Aftermarket Stereo for Generation 1 Prius NHW11L
Discussion in 'Generation 1 Prius Discussion' started by UN1X, Sep 10, 2016.
  1. UN1X
    UN1X Junior Member
    2002 Prius
    Has anyone been able to install an aftermarket stereo system? It would be nice to have a Bluetooth capable stereo system installed in my Prius.
  2. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    Yes, we do them all the time. You need a 1DIN high radio and the brackets that hold in the dealer installed CD player. Install the radio where the CD player would go (behind the flip down door) and modify the two wiring harness adaptors as described in this thread: Radio Auxiliary Install? | PriusChat
  3. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    If there's nothing else wrong with the radio, you can get a blutooth attachement for your car. Mine came with a Tranzit Blue ISFM23. It plugs in to the antenna inlet on the radio, you connect the car antenna to the input on the little box. You can get one at Amazon for about $60, and it's pretty easy to install.
