Aftermarket Wheel Fitment Guidelines
Discussion in 'Prime Accessories and Modifications' started by Rob43, Apr 3, 2018.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    The Sexy look of steel wheels ! (Lol)
    Rob43
    myhockeyswag.com likes this.
  2. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    Rob - you never posted a good side photo of your wheel set up, can you?
    Also - I went through all 10 pages and it's pretty scattered in regard to what you bought. Any chance I can beg you to type in 1 post exactly what you bought and from where? I really like your set up and prefer to go with EXACTLY what you bought.
    Any chance you can list it all neatly for my ordering purposes? :)
  3. caymandiver75
    caymandiver75 Member
    192
    100
    Northern VA
    2019 Prius Prime
    I swapped over my 2012 Prius Performance Plus 17" wheels to my Prime. Been running these for the past 7500 miles with zero complaints.
    MrBugMan, evpv and Xterra72 like this.
  4. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    Those look amazing !!
  5. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Sure, I'll put something together later today. Pics might take a few days due to a busy schedule.
    Rob43
    PS, If you have any conveniently located 240v outlet near your Prime, you can use your Toyota OE 120v EVSE unit at 240 volts for fast 2:28 minute charging for less than $50 dollars.
  6. Backyard_86
    Backyard_86 New Member
    Hayward, CA
    2020 Prius Prime
    New member. Picked up 15x6.5 TE37 they're 9.5lbs !
  7. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Welcome to PriusChat !
    They look good.
    Rob43
  8. Darkly-Noon
    Darkly-Noon Junior Member
    Ottawa, Canada
    2020 Prius Prime
    I see most are choosing 17" aftermarket wheels, but I decided to get a 16" setup, hoping to hit the sweet spot between light, efficient but puny 15's and wider, grippier but heavier 17's. I also wanted something that looked OEM, and not "aftermarket-ey".
    I looked at Tire Rack and some Canadian sources that my local tire shop could get for wheels, but I didn't see much that I liked in 16" sizes, so I started looking at European sources. I wound up ordering these from Performance Alloys, a mail-order supplier in the UK that ships world-wide.
    MAK Wolf, 16" x 6.5" ET35mm, black / polished finish
    I weighed one with a shipping & receiving scale and they're 21 lb each. Not exactly the lightest available, but they ought to be rugged enough with the potholed roads around here.
    I don't have them installed on the car yet, as I still have to choose tires. But I found a German wheel website that has a great 3D configurator and I was able to get a rendering of what it will look like. They don't have the Prius Prime on file, but they do have the regular one...
    I'll post pics of my own car once it's all together
  9. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
  10. Darkly-Noon
    Ottawa, Canada
    2020 Prius Prime
    Yes, I got the correct hub rings for the Prius when I ordered the wheels. And they included lug nuts, too
    Looking at a performance all-season like the Michelin Pilot Sport AS3+. There's lots of others in that class, too - Bridgestone, Goodyear, Continental, etc.
  11. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Good...
    Many great choices, look at all of the Eco Focus tires first.
    www.tirerack.com/
    Rob43
    #191 Rob43, Mar 21, 2020
  12. Darkly-Noon
    Ottawa, Canada
    2020 Prius Prime
    Wound up getting the Michelin Pilot Sport AS3+ in the 205/55 HR16 size. They always seem to be among the top-rated ones in the performance all-season class. So far I've only driven home from the tire shop, but they're pretty quiet on the highway, and they're certainly a lot grippier than the factory tires.
    evpv and Rob43 like this.
  13. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    They look real good on your Prime (y), keep us up to date on how they work/feel/handle for you.
    Rob43
  14. Darkly-Noon
    Ottawa, Canada
    2020 Prius Prime
    Thanks, Rob43 - will do. Here's a couple other angles. The offset is 35mm, so they only stick out 5mm more than the factory wheels.
    MrBugMan and Rob43 like this.
  15. ConfusedBirdie
    44
    34
    I found some on tire rack that are 17x7.5, 45mm offset. Would that need spacers or work as is?
  16. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    As long as they have a 5x100 bolt pattern, they'll work fine.
    Hopefully they're light-ish weight. Order a set of 54.1mm hub rings.
    Your 205/50-17 tires are still within the specs of a 7.5" wide wheel and will work great.
    Rob43
    #196 Rob43, May 15, 2020
    ConfusedBirdie likes this.
  17. RalphD
    RalphD New Member
    Phoenix
    Just wanted to share the new 18x8 with a 40 series eagle tires. 9D34000A-8A06-42CE-9D64-2DD640DF65CB.jpeg EEBFE87E-34FA-4CA4-8740-C7B79DE8D889.jpeg 52471F05-EC84-4CF2-BE51-FFFC725E3F52.jpeg
    MrBugMan, xliderider and Rob43 like this.
  18. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Ralph, looks great & welcome to PriusChat.
    Can you provide a link to your exact wheels & tires ?
    Rob43
  19. myhockeyswag.com
    myhockeyswag.com New Member
    Toronto, Canada
    2020 Prius Prime
    Luxury
    Hey everyone! Hope anyone can help me with this issue here...
    I have 17" OZ Sparco Terra wheels on my Prius Prime and trying to put 5mm spacers on both front and rear.
    Wheel spec.
    Universal Fit 17 in. / 7.5 in. / 5 x 100 / +48 mm / 72
    • Family: Sparco Wheels
    • Model: Monoblock
    • Wheel Diameter: 17 in.
    • Wheel Width: 7.5 in.
    • Bolt Pattern: 5 x 100
    • Offset: +48 mm
    • Centerbore: 72
    • Color: Black
    • Finish: Matte
    • Material: Aluminum
    I took it to a shop and they tried with 5mm spacers but the oem bolts were too short.
    Yesterday, I took it to the shop again since they wanted to measure the stud length. They quoted CAD600 for getting new studs so I can put on bigger spacers...
    Like Rob wrote on the thread, I think I'll probably go with 3mm spacers so I don't have to spend 600 just for the studs.
    I am hoping if I any of you can give me a lead on this. Thanks in advance guys!
  20. ConfusedBirdie
    44
    34
    I just ordered some Enkei Vulcan 17x7.5 and some Yokohama Avid Ascend LX 215 45 17. They have the BluEarth LRR and have an 85k treadlife warranty.
