Aftermarket Engine Air Filter
Discussion in 'Gen 2 Prius Accessories & Modifications' started by NROhioPruis, Jun 25, 2008.
  1. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Or Boost and spray..... Meth! :usa2:
  2. problemchild
    problemchild New Member
    429
    36
    The same people who I posted about above tested EVERY air filter made on a 200,000 dollar flow bench. The tests were done by the pros. The final verdict was the GM OEM filter was the best for the trucks and the KN/UNI foam and cleanable filters were the WORST by a long shot. About the only thing the KN filter would stop was squirrels and small stones. It was allowing so much dirt to get into the engine it was unbelievable. I would not put that garbage on any motor I owned.
  3. MR.K
    MR.K Junior Member
    86
    Idaho
    Yea but over 400 $ for a stock air box when yours is damaged ...50 $ sounds pretty good....
  4. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,546
    You're in Cali right Bra...
    First off... if the air filter/intake is not CARB approved, you wont pass smog.
    Second... The stock air-box is very efficient.
    Third... stay away from oiled-foam filters with modern electronic controlled sensors (MAF/MAP etc.) that get contaminated with the oil from the incoming air over that filter. These type of filters work quite well with a carb motor and someone that isn't too keen on changing dirty filters very often, but are a detriment to finely tuned and monitored fuel injected ones.
  5. northwichita
    481
    102
    29
    Wichita KS
    Thanks for all the info, I learned a few things from them. I'll probably stick with oem filter, my question concerned reusing a stock filter after blowing it out with an air gun. I drive all day on dusty roads, and have been in the habit of cleaning the air filter in other cars every oil change, to minimize the cost of new ones. I shook the prius one out last week, got some dust out, it looked more like cloth/synthetic then paper.. Washable? A rural carrier.
    I looked this up in my Bentley manual, says clean element with compressed air, if not extremely dirty , nothing about washing it.
  6. GatorJZ
    GatorJZ Member
    285
    17
    Hate to burst your bubble, but the "pro" who conducted the "test" you are referring to, Username Spicer on bobistheoilguy, is a tree trimmer by profession, not exactly an engineer. He tested one application only and you can not extend his results across the board to all aplications of all filters. While I have some slight misgivings about K&Ns, they are FAR better filters than you are giving them credit for.
  7. Rakimb17
    Rakimb17 Junior Member
    48
    Palmdale CA
    A little Meth never hurt anybody...lol
  8. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Agreed! Chris Chow of GN fame got me hooked on the stuff. I still have all my teeth though. :D
  9. 60psi
    60psi New Member
    a 2 1/2 lb huffy bike!
