 6 in of travel in the factory strut apparently by looking at it in a couple different manufacturer sites Arnot and KYB make what looks like what could be made to work have to get some measurements . Mo rore alsomakes quite a lineup But none of this stuff would just bolt up to the car and you'd be off and running far from it actually look at your actual strut from the rear of your car and that's what you're looking to duplicate maybe with a smaller spring fitted around it air shock that would fit it so coilover springs in the 4-inch range might do or 5-in range.
  5. bisco
    52,847
    Search priuschat for stiffer springs and etc
  6. pasadena_commut
    pasadena_commut Senior Member
    3,060
    951
    Southern California
    It had never crossed my mind before, but "modify a car so that it can carry more weight" doesn't find very many relevant answers in Google. The first hit says to put bigger springs in the back. Naively I would think that might be safe to do if only a couple of hundred extra pounds will be carried, but past that bigger tires are going to be needed, the brakes might not be adequate, and I fear the handling might be adversely affected (even when only a small load is being carried.) It would definitely make the ride even worse than it normally is.
    The Prius isn't supposed to tow, but nevertheless people have done light trailers, and at least there when the trailer is not in use the car would be the same as it always was.
  7. Meter guy
    53
    I go to swap meets from time to time, I have a hitch and a rack that mounts on the back. the rack itself is lightweight aluminum, but when i load up the car returning home i often have a full car plus that rack has several bins on it, full of stuff.
    when I bring back a nice haul, the car is basically bottoming out on big bumps, and when i drive thru a parkinglot the speed humps scrape the back area.
    that's pretty much what carrying extra weight looks like, nothing wildly unusual.
    some of the other vehicles ive had in the past, when i knew i was going to cary alot of stuff, i would add pressure to the air shocks and bring it up easy.
    this may not be as easy as i thought. ill look into the stiffer. stronger springs
  8. bisco
    52,847
    Yeah, you definitely want stiffer springs for that, maybe even a lift kit
    dolj likes this.
  9. Meter guy
    53
  10. bisco
    52,847
    Strawbrad knows his stuff
  11. Tombukt2
    13,857
    2,516
    Durham NC
    Yep Corolla vibe and Matrix mix .no air .just al lil more Uuumph.
