Aftermarket Wheel Fitment Guidelines
Discussion in 'Prime Accessories and Modifications' started by Rob43, Apr 3, 2018.
  1. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    I get excellent mileage using my 17" Corolla wheels with Firestone 215/45/17 tires. At least 25 mile electric range and 55+ mpg using gas on the freeway at 70-75mph. So maybe 10% lower than the stock 15". I average 1000 miles a month and use about 9 gallons a month. So my "crazy" penalty is at most $4.00 a month.
    But... I receive significantly improved cornering and shorter emergency braking. And I think they look way better than stock. Overall, well worth it for me. Oh, and I sold my stock wheels/tires/hubacps for MORE than I paid for the Corolla wheels/tires.
  2. Nascosta
    Nascosta New Member
    Laguna Beach
    2019 Prius Prime
    Those look great, doesn’t sound like much of a mileage hit at all. What do you estimate they weigh? Mid 30 pound range?
  3. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I wrote an interesting thread on all of this earlier this year. Basically it says that as your overall tire diameter gets smaller (like a 215/45-17) your MPG's get better.
    Tire Diameter vs MPG's:
    Tire Diameter VS MPG'S | PriusChat
    Rob43
    AshPrime likes this.
  4. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    They are OEM and heavy. I think 24lbs per wheel.
  5. Chuck Miller
    Chuck Miller New Member
    2019 Prius Prime
    Finally got around to getting my new wheels. Ordered from discount tire. Install took 30 min. $590 total. Drag dr-69 wheels. Same width and diameter as stock. Maybe a lb lighter. Really changes up the look.
    B66B1AF0-0C3E-4531-B8F4-DAA8643FCB5D.jpeg E6A82B78-2794-4211-93AF-7669FB4D11BD.jpeg 323E409A-84B3-4257-82BF-F1B7A675FEFE.jpeg
    don_chuwish, TGrracie, evpv and 2 others like this.
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Are your new wheels using the stock OEM lug nuts? Your wheel has dual bolt pattern holes like my 15" MB wheels I bought for the winter tires. My wheels do not take OEM TOYOTA lug nuts, instead, I have to use thinner tuner lug nuts. I hate needing a special key for my winter wheels and looking for 15" stock size wheels that can take OEM lug nuts. Also, how big is your center hub bore? Are you using hub rings?
  7. MTN
    MTN Active Member
    306
    276
    SB, CA
    ^^ could have just removed the wheel covers for $0 and had a similar look
    *shrug*
    Rob43 likes this.
  8. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Our OEM wheels sell for around $100 each, and the hubcaps go for around $50 each. The Drag dr-69 wheels are $100 each. So he may have actually made money on this swap, even after installation costs. Plus he may have wanted black wheels for a unique look.
  9. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    The Toyota OE 15x6.5 wheels look reasonably good when the hub cap is removed.
    If the owner is willing to do a little DIY work, these wheels can easily be painted Black for pennies on the dollar. The small ~2" Toyota caps with logo can now be sourced for cheap. Here's a generic Prius wheel that was painted Black...
    Rob43
    MTN likes this.
  10. Chuck Miller
    2019 Prius Prime
    To answer the questions... tried the stock without covers and while I like the look on a white prime in my neighborhood, I didn’t like it on mine. Wanted black to go with the magnetic gray and wanted to use same tires. So, I got these. No hit to mileage and a good price. I live in a community where I have no storage or anywhere to work outside so No DIY work and sold the wheels to a company that paid for shipping. Didn’t get my full cost out of them but also didn’t have to hang onto them. Overall a good deal for me.
  11. Chuck Miller
    2019 Prius Prime
    Had to get new lugs. At least I am in Cali and don’t have to change tires. Yes, using hub centric rings. Bore is 53 I think.
    #171 Chuck Miller, Dec 24, 2019
    Salamander_King likes this.
  12. in2tv
    in2tv New Member
    Walnut
    Just picked up the identical wheels to yours. Would you recommend going with 225/45/17? I saw on tire comparisons that the 225/45/17 has identical dimensions to the stock 195/65/15 except the width. The 225's shouldn't throw off the speedometer. What did you use for the lug nuts and wheel lock? Thanks for the info.
  13. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    You really need to think about tire weight and whether you're gonna choose a LRR or Non-LRR tire.
    1) 215/45-17 = 24.6/24.7" OD (Lightest)
    2) 205/50-17 = 25.1" OD (Fractionally Heavier)
    3) 225/45-17 = 25.0" OD (Heaviest)
    Also more tread equals more rolling resistance all thing being equal.
    Rob43
  14. David Rush
    David Rush Junior Member
    28
    17
    BC Canada
    2020 Prius Prime
    After I pulled off the wheeldiscs, I popped the center caps out of them and glued them onto the pretty stock alloys with a dab of clear silicone.
    Couldn't be happier with the results.
    Rob43 likes this.
  15. Mendel Leisk
    42,299
  16. The Big Sleaze
    291
    68
    'frisco
    2020 Prius
    Two Eco
    whats a cheap, no-nonsense (steel?) wheel that will take regular tire that will fit on 2020 Prime?
    I'd like to at least have one spare "real tire" on a wheel ready to go, even if it stays in my van/storage-shed and requires a rescue mission.
  17. Salamander_King
    11,024
    8,978
    New England
    This rim was mentioned in one of the snow tire thread for RPIME.
    1 New 15X6 Pacer 84B FWD Black Mod Wheel Rim +41 5X100 & 5X115
    But any tire shop or online store will have a decent generic steel rim for $40-$80. If you want Toyota OEM, older Corolla steel 15" wheel will fit with a correct center bore size. I can't remember the parts number but IIRC a new one will cost over $100 now but you can find used one on eBay for about ~$70.
    #177 Salamander_King, Jan 12, 2020
  18. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Yes, as the author of the thread "Get Your Dedicated Snow Tires Now !!!", I posted the link you want in post #1.
    GET YOUR DEDICATED SNOW TIRES NOW !!! | PriusChat
    I personally run 4 of those exact steel wheels on my Prime as my dedicated snow wheels/tires, they're inexpensive & get the job done.
    Rob43
    MTN likes this.
  19. Salamander_King
    11,024
    8,978
    New England
    Hum, he lives in Texas. I don't think he needs the new rim for winter tires but just wants a full-size spare tire.
  20. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    I bet he's smart enough to figure that out...
    Rob43
