Aftermarket questions
Discussion in 'Prime Accessories and Modifications' started by MMBH, Apr 14, 2018.
  1. MMBH
    MMBH Member
    155
    43
    I recently bought a Prius Prime Premium, but didn't realize that most of the safety features I thought were standard on the Prime were only available on the Advanced model.
    Does anyone know if there is an aftermarket option for the following items:
    • install a steering wheel warmer
    • is there any remote control device option to turn on the heat in the car while it's plugged in outside
    Thanks in advance!
  2. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    There are generic steering wheel heaters you can purchase for any car.
    Middle trim (premium) has a remote ac function that kinda works for preconditioning the car. You have to set the a/c settings before turning off the car though.
  3. VVTiBob
    VVTiBob Member
    45
    29
    What about ordering the steering wheel that comes on the Advanced model. It would have the heating element built in then just add the switch and wire the circuit.
  4. Diemaster
    Diemaster Active Member
    298
    263
    so. cal
    not sure if there are different part numbers or if the light is included on lower trims but there's also a steering wheel heater light in next to the MFD
