Aftermarket LED headlight replacement bulbs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 2010_Prius_I_White, Jan 30, 2015.
  1. 2010_Prius_I_White
    2010_Prius_I_White Junior Member
    62
    Las Vegas, NV
    I
    Well since it's been a couple years and the aftermarket parts for the Prius are becoming more available, does anyone know what are the best LED Low Beam Headlights I can get for the 2010 Prius I? There's SO much deceptive marketing out there like trying to say "4000 LM!" when if you read the fine print, it's really 2k / bulb, which makes their statement a lie. So I ended up buying some that are extremely dim, cost me about $23 for the pair, claimed 80W and 1200 Lumens, but that's just simply not true. I couldn't even see the road when they were installed. What started me on the whole search for LED headlight bulbs was that I was having to replace the H11's every 6 months and I was getting tired of it. Advice?
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    There is no such thing as a good drop in LED replacement for halogen bulbs. None. All the ones you see on ebay are sick cosmetic toys that do not put out any useful lights, as you have found out.
    Albeit technically against the law, you best bet would be to get an HID retrofit kit. I have read that in the Prius, they work better than the stock halogens, but not the factory LEDs. They do not last as long as the LEDs but more than the halogens.
  3. Thomas Loke
    Thomas Loke Junior Member
    Auckland, New Zealand
    2012 Prius+ MPV
    Has anyone tried this LED headlight with the projector lens of our Prius?
    Search on eBay "2015 4th Gen ETI LED Headlight 60W 8000LM KIT H11 H9 H8 Bulbs x2 Hi or Low Beam". My account here hasn't matured enough for me to post links.
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    None of these LED drop in bulbs are ready for prime time quite frankly.
    If one wants an upgrade from halogen, go HID, so long as you have a vehicle with projector lenses (such as the Gen III Prius).
  5. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
  6. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
  7. 12voltman
    12voltman Member
    124
    93
    Go with the H9 conversion . Pretty simple to do , tons of info on PriusChat on how to do it .
    Much brighter light , LONG life , and pretty cheap .
    Made a TON of difference on my 2011 .
    Serval likes this.
