Aftermarket Headunits
Discussion in 'Gen 4 Prius Audio and Electronics' started by liamr, Jan 4, 2017.
  1. liamr
    liamr Junior Member
    Ireland
    Guys...
    I would like to replace the awful factory headunit on my 4th Gen Prius. I would like a unit from a reputable manufacturer that has Android Auto and requires little or no splicing. I also want all of the steering wheel buttons to work as they should.
    I would probably do the install myself as I don't trust what some "experts" will do behind the covers.
    what proven options are out there?
    Liam
  2. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Welcome to Prius Chat. You are not alone in seeing a simple exchange unit, but I fear is not as easy as it sounds. However, good luck and please post of you find a solution on your own as many would be interested.
  3. liamr
    liamr Junior Member
    Ireland
    thanks RCO. I'm hoping that a high end brand like Kenwood combined with one of the interface kits will make most things work.
    Seeing that you are in the UK and a fellow RHD driver, can you tell me whether there is a RHD double din dash kit available?
    49,490
    welcome! maybe drop into a car stereo shoppe and chat them up. you may come away with some good information. all the best!(y)
    RCO likes this.
  5. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Sorry, I'm no expert in this field, but bisco (above) is world renowned for sound advice. I'm sure you could do worse. I know there are others doing similar things on other threads here, but they're all USA based and that could be well expensive from this side of the pond.
