Aftermarket Wheel Fitment Guidelines
Discussion in 'Prime Accessories and Modifications' started by Rob43, Apr 3, 2018.
  1. AshPrime
    AshPrime Junior Member
    17
    SF Bay Area
    2019 Prius Prime
    BigBilly, or anyone with lower profile tires. How do you notice the ride comfort and cabin noise to be when going with a lower profile tire to make up for larger rims...? I am hoping to go to a 16" or 17" wheel but I'm a little apprehensive about noise level from a lower profile tire. Thanks in advance for any opinions, much appreciated.
  2. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    First, go with a 17", you'll be happy you did.
    Your question is EXTREMELY tire specific, meaning choose the right tire and it could be quieter than OE, choose the wrong tire & it will not be good.
    I personally love my General (made/owned by Continental Tire) G-Max AS-05's in 205/50-17 (19.2 lbs) mounted on a 17x7" that weighs 17.0 lbs.
    The two choices that you won't go wrong with are:
    1) Yokohama AVID Ascend GT in a 205/50-17
    2) General G-Max AS-05 in a 205/50-17
    Rob43
    #122 Rob43, Aug 21, 2019
    TheRedRocker and AshPrime like this.
  3. AshPrime
    17
    SF Bay Area
    2019 Prius Prime
    Rob thank you so much for the advice that's great info and a great reminder about tire choice being important as well. Thanks also for this extremely valuable thread it's had amazing traction!! No pun intended lol...
  4. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Thank you !
    Buy tire #1 if you want to "slightly" lean towards quiet/comfort.
    Buy tire #2 if you want more dry grip, tire noise will be close to OE sound.
    Both choices are INCREDIBLY BETTER than the OE tires....
    Rob43
    AshPrime likes this.
  5. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    Does anyone know about this wheel and whether it would fit a Prime? I can't find a weight figure for it but apparently it's forged, so it should be fairly light.
    I first saw the wheel a couple of days ago on a (likely 2017) FRS (now called the 86) and it looked danged good.
    Kthai01 likes this.
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Yep, sure do....
    First, they will fit & work great.
    Specs: 17x7.5", ET 43, 5x100, ~18.5 lbs, HB 56.1
    The only recommended item you should get is the 56.1 to 54.1 hub rings.
    Rob43
  7. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    Rob43, thanks for the info. It's the look I've been searching for for quite awhile — 15 spokes and flat-faced — but unfortunately I'll have to cross it off my list because at ~18.5 lbs it's just too heavy, especially for a forged wheel. Do you remember where you got the weight spec? And come to think of it, 7.5" is probably too wide for good fuel consumption. Oh well; the search continues...
  8. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    That's too bad...
    As a performance wheel purchase, they would have been great ! But as a fuel economy purchase, they'd be only fair.
    The weight was pulled from another car forum where the poster bought the wheels and weighed them with the tpms installed. As an OE wheel, they're Very light weight...
    I will tell you that my personal setup makes for an Extremely Enjoyable performance daily driver when compared to the Toyota OE 15" tire & wheels.
    Rob43
  9. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    ...and your personal setup is...?
  10. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Post 16 & 17.
    Later I added a set of 5mm spacers, this gives the appearance/illusion of a 215/45-17 setup.
    Rob43
  11. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    Those Winners are 17x7 I assume. How much do they weigh?
  12. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Yep, 17x7, 17.0 lbs, ET40, 5x100, HB 73.1; Typical cost is somewhere around $105 to $112 each.
    You'll need 73.1 to 54.1 hub rings & Tuner (smaller diameter) conical/60 degree lug nuts, I bought ET lug nuts because I knew in advance that I was going to use 5mm spacers.
    I'd recommend either of the tires I mentioned a few posts above...
    Rob43
  13. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    Thanks again. You're one very helpful guy!
  14. ConfusedBirdie
    44
    34
    Do you have a picture of those on your car?
  15. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
  16. ConfusedBirdie
    44
    34
    How is the fuel economy comparison to stock? I’m about to put these on my 2017 and am curious.
  17. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    workin my way threw this thread
    15 x 6.5 Helium silver 11.4
    15 x 7 Lightening blue 13.4
    17 x 7 - - 17
    #137 vvillovv, Oct 10, 2019
  18. rlk204
    rlk204 Junior Member
    Hey @ConfusedBirdie - I would say I have reduced the fuel economy about 5-10%. I track my MPGs via an app between fill ups and I use to get 50-55MPGs and the last 2 fill ups were between 45-50 MPGs. My commute (~8 miles) has gotten significantly less since I got a new job so fuel economy has become less of a priority for me so I don't really care and the looks out weigh the loss for me specifically. Hope that helps.
    ConfusedBirdie likes this.
  19. ConfusedBirdie
    44
    34
    do you have a picture of them on the car?
  20. TheRedRocker
    TheRedRocker Member
    47
    46
    Kansas City, MO
    I don't have a Prime, but wanted to thank Rob43 for his advice
    I pulled the trigger on the General G-max AS-05 225/45R17 (21 lb) and Konig Ampliform 17x8 40mm offset (17.85 lb)
    Rob43 likes this.
