Aftermarket Catalytic Converter Install
Discussion in 'Gen 2 Prius Main Forum' started by rogerthat, Jul 30, 2021.
  1. Ultimate_Combination
    65
    48
    Durham, NC
    - $124 ebay Cat
    - $77 Denso O2 Sensor
    - $100 Mechanic Install
    Man, I was too slow in removing the OEM Cat or Cat Sheild myself so I missed the $1000 +/- profit on the OEM Cat :(
    $301 Total for a Cat Replacement after theft is fine by me!
    Thanks for the ebay link @rogerthat
  2. rogerthat
    rogerthat Active Member
    411
    129
    Georgia
    $100 seems reasonable for a mechanic to install - Did you get it welded or did you settle for the clamp?
  3. Ultimate_Combination
    65
    48
    Durham, NC
    He used the clamp.
    I got a glimpse of him using that mandrel bending and cutting machine he has, which he used to taper the end of the tubing on the new Cat so it could slide nice into the end of the exhaust pipe that was cut...and he did use the clamp.
    This kit wonderfully includes the clamp and bolts and spring bolts for the install....the old springs and cut bolts are still on the ground in that school parking lot.
    Last I heard from the police that they've tracked it down to a known Vietnamese Cat Theft ring from Chapel Hill driving around in a white Toyota Camry with obscured plates...yeah I don't expect to get that part back at all now...
  4. tashaviaf
    tashaviaf New Member
    Brooklyn
    Welp.
    It only took six days for my original catalytic converter to be stolen off my just-bought-last-week 2008, 2nd Gen Prius (AKA the most sought-after one on the market right now with the highest value), right on the corner with security cameras, in a "good" neighborhood (Williamsburg BK).
    I'm in NYC. Any suggestions? Is it safe to drive or should I have it towed? I haven't spoken to Geico yet to see if this is covered but I do have comp/collision.... hopefully this will be covered?
    I didn't even get a chance to make a happy post about my new (to me) car to share with ya'll :(
    It has 206k miles so I'm comforting myself by saying that it probably needed replaced soon anyway, I do not know. Argh.
  5. Danny13pruisc3
    175
    28
    maryland
    Damn that sucks. It will be covered with geico since you have comp.
  6. Danny13pruisc3
    175
    28
    maryland
    you probably already handled it.. but i would just leave it home and order the cat and install myself if you have basic mechanical skills.
    Driving it is loud AF.. so that's up to you.. I would slap on any kind of muffler up in there and rig it to stay up over driving it as is.
    BTW that cat sells on amazon for like $90 sometimes. if you see it at 130 sometimes you can wait and the price will drop back to 90.
    I've purchased 2 of them at $90 now.
  7. Danny13pruisc3
    175
    28
    maryland
    BTW thanks for posting this thread.. it probably saved me some time.
    I ordered a 6 pack of dewalt metal cutting sawssall blades and it cut through pretty quickly. Make sure you cut from the buttom to the
    top so the the pipe doesnt cave in on the blade. i found that out the hard way. it probably would have cut through in like 5 seconds or less had i started from the bottom. it cut through from the top but hung up at the bottom as it caved in.
    I probably saved myself some time/hassle by leaving the factory donut in and reusing the bolts. (thanks to the tip from the op in this thread). I did find that even though my 1/2" electric battery impact wrench didn't break them free, I think it kind of did.. because first i tried using the impact no go.. then i tried the breaker bar.. then i tried the impact some more.. and then the breaker bar seemed to work. Kind of sucked doing that from the ground..
    It's probably just best to let the mechanic put it on the lift and straight pipe it.. the 2 muffler shops around here wanted like $180.. one quoted me $80 but i lost the contact info.. of course now i found it again afterwards..
    the other tip i'd say is to get some card board to lay on. i used the U clamp supplied with the cat.
