AGM battery for Gen 4/Gen 5 Prius/Prius Prime and observations on the 12-V charging system
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Sep 20, 2024.
  1. Gokhan
    Gokhan Senior Member
    6,216
    2,465
    Paramount CA
    In my Gen 4, turning on and off of the A/C has no effect on the DC–DC-converter voltage.
    I did verify that the cigarette-lighter voltage tracks the battery voltage (but it is somewhat smaller, especially with load on the socket).
  2. Roy Peterson
    Roy Peterson Member
    98
    128
    Richland WA
    2024 Prius Prime
    Regarding the aux port voltage, it agrees with the BM voltage and what the scan tool reads. What I was intending to say was that I would put the car in ACC mode by pressing the start button with foot off brake. The voltage I see on the aux port voltmeter is 12.2 to 12.4 volts. This is with battery under a load in ACC mode. Comparing this to the BM voltage gives me a sense of the battery health. Along with actual reading. I monitor the trend. I’m not OCD - I did this type condition monitoring CM in my work career and traing and habits carry into your personal life thinking
    Drove the car yesterday but not today. Currently this evening, the battery voltage is 12.61 volts. Yesterday after driving with charge voltage 14.4 volts continuously, the BM voltage after car asleep for several hours was 12.80 volts. Most likely impacted by surface charge reading since BM voltage was 12.64 volts early this morning.
    So for a recent 26.6 minute trip with charge voltage 14.4 volts continuously, what I recorded was initial aux battery current started at 3.6 amps and over trip time dropped to 2.4 amps. Using 2.8 amps as an estimated average charge current, only @ 1.25 AH is put back into the battery (2.8 amps x .44 hours). This is the longest trip time typical for me. Often trip times less than 15 minutes. Thus even at 14.4 volts with my trip times, I doubt the battery would ever reach a true 100% SOC. Not a concern for me personally with this AGM battery.
    Now with the OEM battery, I would have a concern. Frankly, I don’t understand the Toyota statement of a full charge every 20 driving hours to prevent sulfation. How does that work if I drive a few short trips and not drive for a few days ? Maybe a clue as to why the OEM battery has reports of discharged state…..
    I may decide to do a full charge of the AGM battery once a month to improve battery life. It’s not a big effort plus I do that already with my truck AGM battery since my trips are same pattern as the Prius. 3 years from a battery is OK for me and I understand others feel different. I still have the OEM, it’s tests good and I keep it charged so I do have a backup of sort.
    Cheers
    Kevin Kellogg and Gokhan like this.
  3. Gokhan
    6,216
    2,465
    Paramount CA
    The lowest resting voltage I've seen is 12.61 V, and the aggressive charging kicked in the next day, raising it to 12.78 V. 12.61 V is about 77% SOC; so, the BMS seems to not allow below 75% SOC. Lately, the resting voltage has been around 12.61–12.65 V, which is about 77–80% SOC.
    One hour of continuous charging at 14.3 V should take the AGM battery from 75% to 100% SOC.
    In any case, from what is being reported, the Uplus AGM battery seems to be working much better than the OEM flooded-cell battery. Someone reported 11.9 V on his OEM Gen 5 battery here, which means it has already got damaged by sulfation.
    Kevin Kellogg likes this.
  4. Roy Peterson
    Roy Peterson Member
    98
    128
    Richland WA
    2024 Prius Prime
    For the past several weeks, temperatures have been in the 30’s and low 40 range. During this period, the aux battery charging voltage has been a constant 14.4 volts. Morning battery voltage typically 12.6X volts per the BM.
    Chinook winds today with warmer temperatures. On 4th trip this morning, temperature at 58, the charging voltage dropped down to 12.8 volts. Temperature hit 62 this afternoon. All additional trips initial charge 14.4 volts but decreased to 12.8 volts within a few minutes returning to pattern I have observed prior to the recent drop in temperature. So the takeaway would be the outside air temperature has an effect on the charging voltage.
    Cheers
    soft_r and Gokhan like this.
  5. Gokhan
    6,216
    2,465
    Paramount CA
    I am not sure if this is because of the cold temperatures or because your voltage is dipping to 12.61 V. From what I see, when the AGM-battery voltage dips to 12.61 V, the BMS charges aggressively for half hour at 14.3 V.
