Aftermarket Wheel Fitment Guidelines
Discussion in 'Prime Accessories and Modifications' started by Rob43, Apr 3, 2018.
  1. Mendel Leisk
    42,335
    Nice driveway too. :)
  2. Robert Giroux
    Robert Giroux New Member
    Montreal
    2022 Prius Prime
    We kept the OEM mags and installed Bridgestone Blizzak WS-90 winter tires on these mags. This is now our winter set :)
    Prim.e.xample likes this.
  3. Robert Giroux
    Montreal
    2022 Prius Prime
    LOL :) We are really pleased with the new mags & tires. When the car is freshly washed, it looks fantastic!!!
    Since we tend on keeping our cars a long time (this PP replaces a Corolla S 2009), we invested a bit more in mags/excellent tires so the car looks great in winter and in summer.
  4. Suds
    Suds Member
    32
    32
    Wichita
    2026 Prius Plug-in
    XSE Premium
    Prius Corolla Wheels.png 2021 Prius Prime XLE 9400 miles. Just installed 17" x 7" 39mm offset 50th Anniversary 2017 Corolla Wheels (PT758-02170-01). Michelin 215/45/17 Crossclimate 2. MudFlaps on the way from England.
    #264 Suds, Jan 15, 2023
  5. hox
    hox Junior Member
    33
    Portland, OR
    Hi all,
    I purchased a set of Flow One Spec F2 wheels to replace my OEM wheels for my brand new 2020 Prius Prime Limited. ~25k miles later (I do not drive much!) and I discover that the inner 1.5-2 inches of the rear tire tread is unevenly worn on both sides during a regular tire rotation. The wear was bad enough to require replacment of both rear tires which then triggered having to replace all 4 tires. The tire shop which does not do alignment advised getting an alignment to prevent premature replacement of the new set of tires.
    I never thought to get an alignment on my new Prime when I first swapped out the OEM wheels. I love the way my car handles with the larger wheels (17x8 ET45 18.4 lbs each) so maybe this post will help others considering replacing the OEM wheels to add an alignment after installing larger wheels/tires.
    Unfortunately I also learned today when I had my 4 wheel alignment done at the dealership ($180!) that the 2020 Prime does not have camber adjustment, so I am not certain the tire wear issue is resolved. The service person also said they recommend annual alignments on this model to prevent uneven tire wear even with OEM wheels. This cost is something I never thought about when purchasing this car, which I believed to be fairly low in mainteance. So January 2025ends with a $750 unexpected tire bill and a $180 alighment. OUCH!
