Aftermarket Wheel Fitment Guidelines
Discussion in 'Prime Accessories and Modifications' started by Rob43, Apr 3, 2018.
  1. Rob43
    Rob43 Senior Member
    1,335
    940
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    You're welcome !
    Looking forward to your feedback.
    Rob43
  2. ConfusedBirdie
    44
    30
    Put the FRS wheels on my 2017 today. They look amazing in my opinion.
  3. Nascosta
    Nascosta New Member
    Laguna Beach
    2019 Prius Prime
    I’m looking to put these on my 2020 Prime, they seem to fit the bill. With a spacer and hub adapters.
    I know it will take a hit on MPG, but if it’s only 5-10mpg I’m not too worried about it.
  4. ConfusedBirdie
    44
    30
  5. Rob43
    Rob43 Senior Member
    1,335
    940
    2013 Prius v wagon
    What exact tire brand/model did you get & what tire size ?
    Rob43
  6. Nascosta
    Nascosta New Member
    Laguna Beach
    2019 Prius Prime
    Hi Rob, do you see any issues with the wheels in my previous post? Fitted to a 2020 prime? i’ve seen your link to the hubcentric adapters. They seem to fit the parameters you stated in the first post, thanks again this thread is very informative.
  7. ConfusedBirdie
    44
    30
    I followed your advice on size and got 205 50 17. I went with Westlake SA-07. I had some on my optima hybrid and they were as fuel efficient as Continental Pure Contacts I also had And lasted worry free for 70k miles.
    So far, in a very limited sample size, my fuel economy has gone down by about 12% with this combination.
    #147 ConfusedBirdie, Oct 24, 2019
  8. Rob43
    Rob43 Senior Member
    1,335
    940
    2013 Prius v wagon
    Yes they will fit.
    As far as I can tell, the hub bore on those FRS / 86 wheels is 56.1, so make sure you buy the correct hub rings* or spacers.
    Rob43
    * My personal hub rings for my wheels won't work on your wheels, my 17x7's have a 73.1 hub bore.
    Nascosta likes this.
  9. Nascosta
    Nascosta New Member
    Laguna Beach
    2019 Prius Prime
    Thanks Rob
  10. Rob43
    Rob43 Senior Member
    1,335
    940
    2013 Prius v wagon
    What tire Brand/Model are you going with & what size tire ?
    Rob43
  11. Nascosta
    Nascosta New Member
    Laguna Beach
    2019 Prius Prime
    they are those 15 spoke wheels made for the Toyota 86.
    Make: Toyota TRD
    Size: All 4 rims 17x7.5
    Offset: ET +43
    Bolt pattern: 5x100
    Color: Flat gunmetal grey
    Hub Bore:56.1
    Part number: PTR20-18160-GR
    tire will be a 205/50-17 but not sure what brand
    #151 Nascosta, Oct 27, 2019
  12. ConfusedBirdie
    44
    30
    I am a week into having the FRS wheels on my 2017 Prime.
    They are 17x7 and have a 48 offset. I put 205 50 17 tires on them. The tires I put on compared favorably to some Continental LRR on another hybrid I owned. I used 3mm spacers and the 56.1 to 54.1 hub ring:
    my question is this - if I’m getting 20-25 % worse MPG than stock, is there possibly something wrong? My EV range is down from 25 to 18.5.
    My mpg at 65 mph is down from 63 to 53. I drive around 110 miles a day and I got consistent 80-86mpg daily. Now I’m getting 66-68 mpg. Highway at 70mph I used to get 55mpg now I’m getting 43.
    could something be off because of the offset still being 45 vs stock 40? Are there certain things I should check first? When I let off the accelerator it seems to act almost like it is in “B” mode now and that is new.
    thanks for any guidance I can get.
  13. Rob43
    Rob43 Senior Member
    1,335
    940
    2013 Prius v wagon
    First thing, pull one wheel off and put it on the an accurate scale and get your weight, then report back.
    Rob43
  14. ConfusedBirdie
    44
    30
    42.5 lbs
  15. Rob43
    Rob43 Senior Member
    1,335
    940
    2013 Prius v wagon
    1) Your ~42.5 lbs weight was roughly what I was expecting, this works out to be about 33% more weight than OE.
    2) The other major factor is your choice of ~$45 to $55 dollar Chinese tires, I actually believe that they work well in most environments, especially in the dry. BUT there is no factual data on rolling resistance / fuel economy, I believe that this is your most important factor and downfall on a tire like this.
    3) It's this combination of factors that's eating up some of your MPG's. But remember, your Prime now feels & drives MUCH better than a stock OE Toyota Prime sitting on 15" wheels.
    Another way to factor all of this: You saved BIG $ on your tire purchase, take your probable ~$200 to ~$250 dollar plus savings & factor them back into your fuel economy over the average life of these tires. Your fuel economy loss will be Much Less.
    Rob43
    #155 Rob43, Nov 5, 2019
    ConfusedBirdie likes this.
  16. genericuser
    genericuser New Member
    29
    San Francisco
    2020 Prius Prime
    Anyone know if the current gen Prius' star rim fits the Prime? Looks very nice, and must be low drag since it's OEM Prius part.
  17. Rob43
    Rob43 Senior Member
    1,335
    940
    2013 Prius v wagon
    If they're off of a current Prius with a 5 lug bolt pattern, they'll fit just fine.
    Upgrade to a great tire for pure driving excitement:
    Better Handling On A Budget ! | PriusChat
    Rob43
    PS, If you have a conveniently located 240v outlet, you can charge up in 2 1/2 hours for less than $50 dollars.
  18. Nascosta
    Nascosta New Member
    Laguna Beach
    2019 Prius Prime
    So it sounds like the ideal setup would be in the 28-30 lb range per wheel & tire assuming it’s a low rolling resistance tire.
    it’s crazy how the mileage takes a 25% hit with just a few pounds of extra weight per corner. It’s almost like you’re adding 500 pounds in the trunk
  19. MTN
    MTN Member
    83
    SB, CA
    2020 Prius Prime
    Its crazy what some people will pay for fashion.
    Salamander_King likes this.
  20. Rob43
    Rob43 Senior Member
    1,335
    940
    2013 Prius v wagon
    Concerning MPG's on a Prime:
    Typically speaking, trying to keep un-sprung weight (wheel & tire weight) down* is a fairly important thing. But what I believe is a slightly bigger issue on the Prime is having a good or great LRR tire. I can tell you from experience that it's very hard to buy an"affordable" 17" wheel & tire setup that is both light-ish in weight & has a good working LRR tire in the upgraded 17" size. It's a tough equation.
    I'd say that my personal MPG loss is roughly 12-15% when Solely on the ICE. I'm OK with this because my new driving enjoyment is much much higher when compared to running on the OE 15" wheels & tires.
    Rob43
    * My light-ish weight 17" wheel & tire setup is still 3 to 4 lbs heavier than stock.
Loading...