    What I don’t understand is why you are still seeing 12.6 V the day after aggressive charging. In my case, it would be about 12.8 V or higher. Do you have an accessory that causes high parasitic drain?
  6. Gokhan
    6,216
    2,465
    Paramount CA
    Observations after weeks of testing:
    1. The BMS does not let the AGM-battery resting voltage to dip below 12.61 V (77% SOC). It does aggressive charging at 14.3 V for half hour when the resting voltage drops to 12.61 V. This typically brings the resting voltage to around 12.8 V.
    2. Unlike someone claimed here, the Prius BMS is not calibrated for a flooded-cell battery. It is clear (from observation 1 above) that it is agnostic to the battery type, as it can calculate the SOC using the history of the measured current and voltage values.
    3. The AGM battery works much better than the OEM flooded-cell battery in Gen 4/Gen 5 Prius. Virtually every owner is reporting quick capacity degradation and sulfation with the OEM flooded-cell battery. This is because of the miserly BMS—not parasitic drain. The AGM battery charges more quickly and efficiently, alleviating the low-SOC and subsequent degradation/sulfation issues.
    4. The only disadvantage of the AGM battery is the 5-lb extra weight. Other than that, the performance is far superior to a flooded-cell battery in the Gen 4/Gen 5 Prius.
  7. Roy Peterson
    Roy Peterson Member
    98
    128
    Richland WA
    2024 Prius Prime
    My car has no added accessories. I charged the traction battery yesterday evening and then unplugged the charge cable. This morning the aux battery voltage was 12.83 volts per the BM before first drive. Outside temperature 44F per car reading. 15 minute trip the charge voltage was 14.4 volts continuous. Return trip 13 minutes charge voltage 14.4 volts continuous.
    Cheers
    Gokhan likes this.
  8. Roy Peterson
    Roy Peterson Member
    98
    128
    Richland WA
    2024 Prius Prime
    Battery voltage was 12.82 volts after drives this morning. Trip 3 this afternoon at 47F showed 14.4 volts for 15 of the 19 minute journey at which point it decreased to 12.8 volts. Return trip voltage went to 12.8 volts within a minute of starting car. Hour after arrival, current battery voltage 12.79 volts.
    Tomorrow morning temperatures forecast in the 30’s. It will be interesting to see if the charging system stays at 14.4 volts as was the case for the 2 week period where temperatures struggled to hit 40 F.
    Cheers
    Gokhan likes this.
  9. Roy Peterson
    Roy Peterson Member
    98
    128
    Richland WA
    2024 Prius Prime
    Made 2 trips Friday about 10 minutes each way. Temperature 44F. Charging voltage constant 14.4 volts both trips.
    This morning voltage was 12.73 per BM prior to drive. Made 2 trips about 18 minutes each. Temperature 39F. Charging voltage 14.4 constant both trips.
    Cheers
    Gokhan likes this.
  10. Gokhan
    6,216
    2,465
    Paramount CA
    It looks like not having an active Toyota Connect subscription seriously increases the parasitic drain. The car is probably constantly exchanging data with Toyota’s server to confirm whether there is a subscription, which is using a lot of battery.
    Interestingly, even without an active Toyota Connect subscription, live traffic information still works on navigation in my 2021 Prius Prime Limited.
    If you don’t have an active Toyota Connect subscription, do not leave the car undriven without a battery maintainer for longer than a week.
  11. soft_r
    soft_r Active Member
    180
    145
    Beverly Hills
    2024 Prius
    Well it's not happening from the head unit, that gets 0 power when the car is off.
    So then it has to be through the DCM which stays powered and has its own small internal battery. There's a fuse to disable that if you don't use any features it gives. :)
  12. Gokhan
    6,216
    2,465
    Paramount CA
    That 18650 lithium-ion battery is only used in the case of a collision with a 12-V-system failure.
    Mobile-phone battery (backup battery): Is built into the DCM (telematics transceiver) and supplies power to the DCM (telematics transceiver) when the Automatic Collision Notification (ACN) service is activated and the vehicle battery cannot supply power.
  13. Paul Gregory
    Paul Gregory Senior Member
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    I got my Gen 5 about a year ago, and I had a lot of trouble at first with my 12V battery going flat and being unable to start my car, sometimes this would occur over a few days, and sometimes within a few hours. I reported the problem to my dealer, and twice they said "it tested OK." I took it to a second dealer, and they replaced it under warranty, but the problem persisted. At that point, I suspected high parasitic drain, and I was able to measure 330 mA, but it varied considerably over time.
