Aftermarket Wheel Fitment Guidelines
Discussion in 'Prime Accessories and Modifications' started by Rob43, Apr 3, 2018.
  1. TractionAction
    TractionAction Junior Member
    Brentwood CA
    2024 Prius
    The wheel and tire combo look great, can you share your mileage with this set-up?
    Any spacers needed, or just bolt them up?
    Also, can you post some pics?
    I'm thinking of upgrading when my stock 15's wear out.
    Check out willtheyfit. I believe this is the one Rob43 references in his posts (very helpful).
  2. Lue
    Lue Junior Member
    22
    Palmdale
    Thoughts on a set of Volk Racing TE37’s
    15x7 +35
    kojack and stomish like this.
  3. Maxinator117
    Maxinator117 New Member
    new jersey
    2019 Prius Prime
    I have some msw 17x7.5 (offset 45) wheels, but from a car I no longer have . However, the bolt pattern is 5x108. I was thinking of purchasing some 1.25" wheel adapters to be able to use these rims. I dont mind the look of the wheels slightly outward. My question is, does anyone have experience of using adapters on their prius, and are there any issues that could arise from this?
    I have used adapters before with these same tires and did not encounter issues. [Originally the rims were purchased as a winter set for a Ford fusion, when the lease was up i used adapters to fit the snows to a lexus rx 300]
    My thinking, after getting about 47k out of the stock toyos, is that I can mout my winter set from my steelies to the oem wheel. And use the 17"s i have for a dedicated summer set. However I can only do this by getting adapters.
    Any thoughts?
    Also, I would probably go with 215/45/17 summers
  4. 100 free watt hours
    100 free watt hours Junior Member
    Have you noticed any difference in handling with the 17" tires and wheels. I find the 15" are barely adequate for the coast highways.
  5. Racing Shepherd
    Racing Shepherd New Member
    Decatur Georgia
    nice!
    Do you have a link?
    and just curious if Mpg is slightly less?
  6. afkguy
    afkguy New Member
    LA
    2020 Prius Prime
    I just picked up a used set of wheels 16x7 +48 wrapped in 205/55 hankook tires.
    kojack likes this.
  7. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    My 17” Corolla wheels with Firestone tires are a huge improvement for handling and braking. I give up maybe 10% mpg but I still average around 1,000 miles on 10 gallons. 28700851-A3FB-4A07-A1C5-FF73032FD873.jpeg
    Gabe29 and AshPrime like this.
  8. JoeVA52
    JoeVA52 New Member
    Virginia
    2021 Prius
    Do those 17" Corolla wheels fit without and medications or spacers?
  9. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Yes, bolt on with no spacers.
    TGrracie likes this.
  10. JoeVA52
    JoeVA52 New Member
    Virginia
    2021 Prius
    Thanks for the feedback. Are you happy with the ride? What size tires did you go with?
  11. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    The ride is great, still very comfortable, slightly more road noise than the original 15” tires. The tires are Firestone FR740 215/45/17 that came from the factory on Corolla S cars. I’m pretty impressed by the handling/ride balance of the tires, I’ll buy them again when they wear out.
    JoeVA52 likes this.
  12. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
  13. Zerg711
    Zerg711 New Member
    17
    I just ordered 17x7.5 +38. Enkei PF01 - strong, light and cheap . This will go with my TRD aero. I’m contemplating 225 or 205 tires - performance or max mpg??
  14. boostedGS
    boostedGS Junior Member
    45
    Los Angeles area
    Do whatever your heart desires. (y) But with those options, I would pick performance since we already get a good amount of MPG, but I'll probably use 215/45/17 tires. Tires, I'll probably go with Michelin Pilot Sport 4S or something performance oriented since I like to canyon drive, etc. I used to have a 2012 Prius 3 for a daily, had it lowered coilovers, Enkei17x8 RPF1's, and 215/45/17 Federal RSRR's (bit loud).
    I would put the car in maintenance mode to turn off all the sensors and rip through the canyons, sliding around (when I run the stock 15's on Nanoenergy tires). Keep up with some up in the canyons and people were surprised it was a Prius. It was fun, but it was also how I eventually totalled it. :ROFLMAO:
  15. Yamsta
    Yamsta New Member
    Maryland
    For the 2021 Prime, I noticed there are actual alloy wheels behind the hub caps. I took a cap off to see what they look like and I actually liked the look! However there is a empty space where a centercap would go. Is there a centercap that fits? Anybody have a part number?
    Also, what would be the mileage hit if I run without the hubcaps? Anyone have pics of their cars without them?
  16. Salamander_King
    Salamander_King Senior Member
    11,025
    8,981
    New England
    Check this thread.
    Question about center caps | PriusChat
    There are a few links and part numbers of the center cap in the thread. Yeah, maybe in an ideal test set-up, aerodynamics may be improved with the cap, but in the real world, there will be no noticeable mpg hit.
    Yamsta likes this.
  17. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Yes, IMHO the alloys look much better than the hubcaps, and I took them off on my last two PPs. You can get a set of four OEM center caps from eBay for about $50. Unless you are a "Hyper-miler" squeezing every last erg of energy per dram of fuel, I don't think you'll notice any appreciable change in efficiency and, as a plus, the wheels are far easier to keep clean from brake dust.
    Yamsta likes this.
  18. Afrelientk
    Afrelientk Junior Member
    Las Vegas, NV
    2021 Prius
    LE AWD-e
    New Prius owner here. I’m looking to upgrade my stock rims with 18” rims. If I get 28lb rims with LRR tires what can I expect that to do to my gas mileage? I don’t want to destroy my vehicles fuel efficiency but I’m having trouble finding lighter weight 18” rims. Thanks for the help!
    I have a 2021 Prius LE AWD-e
  19. Grizwaldo
    Grizwaldo New Member
    Riverside, California
    2022 Prius Prime
    Brand new 2022 Prime owner here.
    I went with the BRZ performance package wheels that are 17x 7.5 offset is 48
    These were on the Subies with Brembos so the caliper clearance is fine, also checked all the other clearances inside the wheel well.
    I have the Toyota FRS center caps ordered.
    215/45/17 but I want to go with Rob’s 205/50R17 generals next to fill in the wheel well better.
  20. kojack
    kojack Junior Member
    32
    22
    grand falls-windsor, NL
    I am looking at going 17's when we get our prime very soon. I am going with a leightweight wheel and LRR tires. what kind of MPG loss am I looking at when I swap? I am going to try to find a very light wheel and tire combo.
