Aftermarket Wheel Fitment Guidelines
Discussion in 'Prime Accessories and Modifications' started by Rob43, Apr 3, 2018.
  1. Kai_stories
    Kai_stories New Member
    Fullerton
    Yes
  2. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    I heard those had a good weight to price ratio. How much do they weigh?
  3. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    OK, now that we're clear on the fact that you want to run a "staggered" front & rear wheel setup*, Why Do You Want To
    Do This On A Front Wheel Drive Chassis ?
    Rob43
    * Are you planning to run a bigger rear tire for the wider rear wheel ?
  4. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    17.0 lbs Each.
    Rob43
  5. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    73.1 to 54.1 (Prime OE Diameter) hub centric rings
    Rob43
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
  7. philip kim
    philip kim Junior Member
    16
    los angeles
    Will a bolt pattern of 5x114.3 work on the prime????
    iPhone ?
  8. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    No.
    Only a 5x100 bolt pattern will work on a prime. (#4 on my list)
    If you look at my above wheel Double bolt pattern, you'll notice that it has 10 total cut holes. The inner
    set of holes are 5x100 & the outer set is 5x114.3, as you can imagine the outer set of 5x114.3 would never line up.
    Do you like any of these ?
    Wheels - Konig Wheels
    Rob43
    #28 Rob43, May 13, 2018
  9. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Hub rings installed...
    Now my wheels are hub centric.
    Rob43
    Apollo2TheMoon likes this.
  10. swla90
    swla90 Junior Member
    Los Angeles
    4A9DAF9A-85D7-4A86-80F5-37FFACFAD8D4.jpeg Plan on getting these wheels:
    15x6 +45mm 5x100
    OE tires
  11. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Go for it, those will workout just fine.
    Rob43
    Compared to your existing stock OE wheel, this new wheel will have an inner rim which is 1.4mm further away from the suspension strut. The outer rim will poke out 11.4mm less than before.
    #31 Rob43, May 22, 2018
  12. philip kim
    16
    los angeles
    Hey everyone just wanted to get some answers, since im a bit confused. I am looking into getting some rims and was wondering if my stock tires will fit. The rim is 15x6 5x100 with +45 offset. The stock tires on the prime is P195/65R15. Will i need to get spacers to make the offset back to 40 and will i need hub centric rings? i believe the bore is 73mm
    #32 philip kim, May 22, 2018
  13. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    1) Re-read post #30 & 31, it directly applies to your question.
    2) Spacers: you don't "need" them, but you might want them because your new wheels will look like they're sitting
    more inbound / inward by about ~11mm's. A spacer will get you closer to the look of a stock OE configuration.
    3) Hub Rings: Yes, buy a set of hubcentric rings. First determine what the hub bore is on your new wheels, 95% says they're
    the more common 73.1mm & 5% says they're the less common 73.0mm.
    Rob43
  14. philip kim
    16
    los angeles
    Thank you Rob43
    iPhone ?
  15. philip kim
    16
    los angeles
    What type of wheel spacers do you recommend? I would like the offset to be back at 40
    iPhone ?
  16. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    philip kim likes this.
  17. philip kim
    16
    los angeles
    Are there gonna be any issues with the tpms system on the wheel swap?
    iPhone ?
  18. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    If you get it right, no. If you screw it up, yes.
    As long as you re-install them correctly on your new wheels, your Prime shouldn't know the difference....
    EDIT: I personally always re-install the TPMS units on the SAME corners that they came off of. So mark your OE wheels with LF, RF, LR, RR.
    Rob43
    #38 Rob43, May 22, 2018
  19. philip kim
    16
    los angeles
    i called a shop today and they told me i will have problems with the studs if i use the 5mm spacer. they said the most i can do is 3mm. Is that true?
  20. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    This is much more a question about "Their" liability once you leave their shop. Some shops won't install spacers at all.
    The key to all of this is.... You need about ~6.5 rotations (turns) of lug nut engagement as your minimum, more turns would be
    considered a plus.
    If you remove one tire you can easily mock this up yourself, just install a stack of washers that simulate ~5mm's of space in
    a triangle pattern on 3 wheel studs. Then re-fit your stock OE wheel & finger tighten* those 3 lug nuts to see if you have at least
    6 tuns of engagement, as long as you do you're good to go.
    Rob43
    * Don't roll it or drive it.
