Aftermarket Cruise Control units
Discussion in 'Gen 3 Prius Technical Discussion' started by afshin, Apr 14, 2024.
  1. afshin
    afshin New Member
    New Zealand
    Hi All
    I recently bought a Prius 2015 (S model) which sadly does not come with a cruise control. But I noticed that you can buy Cruise control separately and install it. First of all, is it safe to do so? Second, I noticed that you can buy Toyota original cruise control unit or buy copied Chinese version. I wonder if anyone has used these copied version and had any problem with them or not, because they are much cheaper than the original one. I have bought this one from BINGWFPT (AliExpress item number 1005005220489106), and I wonder if any one has any experience using this one.
    Best Regards
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Top trim without cruise control? Not top trim anymore!!!