  8. Danny13pruisc3
    175
    28
    maryland
    BTW if you live in a big city or CA.. Sell your gen 2 and get a prius C you'll lose some interior space
    but you'll get better MPG, easier parking, a more reliable car and a better looking car..
    and not have to worry about your cat theft.. I was suprised some people get their cars ripped off more than once.. i guess the idiots doing the work might be newbs not realizing the second cat isnt' worth jack until after they take it..
  9. k barbieri
    k barbieri Junior Member
    22
    Brooklyn, N.Y.
    Mine was just stolen 2 Sundays ago from my 2008 Prius at 9am! I gave a question I’m thinking of going aftermarket on my replacement and putting a cat security shield over it. The plate is made fir make model and my year and all Gen2 years I believe.
    Wondering if anyone has put the cat security in their Prius.
    Thanks
    #49 k barbieri, Sep 7, 2021
  10. rogerthat
    411
    129
    Georgia
    Yes, many people are installing cat shields. Search the forum and you'll find numerous posts on that topic. However, it is my opinion that the extra expense is not worth it if you are installing a cheap aftermarket cat - just make it as clear as possible that you have an aftermarket version installed. Also double check that you're allowed to use an aftermarket cat as you're in NY.
    Danny13pruisc3 likes this.
  11. Danny13pruisc3
    175
    28
    maryland
    Sounds like i have an exhaust leak.. or i'm wondering if it's just louder because this fake-azz cat is probably mostly a straight pipe.
    maybe i'll pull it up on the ramps today to investigate.. i didn't use any paste.. then again maybe i'll leave it like this. it's not too loud and i kind of like knowing when the ice is running so i can get off the gas pedal lol
  12. rogerthat
    411
    129
    Georgia
    Minor update: The warning I wrote with a Sharpie Industrial Marker (rated to 500 deg F) did not last. I may get some orange heat resistant paint as another poster suggested.
  13. qmanqman
    qmanqman Active Member
    444
    153
    CO
    You think theft is new?
    I know right? People think Trump is a hero and savior. LOL
    #53 qmanqman, Sep 28, 2021
  14. jzolot
    jzolot Junior Member
    Chicago, IL
    2001 Prius
    I’ve been driving since 1972, got my 2001 Prius in 2008, living in a low crime neighborhood for over 30 years. Guess what… for the first time, my original cat was cut off the bottom of my Gen 1 five days ago. I did not think it was “statistically likely” either, especially with a 21 year-old car. Wrong.
  15. jzolot
    Chicago, IL
    2001 Prius
    I really really really wish I’d done this BEFORE my Gen 1 had the cat converter cut off it and stolen. Thanks for posting.
  16. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    I wouldn’t fret about it. Probably wouldn’t have made any difference.
  17. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    That's not how probability works. The probability of event y happening don't change just because it happened to you. If there's a one in a 100,000 chance of something happening, it's going to happen to 3,300 people in the United States. If one or all of them were to pop on to a message board and say, "You're wrong! It happened to me." they would be incorrect to say that it's not true that the probability of said event is 0.00001.
    You yourself are testifying that the probability of having a catalytic converter stolen on any given day has been about 1 in 18,000 in your experience.
  18. jzolot
    Chicago, IL
    2001 Prius
    This is seriously way above my brain-width!
    Since it happened to me, seems that probability just shot up to 100%. I suppose I’m just myopic, though!
  19. rogerthat
    411
    129
    Georgia
    Update: 1 year and 1 month and over 10k miles later, the aftermarket CAT passed emissions.
    PriusPaddler and PriusCamper like this.
  20. rogerthat
    411
    129
    Georgia
    Update 2: 1 year and about 3 months later, the car just logged a P0420 error code. Well at least it went bad not too long after passing emissions. I cleared the code and I'm considering options. Does anyone know if the car will pass emissions if the code is cleared and does not return or do the inspections review cleared codes?
    I may install another aftermarket cat just before my next emissions test. Has anyone tried the L-shaped spacer hack?
    PriusPaddler likes this.
