AGM battery for Gen 4/Gen 5 Prius/Prius Prime and observations on the 12-V charging system
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Sep 20, 2024.
  1. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    Do you charge by connecting directly to the battery or do you connect under the hood via the fuse block? Obviously the latter is far more convenient. Does it matter?
  2. Paul Gregory
    Paul Gregory Senior Member
    2,128
    555
    Alberta
    2024 Prius Prime
    XSE
    It doesn't matter, but the connection point under the hood is recommended and more convenient. I use the stud located there to connect my battery maintainer with ring terminals. The alligator clips detach, leaving the ring terminals.
    ngc4565 likes this.
  3. Gokhan
    Gokhan Senior Member
    6,153
    2,432
    Paramount CA
    Mine is a Gen 4 PHEV. So, I think the only option for me is the old-fashioned way of clamping on the battery terminals.
  4. Paul Gregory
    2,128
    555
    Alberta
    2024 Prius Prime
    XSE
    I never had a gen 4, but my gen 3 had a clamping terminal under the hood.
  5. Gokhan
    6,153
    2,432
    Paramount CA
    The Gen 4 battery—unlike the Gens 2, 3, and 5 batteries in the trunk—is under the hood.
  6. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    I hooked up my digital charger this morning which has an AGM mode. The battery was reading 13.5 volts. Just for fun I put a P3 Kill A Watt meter in line so that I can monitor things like the charging time and power consumption. At present the charger is drawing only 19 watts and the voltage has risen to 13.7 after 15 minutes on charge.
    Update: 3 hours and 50 minutes into the charge. The charger is alternating between 13.6 and 13.8 volts. It appears to be attempting to repair the battery as the status indicator is flashing red. This is a relatively inexpensive charger from Harbor Freight but is has served me well for several years.
    #246 ngc4565, Jan 30, 2025
  7. Gokhan
    6,153
    2,432
    Paramount CA
    I probably wouldn't trust a battery maintainer from Harbor Freight.
    ngc4565 likes this.
  8. Paul Gregory
    2,128
    555
    Alberta
    2024 Prius Prime
    XSE
    Flooded cell batteries bulk charge to 14.2 volts and a float charge of 13.4 volts.
    AGM batteries bulk charge to 14.7 volts and a float charge of 13.8 volts.
  9. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    8:45 into this experiment the smart charger was reporting a steady green state and 12.9 volts. I plan to give it another go in the morning.
    My charger is an inexpensive unit from Harbor Freight. I cannot say that I trust its display readings but it has served me well for several yeas while charging the lawn tractor in the off season and the inverter generator once a quarter. The latter has had an AGM battery since 2021 that needs a top off every few months.
  10. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    I revisited this today. After about an hour the charger was in its green or happy state reporting 12.8 volts. I believe that the new battery has a 100% SOC. Does anyone check this occasionally or should I just assume that we are good to go for the next eight years?
  11. Paul Gregory
    2,128
    555
    Alberta
    2024 Prius Prime
    XSE
    I don't sweat the small things unless they give me some indication I should.
  12. Gokhan
    6,153
    2,432
    Paramount CA
    @Roy Peterson, with the AGM battery, I have been seeing around 83% overnight-rested SOC (12.69 V) or perhaps a little higher.
    What was your overnight-rested voltage with your OEM flooded cell after it was fully charged with a battery maintainer and then the car was driven for a couple of weeks?
  13. Roy Peterson
    Roy Peterson Member
    97
    126
    Richland WA
    2024 Prius Prime
    With my AGM, I did a full charge with my Noco Genius 5 a few weeks ago. The weather has been in the 30’s and 40’s up until today. For the past 3 months, the BMS charge voltage has been 14.4 volts. Even after the full charge with the Noco, the voltage was a solid 14.4 on every trip. I didn’t drive the car today and the voltage is 12.78.
    Regarding the OEM battery, my recollection is the early morning voltage was 12.3X - 12.4X for late September. This would be after a full charge and driving short trips. I put the AGM in the car first week October. AGM battery big improvement over the OEM.
    Cheers
    GcinFl and Gokhan like this.
  14. Roy Peterson
    Roy Peterson Member
    97
    126
    Richland WA
    2024 Prius Prime
    Regarding the OEM battery, after I had a dead experience in August, I made appointment to have the dealer investigate. They tested the battery as OK. However, I saw a copy of the battery test print out and it stated something to the effect starting below 32 F may be marginal. Nor did they perform the fault isolation procedure that Toyota has for a dead aux battery. They basically charged, tested battery and made several successful starts. I was so disgusted with the dealer at the time I didn’t push the issue. If the battery is marginal below 32 F, that’s not a good serviceable battery IMHO. Made the AGM decision easy…..
    Cheers
    Gokhan likes this.
  15. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    #255 Dael, Feb 23, 2025
  16. Roy Peterson
    Roy Peterson Member
    97
    126
    Richland WA
    2024 Prius Prime
    A little update on how the BMS functions with temperature. For past 2.5 months, temps here in eastern WA have been cold Below 40’s. During this time, the aux battery charge voltage has been a constant 14.4 volts.
    Finally temps warming. Garage temp was 54 F this morning. About 11 minutes into drive, charge voltage went from 14.4 to 12.8 volts. Next trip charge voltage dropped within a minute to 12.8 volts. Exactly what the car did during warmer months. I was glad to see the BMS kept a constant 14.4 volts during the cold weather and thus kept the battery healthy.
    Cheers
    RandyPete and Gokhan like this.
  17. Gokhan
    6,153
    2,432
    Paramount CA
    Yes, that is a significant nightly parasitic-drain event that you can see in my graphs posted here. The SOC drop associated with it is about 1%.
  18. Gokhan
    6,153
    2,432
    Paramount CA
    It looks like the BMS kept the flooded cell at about the same SOC as the AGM cell, as the AGM cell voltage is about 0.25–0.30 V higher for a given SOC. Nevertheless, AGM cells are certainly more robust and durable than flooded cells.
    GcinFl likes this.
  19. mc510
    mc510 Junior Member
    22
    2019 Prius Prime
    Phew this is a long discussion! Apologies for asking rather than reading, but I pooped out at page 3. At which point I still couldn't tell what was the view on the AGP battery replacement. After all of the in depth analysis and testing, is it a drop-in replacement (other than the requirement to fully charge before installing)? Saw some comments about possible need to boost the charge after using for a while ... maybe I misread, but wondering if that's an issue with the AGM battery or an issue that the Prius Prime would have with any type of 12v battery? (Mine is a 2019 still on the original battery but I think it needs to be replaced.)
  20. Gokhan
    6,153
    2,432
    Paramount CA
    Hey, there, yes, the Uplus AGM battery is a fine direct replacement.
    Yes, fully charge it before you install it.
    You don’t really need to do manual periodic charging (with a battery maintainer), but it could help. And, no, it is not because of the AGM type. It is the same issue with the flooded-cell type that the battery management system likes to keep the battery at around 75% SOC. It will charge it to 90+% every now and then (like every 20 driving hours or so).