    I purchased a 100Ah Li-ion auxiliary battery for it, and wired it in parallel with the standard battery. I installed a "smart battery isolator" which cuts out at 13.8V to prevent the auxiliary battery from draining along with the main 12V battery. They are connected by a heavy 10 gauge wire, with a heavy bypass switch to "boost" the main battery if needed (although I have never needed to do this).
    I have a combination ammeter/voltmeter at each battery, which shows me the state of charge, and how much current it being transferred.
    After almost a year, I can say that I haven't had a dead battery since.
  14. hill
    8,806
    2 batteries in parallel ? Is this message meant to convey that this's what it takes to stop / overcome parasitic loss? Far from encouraging.
    That said - the same thing was necessary when I started running front & rear & side dash cams on our 2018 phev.
  15. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    Well, I'm encouraged by the fact that I haven't had a dead battery since I installed the aux battery.
    RandyPete likes this.
  16. Gokhan
    6,216
    2,465
    Paramount CA
    I would discourage anyone from adding an LFP 12-V secondary battery. It is unnecessary and unsafe.
    From my and @Roy Peterson's experience, one of the main culprits is the choice of a flooded-cell battery by Toyota in Gen 4 and Gen 5. Replacing it with an AGM battery of the same size (not an LFP battery) eliminates most battery problems. The Gen 4 and Gen 5 12-V BMS is miserly and a flooded-cell battery doesn’t charge fast enough due to its higher internal resistance.
    Other than that, especially without an active Toyota Connect subscription, the parasitic drain could be as high as around 5% a day if not higher (corresponding to an average current of 100 mA or higher). You should use a battery maintainer if you don’t drive the car for at least a couple of times a week. If the car is driven every few days, a battery maintainer shouldn't be necessary with an AGM battery but could sometimes be necessary with a flooded-cell battery.
    #216 Gokhan, Jan 3, 2025
  17. Gokhan
    6,216
    2,465
    Paramount CA
    I got a more accurate number on the parasitic drain:
    • It is a 0.03-V drop in 24 hours for the 50-Ah AGM battery,
    • which is a 2.1% SOC drop in 24 hours,
    • corresponding to an average current of 45 mA.
    It seems typical for a modern car. I doubt it makes a difference with our without Toyota Connect subscription.
    Considering that the battery can already be at as low as a 70% SOC, you do not want to leave the car undriven without a battery maintainer for longer than two weeks.
    Note that even if you do not drive the car and do not have a battery maintainer, you can turn it on to the READY mode for half hour or, even better, for one hour once a week to recharge the battery. It will unlikely go over an 85% SOC, but it will prevent a battery failure and/or serious battery degradation.
    Kevin Kellogg and soft_r like this.
  18. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    I may have been concerned at first, but the way I have it installed, I've had no issues for at least 9 months. When I had the car in for service, the dealer had no issues with it either.
  19. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    What's the basis of your claim that an aux battery is unsafe? I have wired it properly and protected the connection with a fuse. The dealer inspected my setup and had no issue with it. The parasitic drain I experienced was variable and unpredictable. The aux battery seems to have solved the problem of having a dead battery.
    reservoirblue and hill like this.
  20. Kevin Kellogg
    Kevin Kellogg New Member
    Prescott, AZ
    2020 Prius Prime
    I've only owned my 2020 Prime for 3 months. It is 5.16 years old and has 56,000 miles. My wife was stranded shortly after we bought it because it wouldn't start without a jump. Since then it seems to have responded well to CTEK trickle charging and the problem has not reoccurred. I attached the voltage reading since December 15th as well as the reading from today. The voltage seems to jump at the beginning of a trip and drop quickly afterwards as shown in the second chart.
    The lowest levels have been around 12.4 a few times and the garage is usually around 50 degrees. The state of charge table I have indicates about 75%. An AGM battery equivalent looks like it would be around 12.56 or so or not far from your 12.61 resting voltage on your new AGM.
    I drive about 98% in EV mode. Perhaps I'm missing something on the battery monitor readouts but my plan is to keep trickle charging every week or so and keep an eye on it.
    GcinFl and Gokhan like this.
