Aftermarket Remote Start w/OEM fob - Video inside.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by The Critic, May 2, 2013.
  1. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    From the xpresskit website. You create a profile, tell it what you have(drive) and it lists your options. What is applicable to your vehicle, pdf downloads that contain instructions and firmware. Which you need the xbloader to load.
    SCH-I545 ?
  2. butchbs1985
    butchbs1985 Taking things apart is fun!
    232
    16
    ChicagoLand
    2013 Prius v wagon
    Why would temp effect the remote start of the Prius? No engine to turn over so unless there's an interrupt somewhere due to temp, it shouldn't do anything different. On my truck the remote start tries several times when it's cold just because the RPM's don't go high enough when it first turns over when cold.
  3. gus6464
    gus6464 Junior Member
    16
    Does the DBALL allow me to modify the remote proximity unlock so that all doors unlock vs just the driver door?
  4. ryankokesh
    ryankokesh Junior Member
    33
    I'm having the same problem. I think all three wires are correctly tapped, but all I get is the seven blinks. Did you ever get this figured out?
    iPhone
  5. StarCaller
    StarCaller Senior Member
    1,273
    724
    Cedar Crest, NM, USA
    the db-all2 & the tlth2 should work with a 2014, right?
    & it's pin 30, not 23?
    edit: works. it's pin 30/
    KeepitSimple likes this.
  6. KeepitSimple
    KeepitSimple Member
    128
    Washington, District of Columbia
    Would this work for the Prius C?
  7. StarCaller
    1,273
    724
    regarding to the xpress site, NO /
    but who knows, they might add the prius c in the future/ ;)
  8. KeepitSimple
    KeepitSimple Member
    128
    I can't get the firmware to load property and the customer service chat isn't the greatest. Anyone in Virginia that could help with the software/firmware portion?
  9. peterjmc
    917
    189
    Clarksburg, MD
    Where in Virginia are you?
  10. ryankokesh
    33
    The first time I flashed it everything went perfectly. Then when I wanted to change the run time I ran into issues. Weirdest thing. Eventually it worked.
    Are you on a vm?
    iPhone
  11. KeepitSimple
    KeepitSimple Member
    128
    VM= virtual machine? No just a regular PC.
  12. KeepitSimple
    KeepitSimple Member
    128
  13. prizzy
    prizzy New Member
    17
    dallas, tx
    Will I void my warranty if I tap in to the ecu wire using T connector?
  14. ryankokesh
    33
    I can't imagine it would. I don't have any facts to support that, however.
    iPhone
  15. prizzy
    prizzy New Member
    17
    dallas, tx
    Ryankokesh, thanks for the fast response. Sorry for asking too many question. but I just look over the TLTH2 harness diagram on post #10. If I use TLTH2 harness than I do not need to tap into my ecu wiring? I assuming using the TLTH2 harness is a plug n play.
  16. ryankokesh
    33
    Ask away!
    I think there's two or three wires you'll still have to tap behind where the fog switch etc is. It greatly reducing tapping, though.
    iPhone
  17. prizzy
    prizzy New Member
    17
    dallas, tx
    I ordered my kit and it arrive. The flashing went fairly easy. For safety measure, do I need to disconnect the battery when tapping into the wire?
  18. StarCaller
    1,273
    724
  19. prizzy
    prizzy New Member
    17
    dallas, tx
    Hey guy, I just installed db-all2 & the tlth2 on mine 2014 Prius 3, when I hit the lock button three time nothing happen. I check the wire diagram and it is tap correctly. Any one exprience this? I also flash my dball2 using internet explore.
  20. StarCaller
    1,273
    724
    obviously you did something wrong /
    start from scratch checking ALL the connections /
    I did pretty much the same thing as you, but mine worked right away /
    BION
